Issue with Powertap G3, erratic readings?
Hi there,
I've just recently changed my battery to my powermeter and for some reason the kws are jumping around quite alot, from my very first setup and I have no idea whats caused/causing it to do this?
I had no idea these things had to be done, as all I did when I got it. Was blue tooth to my computer and everything worked fine, my cadence, powermeter were pretty much in sync while ridding on my smart trainer.
All Ive done is changed over battery, (2 times now), just to double check if it was the battery. I've also done the calibration from my cycle computer (Bryton 310), its set at -6.
Cadence is fine when comparing the 2, but my power output now is so erratic Im getting frustrated 🤦*♂️🤦*♂️🤦*♂️
Does anyone have any idea whats happening and how to sort this out please?
Very much appreciate the help. Thanks
