VO front rack/decaleur question
Quoted: 1106 Post(s)
Liked 1,328 Times
Has anyone got a VO bag or decaleur, if so could you measure the spacing of the holes in the cross-bar and (if you have the metal bit) the length of the two bits that fit in the rack?
'cause I has a rack but no top bit, VO is out-of-stock (though surprisingly cheap), will have to make one.
This creature:
This creature:
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
This creature:
This creature:
Randomhead
Liked 3,699 Times
Do you really want an original? I'm no weight weenie, but they weigh too much to use on my bikes. Huh, I guess I am a weight weenie. Plus, I like to put Orleib pannier clips on my rando bags.
Quoted: 838 Post(s)
Liked 1,082 Times
This creature:
This creature:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Want one? PM me. I make a lot of decaleurs, I've got a few of the bag bits that I use as jigs for people that want just the bike side.
The pins are 6mm (not 1/4"), spaced 40.5-41mm apart on the ones I have, but your best bet is to use the rack itself as a jig to take into account the variation.
VO uses solid rod, I use tubing. The VO bit weighs 120 grams, mine are about 50.
The VO decaleur has the quality of very low price, but some have broken theirs at the headset spacer/tubing weld. Others report that their headset comes loose as there's no clocking mechanism to work with a flat or steerer groove.
If you can make the bag side, you might consider making an entire decaleur. My Flickr decaleur album
Likes For gugie:
