"Modern Day 105 is as good as..."
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 570 Post(s)
Liked 773 Times
...Older Ultegra/Dura Ace.
IMHO - it's not. Aside from the ergonomics of the brake hoods - it's not.
2001 9 speed Ultegra vs 11 speed 105:
-Ultegra shifts better
-Ultegra shifts faster
-Ultegra shifts smoother
-Derailleur adjustments are easier - even with a triple front.
-105 is full of plastic parts and pieces, looks like crap IMHO
-Shifting and adjusting the shifting is a crap shoot. (yes, I've had a pro/race bike shop try and tune it up a few times)
-The front mech has about 1mm of "tuning", one tiny turn of the screw and things are rubbing, one tiny turn in the other direction and no shift...
-The rear mech is finicky as well, very sensitive to every minor adjustment, and easily comes out of adjustment.
-Shifts are slower, not as crisp.
22 year old Ultegra - better than 1 year old 105.
Likes For Jughed:
Quoted: 4420 Post(s)
Liked 4,873 Times
I never had any issues with 11-speed 105 and couldn’t tell the difference between 11-speed 105 and Ultegra. It’s too long since I ran 9-speed Ultegra or DA to make a direct comparison, but I don’t recall any problems or feeling any different about it. I had one bike with 9-speed Ultegra and one with 9-speed DA and couldn’t tell the difference between those either.
One thing that annoys me slightly on 11-speed 105 is the rattly sounding brifters when riding on chip seal roads. I can’t remember that on the older groups, but it’s been a long time.
I can say that I do prefer 12-speed SRAM AXS to all of the above. The game has moved on beyond cables.
Likes For PeteHski:
Quoted: 570 Post(s)
Liked 773 Times
Yep, another good point - the rattling brifters.
I'm riding these two groupsets side by side right now - the old stuff is just better.
Likes For Jughed:
Quoted: 2490 Post(s)
Liked 2,960 Times
My Reynolds 853 bike with 9-speed Ultegra is quietly rusting away in the basement. My Ultegra 10-speed STI levers are sitting in a box somewhere, only because I rarely throw anything out.
Got sick of having to (attempt to) nurse them back to health by giving them messy baths in WD-40 and such. Hats off to Shimano's engineers for their ability to design something nearly as complicated as the innards of a Palek Philippe wristwatch, but I like those parts to meet me at least half-way. If I perform maintenance on them reasonably regularly, I expect my bike parts, including shifters, to work until they wear out. Having to give my shifters saunas and facials does not constitute reasonable maintenance.
So my one drop bar bike that remains in the rotation now has a Microshift setup. No finessing required to go from gear to gear. Assertive clicks, always positive engagement. No more hoping the Ultegra shifters consent to work the way they're supposed to this time. They're gone, and they're going to stay gone.
Likes For Trakhak:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,438 Times
IME: It is, aside from fiddly set up, it is. Faster, more accurate, and smoother; and consistent with little to no adjustments once set up. And, the rim brake calipers of the 7000 are much better, but clearance is limited. As to aesthetics, "apples to oranges", and "eyes of the beholder adages". I like 6500 just fine, still have a partial shift set, but the shifters are not in use. Both derailleurs are matched with 6400 bar ends set in friction mode, with 46/36 and 11/34 11 speed cassette. I have no DA experience.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Other than the finish, I can’t tell any difference in the performance between my 9-speed ultegra stuff and my 10/11 speed 105 stuff.
I mean the lever feel when it shifts is a little classier (less plasticy) on the Ultegra, but zero difference in how it shifts.
Quoted: 242 Post(s)
Liked 456 Times
I too am sick and tired of finnicky shifting, always having to adjust the derailleurs, sticky shifters, etc.
I've gone back to 5 speed down tube mounted friction shifters on my Aethos. It took some work to attach them but zip ties are awesome stuff. No longer do I hear the chain rubbing, no worries about getting the derailleur adjustment 'just right', no more worries about the shifter cables breaking off inside the shifters or the shifters getting dry and sticky inside.
LOL
I didn't do any of the above.
My Aethos ran Ultegra 11 speed mechanical for a year and before the Aethos the kit was on a different frame for maybe 2 years. During that time the only annoyance I had is the pressure required to shift the small chain ring onto the large. I'm a small person, 5'4", with small hands and it takes a bit more effort than I prefer and that is even using the 'easy to shift' front derailleur. But it worked every time without fail, as did the rear derailleur. The only time I had to make tension adjustments was when the tension lessened requiring a small change to get it back where it needed to be.
Yes it is a bit more difficult but that is because of all the gears jammed onto the rear end. The spacing is closer requiring a more precise adjustment and more patience and skill when making the adjustment. Yes the chain can be a bit more noisy...again because of the spacing...but a waxed chain is almost soundless hehehe.
The fewer the gears in the back the easier it is to adjust the derailleur as there is more room for less than precise adjustment.
Considering I started on 5 speed down tube friction shifters and using, repairing and servicing them since the mid '80's and still working as a wrench today I will say it is far easier to work on 8-9 and 10 speed kit as there is just more forgiveness in spacing and fewer parts in the shifters.
To change track just a bit. I have been riding on Di2 12 speed 105 for nearly a year and love it love it love it. It was easy to set up and adjust and since the first adjustment has not needed it again. I've also just finished a build on a SL8 SWorks Tarmac with a full 12 speed Di2 Dura Ace grouppo and in all honesty I don't see or feel a difference between the two. My 105 works just as well as the Dura Ace...yes the 105 is heavier and maybe isn't as 'svelte' looking but considering I don't look at the kit when riding and the cost savings I'll take the 105 any time and every time. It was also a real pain in the ass mounting the battery in the SL8 seat tube. It mounts in a special holder which clips onto the seat post thus sitting around 5-6" below the seat post in the seat tube. The seat tube water bottle boss intrudes into the seat post and prevents the seat post/battery from going deeper. Not only is cutting the seat post required for the average rider...not crazy high...but the holes have to be drilled into the seat post in the correct placing to hold the clip that holds the battery in place...glad I have a drill press in the shop...it was an easy chore but another chore and measuring many times before cutting...twice...because I was a bit nervous and did a first cut as a test to make sure there were no problems...second cut was where it needed to be and the seat post/battery sits in the seat tube correctly with a tiny bit of room to spare.
As they get more fiddly, suspect like F1, etc. vehicles, extra space is lost and more precise fits, measuring, cutting, etc. becomes the norm. It wasn't hard it just required more thought and measuring before cutting and installing.
LOL
Likes For Kai Winters:
Likes For wheelreason:
Quoted: 380 Post(s)
Liked 541 Times
I have early 2000's 105 9 speed on two bikes. Have had them both for several years. No problems at all with either one. I've been tempted to upgrade a couple times but the if it ain't broke don't fix it thing keeps getting in the way
Quoted: 6199 Post(s)
Liked 4,816 Times
My 105 5800 shifted every bit as good as it's Ultegra equivalent at the time. The only real difference was weight. It was quite a bit heavier. Never had any of the issues others are complaining about as far as loose and rattling shifters. I think there is a lot of reminiscing for the old days and remembering the stuff as better when it wasn't really. Sure it may have been beefier made in places where it didn't really need to be.
I go to car shows and listen to all the spectators say how much better cars were built back in the day. All I remember about cars back in the day was that I had to work on mine every other weekend. New cars I've had seldom see a shop.
Likes For Iride01:
Liked 4,873 Times
No doubt you are right in this instance. But it is not normal for modern 105 to need constant mech adjustment. Mine was set and forget. I find that shift quality is far more dependent on drivetrain cleanliness and wear than anything else.
Quoted: 2976 Post(s)
Liked 1,182 Times
I have 105 on two road bikes and they both work flawlessly.
Likes For prj71:
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 220 Post(s)
Liked 861 Times
I don't own a bike with modern 105, but have an older Cannondale with 9 speed Dura Ace and 2 Canyons with Ultegra 6800 and 8000 mechanical 11 speed. Both 11 speeds require less pressure on the lever and less throw, especially the 8000. Also the larger hoods on the disc brake 8000 are much appreciated.
Quoted: 570 Post(s)
Liked 773 Times
Aesthetics/looks - personal opinion. Functionality is what it is.
My bikes are very well maintained/cleaned/lubed - the 105 front mech is slow to shift and as stated above - takes more force to shift. The fine adjustment between gears is lacking, and getting the shifting to stay consistent over the past 10k miles has been hit or miss. The rear mech is never exactly right - even when coming back from the bike shop - and once it is right, it won't stay that way... and yes, everything has been checked.
Aesthetics - the old stuff his polished and shiny, the on the 105 is dull, bland and just flat wearing off. The newer cranks look like poo.
Likes For Jughed:
Quoted: 3957 Post(s)
Liked 7,310 Times
Originally Posted by Jughed
... not pining for the old days, this isn't a get off my lawn type post.
No, it's a "they just don't make things the way they used to" post.
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
The best-shifting Shimano group was 10-speed Dura Ace, last generation with the shifter cables exiting the side of the lever (7800, I think)...IMO, YMMV.
Quoted: 570 Post(s)
Liked 773 Times
I'm just calling things like I see it.
Sunshine
Quoted: 10970 Post(s)
Liked 7,497 Times
- 11sp Ultegra mechanical brake road bike
- 11sp 105 mechanical brake road bike
- 11sp Ultegra mechanical road bike
- 11sp 105 hydraulic gravel bike with an Ultegra RX RD.
I cant tell any difference between the Ultegra and 105 mechanical. Like no difference at all. They all set up the same- 11sp Ultegra and 11sp 105 have the same FD design and the RDs set up the same way. They all shift exactly as I want- which is I move the lever and the chain moves.
The only difference I can feel on the 105 hydraulic is the hood shape is different. Functionally though, the shifting is identical to my 11sp Ultegra and 11sp 105.
I used to have 9sp Ultegra on a bike- It was a light touch to shift and that was due to the cable routing vs it being 'higher quality'. The same light touch is on my kid's 9sp Tiagra shifters and my other kid's 9sp 105 shifters that also have externally routed shift cables.
I do not long for my old 9sp Ultegra drivetrain. It was fine, but there is nothing about it that I miss when I compare it to my current drivetrains.
Current 105 drivetrains have easy cable setup and adjustment, once you learn how. And in practice, the FD can always move to not scrape against the chain. If there is rub on the FD, the small trim click eliminates the rub. Again though, the key part of this is setting it up correctly.
***I will say that I have Praxis cranks of 3 of the bikes above, and a Shimano 5 arm HT2 crank from 2016 on the other bike. So no new modern Shimano cranks. Just mentioning this as you complained about look and paint wear for the crank.
Liked 4,873 Times
Quoted: 18424 Post(s)
Liked 15,582 Times
Likes For indyfabz:
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
Well, tbh, Shimano's stuff only got uglier after 7410, but I appreciate the extra gears and the hydraulic disc brakes on my R7000 equipped bike, and the shifting is pretty close to 7800. It took a little more time to set up the FD, but once set it has kept working perfectly since.
I would say, though, that the combination of ST-7400 or ST-7800 STIs with the FD-7410 front derailleur works so well I'm not sure why they changed anything. I've never experienced anything but immediate, silent shifting with them.
Ergonomically, I like the R7020 and R8000 STIs better than 7800, and I like that better than 7410. More comfortable to ride the hoods for longer, and easier shifting and braking in the drops. But it's not night and day, either.
Liked 4,816 Times
So why you are having a completely different experience is either you got a bad set or that there is something wrong with the installation that you just aren't realizing. Or on the other end, I must have purchased a perfect example of what 105 5800 should be. I tend to doubt the latter possibility was reserved only for me. So I think your experience is the outlier data.
