What to wear over bib shorts in cold weather?
Quoted: 56 Post(s)
I've got a pair of bib shorts that I really like so I don't want to invest in a dedicated coldish weather bib. I've got a pair of long underwear from Target that I really like to wear over my bibs in 25-45F, but it just keeps riding down. I wish I could find a pair of just really light bib long underwear. Is there anybody that sells bib style long underwear/thermals? What are other people wearing?
Quoted: 4717 Post(s)
Liked 1,882 Times
That makes sense to me. I want to make sure that you weren’t saying that leg warmers go on at 30 or less.
For those rides when it's below 30 I use thermal tights with a pad in them, plenty of choices out there, with leg warmers under them, or my one pair of windbreak thermal tights.
If you ride a lot in cold weather, thermal tights are a good investment, IMO.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
25-35F is different than 35-45
1) wear them under the bibs
2) get more than one pair of bibs, and just invest in a pair of bib tights. By 'invest' you can find decent bib tights for $100 (or under). Heck I picked up a $40 pair from amazon that work just fine in the 35-45F range....
https://www.competitivecyclist.com/m...?sort=%2Bprice
Quoted: 1096 Post(s)
Yup. If you like your bib shorts, @hexron, there are plenty of tights out there that can be worn over them - you just need a drawstring waist to take care of your issue. If you're really thrifty and handy with a needle and thread, you could probably even make your longjohns work. The kids might say it's ghetto, but you'd get props from me for making it work - just as long as you don't race in them and cause a crash.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
You've got to find what works for you. Experiment and have a wardrobe of stuff to mix and match.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I wear running tights over my bibs in cold weather. Good to the mid 20s.
Quoted: 3953 Post(s)
Liked 7,299 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
I wear leg warmers down to the high 30s. Below that, generic running tights over bibs.
There are many bib tight options that are no chamois. Just wear them over your bib shorts.
https://www.competitivecyclist.com/p...iABEgI_-PD_BwE
Quoted: 56 Post(s)
I have a set of Asics running tights that I use if it's not windy but cold. I also have a pair insulated running tights that use if it's windy or colder than 30 degrees.
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
I either use bib tights or, if it's quite cold, some very warm non-chamois tights I picked up at MEC a while back. I don't think they are even cycling specific, but they do the job nicely.
there's a reason for a cycling specific tights, the waist is higher around the back so when your body is in a forward/tuck position the waist strap doesn't go down to the butt
Quoted: 5224 Post(s)
Liked 3,584 Times
how about cycling specific pants? they don't have liners & you won't have redundant bib tops over ea other. my headwind pants are great over my trishorts
