Discussion: Summer wicking base layer ...
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
The things I think about on a solo century when it's 90+F and over 60% humidity: Does a wicking base layer help with a high quality jersey? Or does a quality jersey do enough wicking to make the base layer superfluous?
For reference, I ride Podiumwear Gold kit, they promote this as a wicking material ... and Craft base layer
Over the years I have found cycling specific clothes to be completely useless. I ride with the same clothes I use for cross-fit. Better made, cooler, better styling and much less expensive. So in answer to your question, the stuff for the gym is better at keeping you cool.
hanging that camelback over the large evaporative surface of your skin will undo what ever miracle properties the textile engineers may have created..
Likes For fietsbob:
meh
Liked 1,013 Times
Likes For fietsbob:
Quoted: 325 Post(s)
Liked 109 Times
Whether or not the jersey by itself will help with sweat wicking depends on the manufacturer. Some manufacturers optimize their jerseys for aero, print adhesion, or other factors before they consider sweat wicking. Then, those same companies will make a base layer to supplement their jerseys' sweat wicking & evaporation capabilities. In those cases, they get to sell you two pieces of kit instead of just one; interpret that however you want.
Other manufacturers put sweat wicking & evaporation as a higher priority, and their jerseys will be perfectly fine to wear without a base layer. IME, I have not seen any reliable way to determine if a given jersey will work better with a base layer, as most companies seem to offer a base layer regardless of the claims they make about their jerseys. I prefer a base layer because I'm more comfortable wearing one than not. YMMV.
Likes For BoraxKid:
I had seen a daypack with a frame to tension the mesh and have a physical air space separation. with the load carrying bag ..
My last long tour I got a wicking mesh singlet, and added a sewn on tunnel pocket across the lower back
and had an Ortlieb made Money bag for my passport Debit Card, * return ticket Etc.. in that sleeve..
*no cash advance charges even abroad, in other currencies, unlike a credit card..
Quoted: 1221 Post(s)
Liked 627 Times
I don't think I've seen any pros in races like the tour of France wear any wicking base layers, and it gets silly hot. Also they'll start low and climb into the mountains, often you'll see their jerseys open with no base layer. Then immediately after the race they'll get wrapped in warm attire. You'd think this would be a good time to wear that extra under layer but they don't, so that's my thoughts.
For me I'll forgo the jersey and just wear under armour long sleeve shirts, especially in the conditions you describe.
Quoted: 325 Post(s)
Liked 109 Times
Anyway, it sounds like you have some selection bias clouding your judgement here. There are definitely pros that wear base layers in hot weather, and there are pros that don't. It's bad practice to over-extrapolate your observations, so be careful with that.
Likes For BoraxKid:
Quoted: 4791 Post(s)
Liked 3,918 Times
There are better jerseys and lesser jerseys fro hot weather. ne warm ride will tell me where any jersey lands on that scale.
Uner the jersye I wear:
Max temp 75 (or cooler temps expected on downhills, later, etc. - the wonderful Patagonia T-shirts (as nice as silk against the skin)
Mat temp 85 (90 with cooler expected) - the old Performance mesh tank top
Above 85-90, just the jersey.
For me, being cold is such an issue that I often wear the T-shirt or tank top in warmer than I outlined above. Not a big issue. With good undergarments, it is rarely a huge deal if I get it 'wrong".
Now, good undergarments make a huge difference with the older and poorer quality fabric jerseys. My old race jersey is synthetic (I was a bike racer/bike shop employee spending my excess cash on silk sewups) and synthetic dried far faster in humid New England). I still have it. Custom fit and very well made but long before any "super" fabrics (except wool and silk). I can still wear it and do but I would never wear it without a wicking T. (Back then I wore cotton fishnet Ts. They worked surprisingly well..)
Ben
Ben
Liked 627 Times
I've spotted plenty of pros wearing summer base layers under their jerseys at both the tours of France and Spain. That's actually how I discovered summer base layers in the first place: I saw a pro giving a post-ride interview at the Tour de France with his jersey open, and I noticed he was wearing some kind of mesh layer under his jersey. Then I heard the GCN boys mention the importance of a good base layer and how it can help cool you down, and they're pretty much all ex-pros. One of them even rode for the Rapha test team, I believe.
I'm pretty sure one of the presenters rode for the Cervelo test team right? Can't quite remember which one it was ... maybe it was James? Oh I bet it was Jeremy Powers!
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
One layer against my skin is the most I can handle in the summer Sun, heat and humidity. That layer will be a synthetic moisture Wicking material. Usually some sort of polyester/nylon/spandex blend.
With a couple exceptions I think this is superior to my bare skin. Bare skin against the summer sun can be brutal, I cant always keep enough sun block on and it can block your natural sweating ability from your skin’s pores. Shade through clothing I think is superior. I use DaBrim visor over my helmet some days.
Quoted: 6944 Post(s)
Liked 10,944 Times
I've tried thin summer baselayers under SS jerseys, and found it to be a wash - they might aid wicking a bit, but add to heat retention.
On the hottest days, I wear one of these. It's the best jersey I've found for such conditions. And unlike many ultra-thin jerseys, its pockets will actually hold your cargo without going all floppy.
