Climbing
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6768 Post(s)
Liked 5,487 Times
Definitely the sit and spin.
Quoted: 550 Post(s)
Liked 325 Times
Spinning also produces less fatigue.
Consider kicking off a 418 mile supported tour with a 6000' climb including a 20 mile, 4700' stretch averaging 4.5% and reaching 6%.
Ending the day with extra Cliff bars isn't going to win you anything, but having the legs left to finish the day quickly will get you a prime camping spot with no line for a hot shower and still feeling good tomorrow will make the following 330 miles and 24,000 feet much more pleasant.
Blissketeer
Seated high cadence spinning punctuated by heart pumping bouts of pedaling out of the saddle at high cadence. Standing and pedaling a "too high" gear and you diminish efficiency.
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Sitting and spinning uses less energy than standing up and pushing larger gear, That does not mean you should not stand up at all. On a long climb, it is a not a bad idea every so often to shift up a gear or two and stand up foir a little bit, then sit down, shift back down, and resume your regular pace. This changes the muscles you are using a little bit and lets the one used when sitting to rest a bit.
This all assumes it is a "rhythm" climb, one on which you can fairly easily keep up a reasonable seated cadence for an extended period. On a steeper "power" climb, you do what ya gotta do to get - or what your legs and lungs can tolerate.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Sitting and spinning is more efficient. Often I ride with a group that's faster than I am. That's when the extra energy required by standing is especially noticeable. If I'm already struggling to hold the pace, the extra energy consumed by standing will just slay me.
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
If you meant your question literally, then yes, as the others have stated, sitting and spinning is the answer. But besides "getting to the top," there can be as many preferred outcomes to climbing a hill as there are climbers. Some want the most energy efficiency, some want to get there the fastest, some want some combination of the two, driven by what they perceive their energy needs and time requirements are for the rest of the ride.
