1x experiment: experiences so far
Thought I'd share my 2x to 1x experiences as "data" for others.
I built up my Niner RLT9 with Ultegra 2x (46/34, 11-32 cassette) and I've ridden like that for over 4 years. No real complaints, but I like to tinker and I do really like the simplicity and general riding experience of 1x on my mountain bike, so I decided to give 1x a shot on the gravel bike. I live in the SF Bay Area (east bay) where most of the riding involves a lot of climbing and lot's of descending...maybe not ideal for 1x gravel? I had to find out.
Swapped in a wolftooth 40T chainring on the ultegra cranks, removed the front derailleur and cables, added a wolftooth roadlink to the ultegra RX rear derailleur, added a 11-42 cassette and viola! I've got 1x.
I've put in a few mixed rides and I have to say that I quite like it so far (maybe 150 miles on the setup). It's nice to not have to think about shifting the front derailleur and the 40 x 42 bailout gear is really nice to have on some of the steep dirt climbs around here.
The typical cons that folks share about going 1x haven't really been an issue (yet), but I will report back. So far, the jumps between gears haven't bothered me and max gearing of 40-11 has been fine for flats (and I'm OK coasting down the big hills once I've maxed out).
Likes For jp911:
Quoted: 3231 Post(s)
Liked 2,079 Times
" I live in the SF Bay Area (east bay) where most of the riding involves a lot of climbing and lot's of descending...maybe not ideal for 1x gravel"
Probably IDEAL for a 1X setup. Going up and down a lot won't have you missing 1 tooth jumps on a cassette. It's when you are on a flat or easy rolling ride, may be with long sections with a headwind, that makes you want the 2X and tighter cassette.
Likes For Steve B.:
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Yeah, 1x is fine when I'm riding on my own. But in a group ride when someone else is setting the pace and cadence - the gaps are more of an issue.
Likes For chas58:
I maxed out the B-screw and shifting into the 42 cog was really rough. The roadlink solved it for me. Maybe differences in the derailleur hanger between frames and manufacturers?
I like 1x a lot for cyclocross. When I’ve done gravel races, I’ve done them on my cross bike. And for gravel, in my opinion 1x is acceptable, but that’s all. If I had a dedicated gravel bike, it would be 2x. No doubt about it. That said, the 1x in question is a 10-speed, 42x11-36. 12-speed with a bit more range, especially at the top end, might be a different story. But it’s on the edge. A double crank gets you the range and close ratios you want, easily, without giant cassettes or compromises.
Quoted: 1456 Post(s)
Liked 1,477 Times
I live in the midwest, where climbs and descents are measured in seconds. The vast majority of my riding is pancake flat. In these conditions you can pair 1x with a narrow range cassette and eliminate the gear jump issues that are usually associated with large-range 1x setups.
I have two CX/Gravel bikes with 1x setups. I'm running 11-32 or 11-34 cassettes, paired with either a 40T or 42T chainring. On my bike equipped with a 40T ring, I almost never use the top half of the cassette. For 95% of my road and gravel riding, a 42T with an 11-28 would be perfect. I run the 11-32 and 11-34 primarily to give a little extra range for CX racing, and for occasional trips to northern Michigan or Wisconsin where there are some actual hills that take more than 30 seconds to climb. If I lived in an area with more climbing I'd probably want a larger rear cassette which would make the spacing worse, but as noted in these conditions gear spacing is usually less of an issue since you're not riding at a constant speed.
Don't get me wrong, if I were buying or building up a dedicated road bike, I would probably go with 2x shifting. For CX and gravel riding? I'm good with 1x.
For comparison on spacing and jumps in gears, anything below an 11/32 is almost identical for the small side of the cassette. Here's Shimano's typical road offerings:
11-25: 11-12-13-14-15-16-17-19-21-23-25
11-28: 11-12-13-14-15-17-19-21-23-25-28
11-30: 11-12-13-14-15-17-19-21-24-27-30
11-32: 11-12-13-14-16-18-20-22-25-28-32
11-34: 11-13-15-17-19-21-23-25-27-30-34 (this is a 105 cassette)
EDIT: It's interesting because I've never really looked at cog sizes that closely, but there are some differences between Shimano and SRAM cassettes. The sizes above were for Shimano Ultegra, except for the 11-34 which is only available as 105 level.
SRAM's larger Force cassettes seem to have tighter spacing on the smaller cogs:
SRAM's 11-28 (PG-1170) has 11-12-13-14-15-16-17-19-22-25-28
SRAM's 11-32 (PG-1170) has 11-12-13-14-15-17-19-22-25-28-32
SRAM's 11-36 (PG-1170) has 11-12-13-15-17-19-22-25-28-32-36
Randomhead
Liked 3,693 Times
I have thought about going 1x, and I am pretty sure I could do it successfully. I just haven't gotten over the idea of a giant cassette to match my current 2x system
Likes For unterhausen:
Liked 1,477 Times
Shimano XT 11-42 is 433g compared to an Ultegra 11-25 at 232g. That added weight is nearly equal to whatever you'd lose from eliminating the FD and a chain ring.
I do like the simplicity of 1x shifting, especially during CX racing.
Thx for the suggestion. I have an 11-36 cassette that I've used for gravel events in the Sierras with really big climbs, but this experiment was more about trying 1x vs (cost) efficiently adding a granny gear. In fact, the 11-42 cassette I used came from my mountain bike, so the only hardware I purchased were the chainring and roadlink...a little more expensive than a new 11-36 cassette, but not by much.
Bikes: TCX & CAAD3 SAECO
Quoted: 147 Post(s)
Liked 118 Times
With a mighty wind
Quoted: 1086 Post(s)
Liked 859 Times
I ride that same ratio and have for a few years. No real complaints. I've occasionally found a place where I'd like a little lower. I don't mind coasting and tucking on the few paved descents I take but I 40x11 does feel like a bare minimum.
I think I'd like to try 10-42 x 38, that sounds perfect. Of course it's the kind of thing to put on a new bike, not my 23 year old cross bike.
Bikes: Classic lugged-steel road, touring, shopping, semi-recumbent, gravel
Quoted: 46 Post(s)
Liked 81 Times
My Marin gravel bike conversion is 1x 35t chainring and 11-36 cassette so I will report on that if anybody is interested.
Likes For smurfy:
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
I finally converted to a wide range 1x set up on my commuter, gravel, bad weather bike about a year and a half ago. The only regret I have is not doing it sooner. I went from a 2x 11/28 cassette 50/34 chainring set up to a 46t chainring 11/42 cassette 1x combo. I made a Youtube video with gear charts, and the installation process, and wow, what a difference!
Likes For Le Mechanic:
Checking back in...I'm really enjoying the 1x setup and as someone noted: it's well-suited to an area with a lot of climbing. The only issue I've had so far is a chain drop on a really rutted, fast downhill dirt trail. I heard it happen, so I just coasted until the trail turned to uphill and quickly fixed it. This revealed another benefit of 1x, which is how much faster you can put your chain back on without a front derailleur.
I took a ride on my road bike last weekend and found that I needed to put more thought to shifting with a front derailleur back in the mix. That bike is less oriented to climbing from gearing perspective, so I was def working harder on steeper climbs (not surprising).
Aside from one chain drop that got tangled in the crank spider, I have always used the front derailleur to shift any chain drops back on, no stopping needed.
I've never been so lucky. Not that I've experienced a lot of chain drops, but when I do they seem to require more work than what you describe (maybe I'm just doing it wrong).
Quoted: 46 Post(s)
Liked 81 Times
Finally test-rode my 1x setup. Microshift XLE 10 clutch real derailler and bar-end shifter. Crank is Bontrager 7050 "race" (whatever that means) formally a triple.
Shifting is absolutely flawless. Has all the gears I need however I haven't tried it on any hills yet. Rode it on gravel and chain hasn't come off yet so that's a good sign!
Maybe this weekend I will take it to some real off-road trails and see how it performs.
Likes For smurfy:
