Increase Max Width of Front Tire
Quoted: 97 Post(s)
Liked 7 Times
Is there a fork available for a 2008 Madone with width expanded, to allow 28mm or 32mm tires?
If the largest width in the rear is 25mm, would running 28mm in the front cause a big problem?
Quoted: 4806 Post(s)
Liked 3,931 Times
Can't help you with the increased fork. Running a front tire a size larger than the rear works just fine. The bikes I use in gravel I run a 38 in front while limited by the chainstays to 35 in back. My old race bike is 24 max in back (I run 23s because I can find them) and 25 in front. Another bike has gone 28 front, 25 rear just fine.
In terms of bike handling, most of use want our best gripping tire in front and everything else being equal, that is usually the wider one. Back in the day, the word was to use your best/fastest tire in back for race speed. (Back when every one knew that skinnier and lighter was faster.)
Likes For 79pmooney:
Quoted: 4409 Post(s)
Liked 1,563 Times
A new fork is going to be a big pain that will likely look stupid. Get more supple 25c tires, get softer riding wheels, sell your bike and get the one you want, etc. 25c tires are fine. Nothing magic happens when you make the tire 10% larger.
Likes For Kontact:
Quoted: 5791 Post(s)
Liked 2,581 Times
While running a wider tire tire in front won't cause handling issues, I can't see a logical reason why you would.
Both aerodynamic and weight distribution considerations argue for narrower tires in front, so what benefit are you trying to gain?
No need to answer as you don't owe me or anyone else an explanation for your choices. Consider this a suggestion that you think things through before spending serious dough on a fork.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 4209 Post(s)
Liked 3,875 Times
Running wider front tires is a classic BMX trick. When riding at close to the limit and cornering most would rather have the rear tire begin to slip before the front one did. The narrower rear tire allows for this. But these bikes and races are run on dirt, not the pavement that most road bikes are on.
I agree with 79pmooney in that replacing the fork is a poor way to go. But as long as you do the homework as to compatibility and geometry details I see no reason not to, not what I would do but not "wrong".
I suspect you'll find that after spending a few hundred $ and riding the bike more in conditions where the wider tire should offer greater benefits, you'll find the rear tire's width limits will soon be your next "problem". Your bike was never meant to handle the current fashion of wider tires and I suggest you accept that. Ride the bike with the OEM fork and save up for a bike that better handles your changing preferences. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Likes For BTinNYC:
Quoted: 3242 Post(s)
Liked 2,086 Times
Look around for a gravel fork, they often provide clearance for 45mm tires. This assumes you are disc brake currently
Likes For Steve B.:
Liked 1,563 Times
Likes For Kontact:
Likes For choddo:
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
A 25mm tubular will ride like a 28-30mm clincher. Replace the wheel with a tubular wheel and mount a 25mm Veloflex tubular.
Liked 2,086 Times
Likes For Steve B.:
I have a 28mm tire on the front and 25mm on my 2005 Lemond. As alluded to above, the type of brakes may be a limiting factor, not the forks. For my double pivot Campy brakes the clearance is about 1.25mm from tire to brake caliper lower edge. I had to cut off off the tire flash and sprues from the new tire I mounted-it was buzzing loudly. My photo shows my bike in a trainer, but I occasionally use this as a backup bike when working on my other bike. Yes, I know it needs a good cleaning.
Why I did it...I loved the ride of my 40mm tires on my gravel bike on pavement and ended up getting a second wheelset with 32mm road tires. but the gravel bike has disc brakes.
1.25mm clearance above tire to brake caliper
Likes For letrebici:
Likes For Biker Pete:
Quoted: 2495 Post(s)
Liked 739 Times
Quoted: 346 Post(s)
Liked 175 Times
It has been my "feel." I feel I can ride lower pressures than with a clincher before the tire starts feeling squirrely and at any given pressure road feel and ride comfort is better than on an equally sized clincher. The explanation for all this that I have read is that it is because one gets full suspension benefit of all of the air in a tubular whereas in a clincher much of the air is trapped in the wheel well and that tire flex is constrained by the bead and hook arrangement. I know many will contend this is all nonsense and they may be right but I'm just suggesting it as an option that I think is worth investigating and then deciding for oneself. Find a tubular wheel to borrow, ride it a bit and see if it satisfies the goal. If not, nothing lost.
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
I'm currently running 25 on rear and 28 on front. I find the 28 is much smoother and easier on me vibration wise because I can run it lower pressure than the 25. In the summer when the bike never sees the trainer I will run 28 frt and rear for the ride comfort. I would go wider, but there simply isn't any clearance. The 28's are pushing it.
Likes For SpedFast:
That looks like much more than 1.25mm clearance, but far less than the 5mm absolute minimum that is safe. In any case, I simply do not understand anything about your post. Not your reasons, not the details, nada. Feel free to try again, but I have to say, there is little you could say that would make me think it has been worth the money spent, the time/effort in shaving the tires, nor the constant risk inherent in running such minimal clearance up front on a race-bike.
RE: Risk...I was not suggesting that the OP, or anyone run a tire size setup like mine, but rather pointing out, that there could be a brake clearance factor which had not been mentioned prior to my post. the OP asked
I was experimenting on a back-up bike. The experiment was influenced by my experience riding my other bike with bigger tires which are much more comfortable. My time spent was minimal. My Lemond Sarthe (in my photo) is not a race bike. Also, I don't race. It has done well for me on many metric century rides though. Slowly.
Cheers
Quoted: 2338 Post(s)
Liked 2,827 Times
Jan Heine of Rene herse and supple tires fame or infamy (your choice) noted to me that a 30mm tubular would ride similar to a 35 mm supple clincher
Likes For squirtdad:
Bikes: Gunnar Sport 105/UDi2, previous: Lambert, Giant FCR3, Cannondale Synapse Carbon 105, Specialized Roubaix SL4 Comp UDi2
Quoted: 29 Post(s)
Liked 18 Times
On my Gunnar Sport road bike, Rene Herse 700 x 32 ultra-light tires and latex tubes reduced the harshness of riding on rough pavement, compared to my same inflation pressure, same-size, Panaracers.
Likes For flanso:
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
I'm afraid you may spend quite a bit of money to get very minimal benefit from going from 25mm to 28 or 32mm tires.
maybe better to think about a new bike
but what do I know ?
/markp
/markp
Likes For mpetry912:
Liked 1,563 Times
I would first at least try a supple 25c tires at the proper calculated pressure before I declared that 25s are harsh riding. I don't trust Veloflex clinchers for flats, but they would be an example, along with Turbo Cottons, Schwalbe Pro Ones, Challenge Stradas, Cayuse Pass, etc.
Likes For Kontact:
Quoted: 839 Post(s)
Liked 1,062 Times
danallen, have you measured the clearance on your current 25's? That's where I would start and you may discover that some 28's will fit without a new fork.
Likes For Crankycrank:
Quoted: 2604 Post(s)
Liked 1,933 Times
My initial thought was, "Too bad Waterford closed down, they used to make custom forks." But I suspect there are other places you could get a custom fork (Bilenky, Roderick Cycles, etc.), so that route isn't closed off to you.
If you've got a good relationship with a mechanic at an LBS, you might go see him or her the middle of January. They could look up the fork specs for your Madone (head tube diameters, rake), and help you find someone who could build you the fork of your dreams to drop into your old bike. If you don't order the fork through the LBS and have them install it, I'd urge you to drop some good money on fancy shorts or tires to make it worth their time. Just because it's the shop's slack time doesn't mean they can give you a couple hours free for what's basically web surfing/hand holding.
This! Half my bikes are newer than your 2008, so even though it's a good bike that's been fun to ride, maybe it's time to start looking for n+1.
Likes For pdlamb:
Liked 1,563 Times
This thread is luny.
Likes For Kontact:
