Cannondale eccentric frozen?
Old 07-24-20, 12:44 PM
Freerojo
Bikes: 1997 Specialized Hardrock GX, 2008 Specialized Roubaix Triple 105, 1996 Cannondale RT2000 tandem
Quoted: 48 Post(s)
Liked 19 Times in 14 Posts
Hi, I went to adjust the eccentric on my 1996 Cannondale RT2000 and it would not budge. Bolt backed off easily. I tapped on the bolt to try and loosen with a rubber mallet. The spanner pin holes on the exccentric look a little rough. I have a Park Tool Green spanner that will fit but, because of the previous wear mentioned earlier, I notice the spanner can slip out when i put some force into it. Would it be wise to spray some PB Blaster into the eccentric and wait a week or too for it to do its stuff? I suspect the eccentric hasnt been touched in years. Thanks Ron
Freerojo is offline
Old 07-24-20, 05:04 PM
Leisesturm
Quoted: 2494 Post(s)
Liked 738 Times in 522 Posts
WD-40 and 40 minutes (or less) should do it. In any case I can't see it taking a week!
Leisesturm is offline
Old 07-24-20, 05:19 PM
WheelsNT
Quoted: 22 Post(s)
Liked 18 Times in 13 Posts
The answer is here: https://hobbes.ucsd.edu/tandem/maintenance.faq
I finally broke the code, it’s an http, not https link!
For my single-wedge Cannondale eccentric, this was the complete and total answer. I now carry the bolt and washers on the bike, just as the author encouraged.
Here’s what it says:
Cannondale eccentric adjustment and overhaul.
1) Before starting
Inspect the timing chain and the chainwheels for excessive wear; clean and replace as necessary.
2) Loosening the wedge.
(If you are going to be overhauling the bottom bracket, remove the crank arms and the cartridge first.)
The Cannondale uses an expending wedge eccentric, similar in design to a handle bar stem. The bottom bracket shell is a featureless aluminum cylinder. The bottom bracket axle is mounted in a aluminum rod whose outside diameter is slightly less then the inside diameter of the shell. The axle is mounted off-center ("eccentricly"), so that rotating the holder (the "eccentric") moves the axle fore-and-aft (and slightly up and down). A diagonal cut is made through the cylinder, producing a wedge shaped piece. A nut is mounted in the wedge, and a countersunk hole is drilled through the eccentric from one end through to the wedge. A bolt is inserted into the hole and threaded into the wedge nut. When the bolt is tightened, the wedge is pulled into the bottom bracket shell, causing the effective diameter of the eccentric to increase, wedging it into the shell.
The common and wrong way to loosen the wedge is to back the bolt out so that the head is exposed, and pound on it with a hammer.
To loosen the wedge the right way, you need a short bolt with the same threading as the wedge bolt and a stack of a couple of washers, of increasing sizes. The bolt, with the stack of washers, is inserted into the eccentric from the wrong side, i.e., into the big end of the wedge (on the right side of tandem), and threaded into the wedge nut. The largest washer should be large enough to bridge across the large end of the wedge from the bottom bracket shell to the eccentric. Now, when this bolt is tightened, it gently pulls the wedge free. When the wedge is free, remove the bolt and washers, and put them in your on-bike tool bag.
The next step is to show this to your local bike shop mechanic, so that he stops pounding on frames with a hammer.
3) Overhaul
If you're just adjusting the tension, skip to "4) Adjustment".
If you're overhauling the bottom bracket, remove the bolt and wedge, and slide the eccentric out. The wedge nut can be shaken out of the wedge. Clean the inside of the shell, and all surfaces of the wedge and eccentric. A rag should be sufficient to wipe them down unless them have some especially icky stuff on them. Inspect the inside of the shell and all surfaces; they should be smooth; any illregularities may make adjustment difficult.
*** The following advice about lubrication is based on my personal experience and observations. I do not know what the official recommendations of Cannondale are. ***
Put plenty of lubrication on when reassembling. The forces trying to change the eccentric alignment during normal use are small compared to the gripping power and leverage of the wedge. I use any available "anti-seize" compound designed for normal temperatures; a high quality grease will work well also. Insert the eccentric (the right away around; the wedge will go in on the left). Reinsert the wedge nut into the wedge, and skootch it around so it's in the right position (you should be able to see the threads of the nut centered in the hole that the wedge bolt passes through). If it won't stay, a dab of grease may help hold it in place. Insert the wedge. Insert the wedge bolt (from the right side of the tandem) and get it threaded into the wedge bolt.
4) Adjustment
Tighten the wedge bolt until it's just finger tight. To turn the eccentric, you need a tool, a "pin spanner," available from you local bike shop, or good auto parts store. The tool is a U-shaped rod. The ends of the rod are bent 90 degrees, forming two parallel pins about 2 cm apart. The pins fit into two holes on on right side of the eccentric, one on each side of the head of the wedge bolt. You should be able to turn the eccentric with the pin spanner easily and smoothly. If it's not smooth, overhaul the eccentric, and figure out why it's not smooth. If it doesn't turn easily, it may be underlubricated, or you may need to loosen the wedge up some.
(When doing a field adjustment, you can use a small allen key to turn the eccentric. The short end of the key goes in the pin hole, and long end is braced against the allen key in the wedge bolt.)
If the timing chain is off, thread it on, turning the eccentric if necessary to make it easy.
I have marks scratched on two timing chain links, and on the timing chainwheels so that getting the phase correct is a snap.
Turn the eccentric to tight the timing chain, tight the wedge bolt (Cannondale has a recommend torque, but I don't know what it is; I would describe it as snug when using a standard small allen key. I would be cautious about overtightening, I suspect that the wedge can generate a lot of force).
When adjusting the chain, remember the chainwheels are neither particularly round or centered. The chain tension will vary considerably as the chainwheels turn. Find the "high spot" and adjust the chain tension there; and check it when you're done by looking again for the high spot.
How tight? I've heard two schools of thought. First the "tight" school. Grab a link midway between the chainwheels. It should not have any for-aft play, and about two cms. total vertical play. The other school is the loose school; it should be just loose enough so that it can be remounted without tools if it comes off. For racers and offroaders, I'd probably recommend the tight school, for tourists, the loose school.
After the eccentric has been adjusted, you may need to check the seat height, and the adjustment may cause the pedals to have moved positions.
Charles A. Clinton
And whoever Charles Clinton is, we all owe him a big vote of thanks.
WheelsNT
WheelsNT is offline
Likes For WheelsNT:
Old 07-24-20, 06:35 PM
Freerojo
Quoted: 48 Post(s)
Thank you for this. I will spray some PB Blaster to get things going.
Freerojo is offline
Old 08-18-20, 01:32 PM
Freerojo
Quoted: 48 Post(s)
That tip did the trick.
Freerojo is offline
Old 08-20-20, 07:29 AM
DCwom
DCwom's Avatar
Bikes: Burley Tandem
Quoted: 29 Post(s)
Liked 11 Times in 10 Posts
Our Burley has a similar wedge eccentric, in fact I've heard it is the same as Cannondale's. There is a "set screw" sort of thing that provides a backstop when loosening the eccentric, without this you can turn the eccentric bolt all you want and it won't loosen, hence the lube and hammer whacking people mentioned. See the larger center hole in the picture with the slot across it, this is the backstop. I found this at an ETR from Mel at Tandems East, apparently these things can loosen and fall out, and unless you know this you have no idea they are missing. Tandems East actually has this part, I replaced it and added some thread lock to be safe, now its a simple turn of an Allen wrench to loosen the eccentric.
key and the eccentric is loose.
DCwom is offline
Old 08-20-20, 07:36 AM
WheelsNT
Quoted: 22 Post(s)
Interesting. That looks like a better design. My older Cannondale eccentric is not threaded for that additional “stop” nut. But I’m glad to know about that in case I ever need to work on a Burley.
WheelsNT is offline
Old 08-19-23, 11:35 AM
MassCommuter
Bikes: 1984/85 Schwinn Voyageur SP; 1992 Trek 970; 1993 Burley Rock n' Roll tandem; 2007 Cannondale F5
Quoted: 5 Post(s)
Liked 3 Times in 3 Posts
1) Before starting
3) Overhaul
4) Adjustment
Charles A. Clinton
WheelsNT
This worked like a charm. Thank you for posting such a useful tip!
MassCommuter is offline
Old 08-19-23, 06:53 PM
WheelsNT
Quoted: 22 Post(s)
Glad it helped!
WheelsNT is offline
Old 08-23-23, 09:51 PM
roccitman
Bikes: 1996 Ken Evans with Campy ... something. 1999 Aegis with 105
Quoted: 8 Post(s)
Liked 12 Times in 6 Posts
Do I have a different BB? Both sides of mine appear to have wedges.
roccitman is offline
Old 08-24-23, 10:36 AM
TobyGadd
Quoted: 32 Post(s)
Liked 17 Times in 15 Posts
I think that all recent Cannondale eccentrics BBs have two wedges. Usually one gets stuck more than the other But the directions above should work to loosen either wedge. Please let us know what's giving you trouble, and someone will jump in to help.
TobyGadd is offline
Old 08-24-23, 02:50 PM
roccitman
Quoted: 8 Post(s)
Thank you, will do! I have ordered the adapter to get the old Truvativ lockring off, so we'll have to wait for that first, heh.
Old 08-24-23, 03:29 PM
TobyGadd
Quoted: 32 Post(s)
Good luck!
Before you re-install the eccentric, clean everything very well and liberally grease the wedges, bolt, and BB shell. About once a year, depending on how wet it is where you're riding, disassemble and regrease again. The problem is that there's no seal or sleeve in the frame, so the wedges are exposed to any grit or moisture that gets in there. I've also found that I don't need to torque the BB as much as Cannondale recommends, which makes removal easier. About 5 Nm seems sufficient, even on my 29er MTB tandem.
FYI, I did almost everything wrong when I tried to re-adjust my chain tension the first few times, including hammering on the bolt. Fortunately, I didn't bugger up the threads--but that was just dumb luck. The issue was that some metal filings, presumably left over from manufacturing, got jammed between the BB shell and the eccentric--making it really hard to loosen the wedges. Once I removed the eccentric, I removed both seat posts and did my best to clean the inside of the frame with compressed air, aggressive shaking, and long strips of rags. Amazing how much junk was in there! Thus, I learned the hard way to keep things really clean and lubed. I really wish that I'd seen this thread earlier!
Last, but not least, if you end up damaging your eccentric, Mel at Tandems East can probably fix it. The older-style eccentric has a simple c-clip in a groove that holds the bolt head when you spin out the bolt. If you apply too much torque trying to move the wedges, the groove can get rounded--which means that the c-clip and bolt just pop out before the wedges release. To fix it, Mel can fit a little plate with a hole in it to the eccentric, so the bolt head has something far studier to push against. Cannondale replaced the c-clip with a proper open-ended nut in later bikes, but Mel's solution is inexpensive and bulletproof insurance if you have the older style--and I highly recommend sending him any older eccentrics for the upgrade. My Cannondale MTB tandem has the older style (with Mel's fix), and my newer T2 road tandem has the newer design. The new design is solid, but Mel's fix is just as good.
TobyGadd is offline
Old 08-24-23, 09:27 PM
roccitman
Quoted: 8 Post(s)
TobyGadd Thanks for the info! Luckily I have learned the hard way to leave the hammer on the wall when it comes to bicycles (use it plenty on my dirt bike ) so haven't damaged anything. C-clip is in good shape and there appears to be a little washer between it and the bolt head, I guess to reduce friction. Good tip removing the seat posts to clean out the frame, I'll do that!
Hopefully I won't need Mel's help (on Kauai, so far away) but that's a great thing to know!
Btw, does anyone know what year the T-2 started? And how to tell the difference?
Old 08-25-23, 08:27 AM
MNBikeCommuter
MNBikeCommuter's Avatar
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times in 82 Posts
Another option once the eccentric is removed is to replace it with a Bushnell. You can adjust it out on the road with just a hex wrench. I got tired of the Cannondale eccentric, trying to keep up on regular maintenance, etc., and life has been less stressful with the Busnhell. In the early days, I approached removal with a hammer. And before everyone jumps on me for that, it was back in the days before the internet with Youtube and forums, etc., were the available go-to source of knowledge. We just had to learn a lot on our own, whether it was maintenance, which chain lube worked best, best lights, winter clothing, rain gear, etc. Now I'm feeling curmudgeony but hadn't meant to.
MNBikeCommuter is offline
Old 08-25-23, 10:52 PM
roccitman
Quoted: 8 Post(s)
Get outta my yard, right
I was checking out the Bushnell, and also found Mel's fix on Tandems East. Very slick!
Old 08-26-23, 10:38 AM
TobyGadd
Quoted: 32 Post(s)
I think that both solutions are excellent. Had Mel's fix not worked, I would have gotten a Bushnell.
TobyGadd is offline
Likes For TobyGadd:
Old 09-04-23, 04:11 PM
roccitman
Quoted: 8 Post(s)
Hat tip to the previous owner, my BB shell and the eccentric were in amazing shape. Came loose with ease. Cleaned up, re-greased and put it right back in. Amazing!
Likes For roccitman:
Old 09-04-23, 04:49 PM
TobyGadd
Quoted: 32 Post(s)
Yay! If you know them, buy them a beer!
TobyGadd is offline
Likes For TobyGadd:
