Kickr v. Kickr Snap
Kickr v. Kickr Snap
I would like to purchase a trainer for winter training and am focusing on the Wahoo Kickr or Kickr Snap. The Kickr is about $1200 and the Snap about $600. I don't want to spend more than I need to but I hate trying to save a bit and being sorry later. Does anyone have any experience with the trainers and have opinions on them?
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
I just bought a KICKR a couple weeks ago. First I will say you can get it from Excel and save 15% (this is what I did) plus get free shipping...you could also get the Snap there as well. I went KICKR because I didn't want a wheel on trainer anymore. I was thinking about the Direto but most places didn't have stock (like everywhere I looked)...so when I saw the deal on the KICKR I went for it. Direct drive trainer means more accurate power measurements, no dealing with tire pressures or roller tension and it means no tire wear (or a trainer tire). Theoretically the difference in cost will someday be made up in the fact that you don't have to replace tires alone (but that's quite a few tires I do admit). The KICKR 17 (make sure you get a 17) is great in that it comes with a cassette (no other direct drive trainer does that I know of) as well as all of the adapters for thru axle bikes (many other companies want you to spend $30-$60 on extra kits there) a cassette spacer if you're going to run less than 11 speed and a Wahoo cadence sensor.
You will get this with either trainer but I'd add that Wahoo support seems to be great as well. I had a few questions (not issues) so I called up support and they were able to answer them quickly.
If you have anything specific you'd like to know just ask and I'd be happy to help.
The views expressed by this poster do not reflect the views of BikeForums.net.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
The Direto is going to have trouble ever being in stock this winter, but they're shipping at a good clip. Order and it'll probably be to you in a week or two; it's just not being produced in line with demand. Are you in a huge rush? I'd rather have the Direto than the Snap, if I could afford it. Even if it meant waiting a couple of weeks.
NYC
Quoted: 1169 Post(s)
Liked 107 Times
I have had wheel on trainers and I will say that the ability to just set the wheel to the side and drop onto the Kickr w/ it's own cassette and skewer ready to go (and not have worry about / deal with trainer tires, trainer wheels, tire wear, wheel tension, tire slip on heavy intervals, and the skewer getting beat to hell by the clamps)... I love my Kickr and won't ever go back to a wheel on trainer ever again.
Bikes: 99 Klein Quantum, 2012 Cannondale CAAD10 5, Specialized Tarmac Comp, Foundry Thresher, Fuji Sportif
Quoted: 98 Post(s)
I'm cheap and did a ton of research. If you purchase directly from Wahoo Fitness they have refurbished units (when available) at discounted pricing. I finally bought the Kickr17 as it's expendable.
Not being a big trainer fan, my worry was which was going to be harder on the bike. A wheel on trainer flexes and twists quite a bit. No wheel? I don't know. Hope it's not going to stress my frame. I worry too much. Pro's use them, but their bikes are given to them.
The Kickr is super easy to set up, you'll need an Ant+ stick, an extension cord, and you're ready to go. I quick spin-down to calibrate and you're up and running. On and off the trainer is as easy as swapping a wheel and very stable to ride. Zwift makes riding indoors surprising like riding outside with friends. Someone is always there to push you.
Good luck with your decision.
Bikes: 03 Marin Bear Valley, 1999 GT ZR2000, Raleigh M80(converted to single speed), 2017 Masi Gran Corsa disc.
Quoted: 19 Post(s)
I had planned to pick up the Snap over the Winter. But I just found a 2014 Kickr on CL for $700, going to try to get him down to $600. Are there any major design changes from to 2014 to 2017 that would keep me from buying the 14?
He drop me
Quoted: 138 Post(s)
Liked 12 Times
Here's Shane Miller's unboxing of the 16 version so he will discuss changes from the original KICKR 1 to the updated version for 2016.
And then the 2017 has a few more options...Shane talks about it here:
Quoted: 19 Post(s)
Thank you.
Quoted: 138 Post(s)
Liked 16 Times
@Dreaded1 - if your trainer bike does not have disc brakes or thru axles, I'd go for the original KICKR, pre-owned but in good condition, at a $500 savings over the current model. The newer KICKR sounds a little better, the handle is better when you need to move it, and the LED indicators are better. And the newest model will work with the KICKR CLIMB Indoor Grade Simulator. The basic KICKR functionality, along with build quality and compatibility, is the same.
Quoted: 19 Post(s)
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Also, anyone run Campy 11-speed with a Kickr without issue? Can a Campy cassette be put on the Kickr?
He drop me
Quoted: 138 Post(s)
Liked 12 Times
Also check out Shane Miller's video on KICKR maintenance. Probably not a bad idea to run through it on this unit before you ride it. Also a potential bargaining point can be made from the video. Check the belt for wear...if it's time for a new belt maybe pointing that out can save you a few more bucks.
You'd think I get a kickback somehow from Shane but I don't. He just makes great videos and has tons of content on Zwift and smart trainers.
Couple questions.. the cassette it comes with says 11-speed out of the box, correct? What is the gearing on this default cassette and does anyone find that you need to use a different length chain to accommodate from whatever is on your wheels?
Here's the one for the 14 and 16 versions: https://www.wahoofitness.com/devices...-power-trainer
Advocatus Diaboli
Liked 1,533 Times
You'd need a Campy free hub and interestingly an OLDER KICKR. The KICKR17 says NOTHING about Campy compatibility in any of the literature and the part (see below) is specifically stated to be for the KICKR 14 and 16.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Yeah I saw that for the 2016. However noticed that Excel Sports product page does say there's an option to switchover to a Campy freehub. Not sure if this is just an oversight or whether perhaps the 2016 piece also works with the 2017 model and wahoo just hasn't updated their webpage?
He drop me
Quoted: 138 Post(s)
Liked 12 Times
Back to Dreded1 Here's a great (albeit long) video on the differences between the KICKR14 and the KICKR16/17 in terms of power measurement. And then DCRainmaker's unboxing video which does a great job of covering the differences.
Advocatus Diaboli
Liked 1,533 Times
If this is true then my question still remains as to what cassette gearing does the kickr come with? I don't want to have to swap chains each time to ensure correct length. Campy chains work well enough with a 11s Shimano cassette?
Quoted: 19 Post(s)
Thank you all for the input. I hadn't planned on getting the Climb anyway. I am just replacing a mag trainer that is at least 15 years old.
Bikes: yes
Liked 643 Times
FWIW I have a campy bike with an 11-speed Shimano cassette and SRAM chain. (Or maybe KMC, I can't remember now. I go through a lot of chains.)
Quoted: 19 Post(s)
My friend just picked up the "17 Kickr, it came with the 11 speed cassette.
He drop me
Quoted: 138 Post(s)
Liked 12 Times
It comes with an 11-25 cassette that I believe is a SRAM cassette.
Quoted: 15 Post(s)
I can't speak much for the snap but I have had the KICKR for about a year and a half and I love it. Bought it used for pretty cheap and have used it with both zwift and trainer road.
I like not having to worry about tire pressure, tension, etc. My favorite part about the thing is automatic resistance.
I use the powertap p1 pedals that track power during indoor workouts. Keeps it consistent with my outdoor work outs.
Advocatus Diaboli
Liked 1,533 Times
However this is marginally helpful. I'm doubting that my chain sized for my bike's 12-29 cassette will work well on the stock 11-25. So I'd have to shop for a nearest neighbor sram cassette that would work with my chain, and just getting an extra campy 12-29 is currently out of the question I guess.
I may opt for the direto which does offer a hub adapter for campy.
I'd like to get the Kikr but prefer to avoid mounting and unmounting my rear wheel everytime.
Would it be reasonable to use it on my hybrid bike (Sirius) that I haven't used much lately? Or should I stick to my road bike?
Advocatus Diaboli
Liked 1,533 Times
