cold mornings bothering my knees
Bikes: my bikes: Old: 1965 Schwinn 10 speed, 72 Monshee 12 speed, 77 Norco 12 speed, 95 Trek 850, two Specialized Crosstrails, 2016 Specialized carbon Sirrus. New 2020 Trek FX1
Quoted: 54 Post(s)
Liked 36 Times
In my neck of the woods the mornings have gotten a bit on the chilly side and yesterday my knees were bothering me after my morning commute. Any suggestions? My favorite LBS has no leg or knee warmers in my size, L or XL... Lots of stuff for the smaller rider but not for the bigger guys... The knees were bothering me enough that I may not want to ride in the mornings until I can find some knee warmers. It isn't a fit issue as nothing was wrong before the temps lowered in the am...
thanks gang...
thanks gang...
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,590 Times
Tights?
Quoted: 1324 Post(s)
Liked 927 Times
By a pair of hockey socks and cut off the foot section. The high tube part will work great as a leg warmer. They'll last a long time if you get someone to sew a band of elastic around the bottom where the cut was made. Ah, I see a lot of them don't have feet. Something like these should work.
https://www.boathouse.com/products/h...?basketIndex=0
Cheers
Cheers
Likes For Miele Man:
Have a look around at what's available through the UK. Road.cc does lots of clothing etc. reviews. Have seen a couple of knee 'warmers' which were more like wind-stopper material which is really what you want.
I had a below-the-knee Castelli bib which had a bit of fleece in them, for cooler temps. Found though, just having that fleece didn't stop the wind that great (knees were still getting cold and locking-up a bit).
Then I came across another model they did which actually had more of a wind-stopper fabric around the knee. That did the trick nicely. Can't seem to find that same model with their latest offerings though.
If you find something that works into the 30 and 40 degree area, please let us know! I am unable to ride in temps lower than 50 degrees regardless of the leg protection I have on.
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 387 Post(s)
Liked 323 Times
Knee warmers are a thing. I have some for the same reason as the OP... when it gets cold, my knees don't like it. Knee warmers are easy to pull off which is important as Fall days usually start-out cold but can warm-up pretty quickly.
For colder weather riding, I've found fleece lined riding gear to be wonderful. With long sleeves and long tights that are fleeced lined, I can comfortably ride to 45 degrees F (my cut-off point) without any other layers.
Quoted: 54 Post(s)
Liked 36 Times
Hey gang, this afternoon I found a popular LBS that had several brands of knee warmers in my size, I bought a pair of 'Sugoi Zap' knee warmers and will pick them up tomorrow afternoon - will let you know how well they work as soon as I've tried them out.
cheers,
Lorne
cheers,
Lorne
Quoted: 1074 Post(s)
Liked 295 Times
My favourites were long an older version of these https://www.mcdavid.eu/product/volleyball-knee-pads/
Guaranteed wind proof and impervious to rain.
For less severe weather I use these https://houdinisportswear.com/de-de/...olor=328234900
Go to a Goodwill or other thrift shop, but a couple large sweaters (wool or synthetic), cut the sleeves off and use as knee warmers.
Longbikes Slipstream
Quoted: 2603 Post(s)
Liked 1,926 Times
I'm guessing you're got something to keep your ears warm, as well as a jacket or heavy wool jersey, and gloves? You can lose a lot o body heat from your head and torso, and cold hands aren't comfortable. For my riding below 40° or so, tights are better than knee warmers. Keep riding and soon you'll have a whole new cool weather wardrobe!
Quoted: 1068 Post(s)
Liked 781 Times
cheers,
Lorne
cheers,
Lorne
https://www.bicycling.com/training/a...w-about-embro/
thanks gang...
thanks gang...
Sugar and salt add more inflammation on joints just saying.
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
I picked up a couple pairs of cheap Baleaf running tights that I wear over either summer-weight cycle shorts or cycle tights.
They were truly wonderful last winter and early spring; true, one could just protect the knees, but before I got them I had a ride where I ended up wearing my zip-up warmth layer as a sort of skirt to keep the wind off something else, and the extra tights layer accomplishes that, too.
Plus having an extra layer of fabric compression seems to help with saddle-area duration tolernace, too.
And the best part is if you wear them over legit cycliing stuff you can remove them - eg, my return ride on an early March overnight where I decided mid-morning it had warmed up enough, sat down on the end of a Delware camelback bridge, off came the shoes, off came the tights, shoes went back on, tights stuffed in with gear and off I rode in summer rather than winter mode.
