V-brakes vs. Cantilevers
#51
meow
Bikes: 2016 Parlee Altum, 2013 Cannondale Super Six Evo Hi Mod Di2 only, 2011 Cannondale Super Six, Dura Ace 7800, 2007 Cannondale System Six Dura Ace 7800, 1992 Bridgestone RB-1, MB-2, MB-3, MB-5
Tomorrow will mark 12 years...I came to this thread -- and happy to keep it alive -- because I am considering a Surly Cross Check and a Long Haul Trucker (I'm a road racer and typically "hang out" in the 33). Thanks for the years of info here folks I'm going to use it, at first, for a 1700 mile tour through Europe, then, probably commuting and some recreational off-road riding. I think it will be V-brake for me.
#52
Quoted: 4234 Post(s)
Liked 2,948 Times
I like cantilever brakes. I haven't found them to be that hard to adjust and I have the old style post pads as opposed to the ones you actually screw in and can do the angle easier. Work great for a drop bar mtb conversion.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#53
meow
I have cantilever on my old bridgestone mb-2 and mb-3 without issues...but, I do like the v-brakes on my kids' mtbs
#54
Not bad for an old thread! With our luck it might reach 13!
My only issue with my Bianchi Sika's cantis is heel strike.
I have Deore LX cantis on that bike and my heels often hit the brakes.
#55
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
bump!
I like cantis because they offer a wide range of adjustment (which also complicates adjustment), though I haven't riddent vbrakes for a few years. I remember they stopped well but I feel like there was less modulation.
#56
Bikes: Litespeed Ti Mtb, BikeE Recumbent, Cannondale H600 Hybrid,
When I bought my mtn bike, there was a craze for anodized parts, so I set up my bike with blue colored parts. Got myself blue colored Critical Racing cantilever brakes with matching blue colored Paul Love Levers. Well that was back in the early 90's.....it is still going strong and like they say, if it ain't broke, why should I change to vee brakes...
#57
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
Minimalism is big now. In houses . . . in running shoes . . . who knows? Maybe brakes that are almost not there will make a comeback too
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
#58
___________
Liked 2,948 Times
I've heard those striders are the best way to teach kids to ride.
#63
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 669 Post(s)
Liked 971 Times
I don't know I have a merida equiped with the full 1993 lx group set, the cantis are braking well but i will replace them later with v brakes for a better and more modulable braking.
#64
Bicycle Repair Man !!!
Checking in...
Kudos to those using the search feature and not starting another cantis vs V brakes thread because it has been a question that has plagued mankind for millenia.
#65
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
Nothings ever quite that simple anyway. V-brakes ARE THEMSELVES a form of cantilever brakes - actually the Registered name for Shimano's version of linear pull cantilever brakes. Even cable pull isn't consistent. Mini V-brakes will have a ratio similar to traditional cantis and less mechanical advantage than V-brakes eith longer arms. And the now discontinued Shimano parallel push V-brakes have every bit as much braking power as many disc brake systems.
Tire, fender or rack clearance is usually more of a reason to end up with one system over another. Traditional cantis give the most clearance and can handle any tire/fender combination that'll fit on a bike. And they happen to be compatible with the pull ratio of most road brake levers.
#66
Quoted: 11 Post(s)
Can v-brakes generally be mounted on frames that typically use cantilevers? I'm looking at building a commuter and inevitably I come across cyclocross frames (e.g. the Soma Double Cross) as being good candidates for the build. But in any photos of these bikes as commuters they almost universally have cantilever brakes on them. I was just wondering if there's any reason that they can't use v-brakes instead?
#67
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Generally, Yes they use the same base in most instances. There are a few odd situations where that's not true that I've run into, but most (well over 95%) instances it's a direct replacement. However, be aware that you may have to change your levers as they typically are not compatible between canti and V's.
Roccobike BF Official Thread Terminator
#68
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I'm trying to fit rim brakes to a fork with narrow 55mm wide post centers combined with 22.5mm wide rims. I need suggestions for cantilever brakes with short arms and highly adjustable pad placement or I will need suggestions for V-brakes, if cantilevers are not going to fit. Both the angle of the pad and the height of the pad needs to be adjustable.
Any suggestions?
Any suggestions?
#69
Frozen in carbonite
Bikes: '85 Full Cycle Cycle.
Quoted: 910 Post(s)
Liked 288 Times
Old school Shimano 600 pre-aero Road bike levers
#71
Frozen in carbonite
Powerful-Ugly Creature
#73
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,683 Times
Any suggestions?
Any suggestions?
EDIT: might not even need that. What kinda fork is it? What tires? If a touring fork and tires around 40mm- you could probably run some long-reach roadie calipers.
#74
Any suggestions?
Any suggestions?
#75
Quoted: 910 Post(s)
Liked 288 Times
Paul Motolites come immediately to mind. The little brackets that the brake shoes mount to can be flipped over to not only put them above or below the brake arm, but also to move the shoes farther outboard. Of course, being from Paul's, they're a bit pricey.
