2012 Madone broken front (left) shifter
I own (obviously) a 2012 Trek Madone 5.2 compact. The front brake/shifter assembly needs to be replaced (it will not shift from the big ring to the small ring anymore). My LBS, whom I bought the bike from new, cannot locate a replacement assembly for me (they say because of the age of the component.........). I'm sure with a bit of research, I can locate one on the interweb somewhere. The original spec on the shifter (from Trek's archives), says it is a Shimano Ultegra STI, 10 speed.
Any additional information that can be offered to help locating one would be greatly appreciated!!
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Look under the hood on the lever for a model number like st-6700
Did you try the shimano sti WD40 flush first?
Here is a compatibility chart.
https://productinfo.shimano.com/#/co...453&acid=C-455
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
For Ultegra 10 speed the models are 6600 for exposed cables and 6700 for under the tape cables. Current 10 speed Tiagra is weird and not compatible. Lots of folks are happy with Microshift as replacements. https://www.microshift.com/en/product/sb-r402k/
I have a lot of $$$ into this bike and want to keep it as close to the same.
Thanks again for your (and everyone's) help.
I'm going to pick up the bike today. I told them to fix the front derailleur to the big ring so I can ride it while I research a solution.
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
Then you already have your answer with the Shimano shifters already mentioned. Dura-Ace would be the only possible upgrade provided the cable pull for 10 speed is the same as Ultegra; other than Microshift, going to another brand will get expensive as it would require new derailleurs of the same brand (generally).
If it were my bike I'd either replace just the left shifter with an exact, used replacement or upgrade the drivetrain to 11 or 12 speeds. Shifters are the largest cost in the drivetrain.
I kinda like SRAM doubletap road drivetrains, although they've become rather uncommon OEM for everything but 1x bikes with disc brakes. They are entirely incompatible with Shimano rear derailleurs so take that into account.
You can use a SRAM 10-speed left shifter with Shimano 10-speed era front derailleurs. It was a pretty common thing to do when people were unhappy with the performance of SRAM front derailleurs, the Red one in particular. I did it myself for about a year on one of my bikes. It worked. Leonard Zinn wrote an article about it at one point, if you want to look it up and get into all the details.
Anyway, it's an option. You probably would be able to pick up a left SRAM 10 speed shifter pretty easily on eBay. The hoods won't match, but I can't see the shifting action giving you problems.
Thanks for everyone's opinions/ideas. I did my research on the internet and decided on changing the shifters and derailleurs to SRAM Red. They still offer these components in a 10-speed. I'm excited as this seems to be a bit of an upgrade to the Ultegra components.
Quoted: 1608 Post(s)
Liked 2,216 Times
One of the reasons I like Campagnolo. Rebuildable assemblies with most parts still available. Just rebuilt 15 year old Ergos for les than $50.
Likes For SJX426:
Quoted: 550 Post(s)
Liked 325 Times
While the more durable Ultrashift levers do not (shifting like I have ADHD, I got 25,000 miles before breaking a spring) Campagnolo discontinued small parts sales for them mid-year in 2009 when they were introduced.
You can only buy complete shift mechanisms for ~$80.
While suboptimal that still beats a whole lever that may have been discontinued years ago.
Likes For Drew Eckhardt:
Liked 2,216 Times
Yeah, although the G-spring levers require frequent rebuilds.
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
All these threads talking about the only solution for Shimano being a thorough dousing with WD-40 and a prayer... Not the experience I would be looking for. Plus, the bike next to my GF's on our building's bike rack is a nearly new Bianchi with Ultegra (looks like it's been ridden the half mile from the store to our building, and never again). I took a good look at the levers and they certainly don't scream quality to me. Plus, they have exposed springs and internals on the underside that are disconcerting as well.
Likewise, $80 for a brand new shifter every 25K miles is OK in my book.
Quoted: 550 Post(s)
Liked 325 Times
(gfk velo strips new shifters for parts which they sell separately, and Peter Chisholm proprietor of Vecchio's Bicicletteria in Boulder, CO at least used to do that)
Original 2009 Campagnolo spares catalog
Revised 2009 spares catalog without small parts.
Quoted: 114 Post(s)
Liked 119 Times
https://www.youtube.com/watch?v=yzLxyrVQ_00
Quoted: 943 Post(s)
Liked 172 Times
Unfortunately, small parts like the the EC-SR037 front paddle return spring for Ultrashift levers with a design 11 years newer are not available* because Campagnolo stopped small part sales for the new 2009 shifters a few months into 2009. They discontinued the rebuild packs shortly afterwards but offered the cable takeup bushings EC-SR060/EC-SR061.
Quoted: 550 Post(s)
Liked 325 Times
Quoted: 943 Post(s)
Liked 172 Times
There's no compatibility per Graeme gfk_velo who is the head UK Campagnolo tech.
