bottom bracket bearings, leave the cages out?
Old 04-27-14, 07:16 AM
Gary3
Quoted: 13 Post(s)
Liked 2 Times in 1 Post
Sheldon Brown states that uncaged bearings work better, I'm cleaning up a set, should I leave the cages out on reassembly?
Gary3 is offline
Old 04-27-14, 07:23 AM
hueyhoolihan
Quoted: 86 Post(s)
Liked 4 Times in 4 Posts
if you leave the cages out, you'll probably have to add a bearing or two, but for the BB i'd use them. there's nothing worse than losing one down the chainstay or up the downtube and then having to open 'er up again and get it out when it starts rattling. not to mention how awkward it can be just getting them in there in the first place.
i've found cartridge bearing BB's to be a godsend, on the whole.
hueyhoolihan is offline
Likes For hueyhoolihan:
Old 04-27-14, 07:30 AM
Gary3
Quoted: 13 Post(s)
same number of bearings for sure, the bearings nearly touch each other in the cage. the drive side was easy, ill try the adjustable side, the grease should be tacky enough to get the bearings to stay in place while I turn the cup. thanks for the quick reply.
Gary3 is offline
Likes For Gary3:
Old 04-27-14, 07:39 AM
AnkleWork
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times in 83 Posts
It seems you missed the words "usually" and "if" in Sheldon's article. It also seems you seek permission more than advice.
In point of fact, full compliment caged bearings tend to have lower friction and longer life versus loose balls, ceteris paribus.
AnkleWork is offline
Old 04-27-14, 07:43 AM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
When I service bottom brackets I always replace the caged bearings with loose bearings... this adds a bearing and removes the cage which is more often a cause of problems than losing a bearing in the frame. I have seen many broken cages that have scored the races and seen many bikes where the cage was installed backwards and caused an improper fit.
If you keep your bearing grease in a cool place it will hold the bearings in place during assembly and when it gets hotter here I keep bearing grease in my shop fridge for this purpose.
You can clean and grease the drive side cup without removing it and unless you are all thumbs getting the bearings placed should not be that difficult.
The bearing support is better with eleven 1/4 inch bearings than it is with cartridge bearings, and a good quality loose ball bottom bracket will last tens of thousands of km with regular service and run smoother.
Sixty Fiver is offline
Likes For Sixty Fiver:
Old 04-27-14, 07:50 AM
Duane Behrens
Duane Behrens's Avatar
Bikes: Specialized Tarmac (carbon), Specialized Roubaix (carbon, wifey), Raleigh Super Course (my favorite), and 2 Centurion project bikes.
to "Sixty-Fiver:" I was reading the posts previous to yours, scratching my head and thinking, "What? You CAN'T add a bearing? What? Cartridge bearings run smoother than loose bearings? What? Loose bearings come loose and lodge in the FRAME? " WHAT?!
Then you came along to confirm what I already knew from my own experience. Whew. Thank you.
To the rest of you, this thread - up until the one from "Sixty-Fiver" - is to me mere confirmation that much of what you read on these boards is often not only wrong but, if followed to the letter, potentially dangerous.
Yikes.
Duane Behrens is offline
Old 04-27-14, 07:53 AM
Gary3
Quoted: 13 Post(s)
Well that clears it all up! The cages held eleven bearings, there is no way twelve will fit, if I should put the cages back in, I will take the time to do it.
Gary3 is offline
Old 04-27-14, 07:57 AM
rydabent
Quoted: 3352 Post(s)
Liked 1,056 Times in 635 Posts
I think bike mfg actually use cages because it makes assembly faster. And yes without the
cage there is usually room for an extra bearing. More balls to share the load, the stronger the bearing.
BTW if you leave out the cage, use all new bearings of the same size.
rydabent is offline
Old 04-27-14, 08:21 AM
AnkleWork
Bikes: old clunker
Quoted: 684 Post(s)
Originally Posted by Duane Behrens
. . . To the rest of you, this thread - up until the one from "Sixty-Fiver" - is to me mere confirmation that much of what you read on these boards is often not only wrong but, if followed to the letter, potentially dangerous.
Yikes.
Using caged bearings is potentially dangerous? How?
Old 04-27-14, 08:40 AM
Gary3
Quoted: 13 Post(s)
sixty fiver, eleven in the cages, and twelve if loose?
Gary3 is offline
Old 04-27-14, 08:46 AM
Sixty Fiver
Quoted: 67 Post(s)
Eleven loose bearings (1/4 inch).
It will look like you need one more but you won't be able to fit 12.
Old 04-27-14, 09:02 AM
Sixty Fiver
Quoted: 67 Post(s)
It makes assembly faster and cartridge bearings are relatively inexpensive to produce, there is no fine adjustment required either which is something that requires a human being at the production end or at the bike shop.
Using new bearings from the same lot ensures that they will be consistent in their grading... the numbers you see on bearings like grade 100 mean that the maximum variance is 0.0001 inches and these are considered semi precision while lower grade numbers indicates higher precision and less variance.
For cycling purposes a grade 100 ball bearing is fine although higher grade bearings tend to be better made with higher tolerances, proprietary finishing (often to reduce corrosion), and better materials which last longer. When I worked in the oilfield (manufacturing) we commonly used grade 40 bearings in custom assemblies and on some occasions we also used ceramic bearings where high temperatures and corrosion were an issue.
Ceramic bearings are pretty much useless on a bicycle when you factor in their cost... at about .75 each for grade 5 bearings doing up a bottom bracket would cost $16.50 and the races have to be as precise as the bearings to really make things work their best.
Grade 25 steel bearings cost about a nickel each.
Old 04-27-14, 09:09 AM
cny-bikeman
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Quoted: 486 Post(s)
Liked 11 Times in 11 Posts
To clarify further -
Most all loose ball BB's take 11 1/4 inch ball bearings. Some cages are full complement (11) some are fewer. Full complement cages prevent balls from interfering with each other but still have a full count to bear the load, besides easing assembly. So in my view that would be the best option. But lessened friction is silly to ponder over, main advantage to 11 balls is a bit smoother wear and longer life. Don't reuse balls, whether in a cage or not, and it's not possible to loose a ball bearing down a frame tube if they are all pointed upward from the shell when inserting the balls. Also, most mechanics insert the fixed cup balls into the grease from the right side while guiding it into place with the finger of the other hand.
cny-bikeman is offline
Old 09-09-20, 12:18 PM
viperocco
viperocco's Avatar
Bikes: 05 Fuji Outland Pro, Fuji cape may, Giant simple single, Peugeot Corbier, Miyata 215st
Quoted: 40 Post(s)
Liked 49 Times in 28 Posts
Fascinating, I am glad I read all the way till the end.
viperocco is offline
Old 09-09-20, 12:35 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Caged bearings typically are an assembly efficiency , but in some cases, like one piece cranks, the assembly requires them..
fietsbob is offline
Old 09-09-20, 08:07 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Liked 582 Times in 399 Posts
I did this when I rebuilt my old Motobecane. I fitted 11 balls nicely... a big improvement over the original caged bearings which had *7* per side.
sweeks is offline
Likes For sweeks:
Old 09-10-20, 08:01 AM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
My first job was in a bike shop in the early '90s. Sometimes I still wake up in a cold sweat thinking about the box of BB spindles of all different combinations of dimensions. The world became a brighter place when cartridge BBs became standard. Unless your crankset is some weird older asymmetrical thing, the best solution is to find a cartridge BB to replace the cup-and-cone assembly.
ClydeClydeson is offline
Old 09-10-20, 11:57 AM
Unca_Sam
The dropped
Unca_Sam's Avatar
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times in 696 Posts
I'm glad I noticed the date on this thread.
Watch out for the Zombie.
Unca_Sam is offline
Old 09-11-20, 09:28 AM
rydabent
Some indicate that if you use loose balls you may drop one or some how get them in the frame. I use very heavy grease in the BB and headset. The heavy grease keeps them in place, and can with stand the extreme loads both of those bearing are exposed to. The "extra drag" some worry about is not a factor.
rydabent is offline
Old 09-12-20, 06:58 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
I never respond to zombie threads.
Moe Zhoost is offline
EnjoyinTheRide
Bicycle Mechanics
6
05-22-17 05:43 PM
Regulatori
Singlespeed & Fixed Gear
12
11-04-15 01:31 PM
mtalbert
Bicycle Mechanics
6
05-09-15 01:12 PM
Ronno6
Bicycle Mechanics
11
12-15-13 04:46 PM
Valbrona
Bicycle Mechanics
2
05-05-13 08:53 AM
