Tire rotation direction Surly Knard
I just bought a 2020 Surly Straggler off CL. I noticed that the tire rotation arrows point to the back of the bike when rotated to the top of either tire. Were these tires installed backwards?
Steve
Steve
Point towards the force.. stopping is one way accelerating is the other.... which matters most for you?
Generically it does not matter ,
Quoted: 6194 Post(s)
Liked 4,810 Times
It probably only matters if you use the tires in conditions that keep them at the edge of their design limits for operation. If you just ride dry dirt and/or smooth pavement at the speeds of the typical amateur, then no big deal.
But it's an easy fix if it bothers you.
Likes For tyrion:
They may not channel water away properly if they rotate in the wrong direction. The arrow should point down in the front. Not a problem if you are a casual rider.
Likes For Davespix:
Quoted: 668 Post(s)
Liked 529 Times
According to Swalbe the direction arrows really only matter for treaded tires.
https://www.schwalbe.com/en/profil
Some tread profiles grip better in one direction than the other, some actually mount differently on the front (grip during braking) vs back (grip during pedaling). Smooth tread tires it doesn't matter, but Swalbe says they add the rotation arrows for "aesthetic considerations"
Quoted: 1944 Post(s)
Liked 2,164 Times
Depending on the tread design, some people will reverse the rear to get better grip climbing on loose dirt. It is usually more desirable to have the front correct for better rolling.
John
John
I got a reply back from Surly customer support. They say:
" the Knard’s tread pattern is not directional, so either way, there would be no disadvantage to running the tires “backwards”."
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I agree that the Surly Knard's tread does not appear directional. I wonder why they'd go to the trouble to mold in rotation arrows on this tire.
The Continental Speed Ride is similar. The tread appears to be non-directional and, yet, there's a rotation arrow on one of the sidewalls of each tire. Weird!
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Really Old Senior Member
One direction for rear traction and the other for front braking.
Likes For Bill Kapaun:
That doesn't matter for bike tires. The rotation arrows are more for traction and rolling resistance. The shape of a bike tire inherently channels water.
Quoted: 4806 Post(s)
Liked 3,929 Times
Some tread profiles grip better in one direction than the other, some actually mount differently on the front (grip during braking) vs back (grip during pedaling). Smooth tread tires it doesn't matter, but Swalbe says they add the rotation arrows or "aesthetic considerations"
For years I ran my label non-drive side since I always lean the drive side against walls. Never noticed an issue nor saw any change when I switched to labels on the drive side. Not with Vittorias (pretty symmetrical tread) or Paselas (which have a V shaped tread so it should make a difference).
Ben
Liked 2,164 Times
John
Quoted: 980 Post(s)
Liked 582 Times
If the tread pattern contains a "chevron" aspect, forward rotation has the "V" of the chevrons contacting the pavement with the point of the "V". This in theory channels the water from the center of the tire to the outer edge, and "backward" rotation would do the opposite.
But as noted, it doesn't really matter for bikes, as they cannot hydroplane according to Sheldon Brown.
I get to watch Trek/Bontrager product knowlege/training videos. They claim that the direction of the casing layers below the tread determine the optimal rolling direction.
Quoted: 4560 Post(s)
Liked 2,802 Times
Yeah, occasionally I've mounted Continental SpeedRide (file tread and vestigial side knobbies, non-directional), Sport Contact II (shallow file tread, non-directional) and Ultra Sport II (slicks with cosmetic treadlike arrow doodads along the shoulders) "backward." I usually don't worry about it.
Some tires, like the Ultra Sport II and GP Classic, have arrow shaped shallow tread that helps indicate the preferred direction of travel. The GP Classic has a rotation marker on the sidewall but it's hard to see so I go by the direction of the chevron hashmarks.
