putting smaller wheels on this specific bike...possible?
Hi,
I'm trying to lower my schwinn Willy black 7 speed by 2 inches. Current specs are 700c wheels and i'd like to replace these with 26 inch ones. I'd be fully prepared to buy new rims, shorter cranks, parts, etc if necessary
heres a picture :
https://99bikes.com.au/sites/99bikes....s/S11WIL7S.jpg
thanks in advance
heres a picture :
thanks in advance
Pwnerer
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
To lower your bike by 2", you'll need to reduce the wheel diameter by 4" -- even converting to 26"/559mm rims and using the skinniest tires available won't do that unless you were using big 700C tires before.
So, let's hear why you need/want to do this.
RUSA #7498
Originally Posted by noglider
Friendship is Magic
Bikes: old ones
Quoted: 26250 Post(s)
Liked 10,231 Times
Coaster brake, drum brakes, disc brakes if you have money to burn.......be prepared to build your wheels.
+1 on probably not worth the cost, trouble, and differences in handling incurred.
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
Plus you would ground the pedal if you leaned even a little bit while pedalling, unless you also went to shorter cranks.
