Tubeless road experiences
I am resurrecting this dead horse…I have been riding Campy Bora tubular wheels for three years with Veloflex Vlaanderen 28 tires. For me at 175 lbs 98 rear and 95 front is the sweet spot. I have a 2020 Super Six which is a very fun responsive bike but the responsiveness comes with stiffness. I have thought about tubeless road wheels to ( theoretically ) ride lower pressure to take some harshness out of the ride without affecting rolling resistance.
Any experiences similar to mine would be appreciated.
Fat n slow
Quoted: 3259 Post(s)
Liked 2,086 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
If you're primarily after a more supple ride and lower pressures, the first thing I'd do is lower your pressure - you're running a little high for 28s and your weight, IMO. Start there, then reassess.
As far tubeless, I think that it's a great solution if you get a fair number of flats. If I didn't need the benefit of flat protection, though, I don't think that I'd take on the extra maintenance just to lower pressure a handful of PSI.
Likes For WhyFi:
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
You're definitely high- just like I used to be. In fact, I was a bit higher at times. I am also 175 lbs. On regular tubed tires that measure 28 and rims with internal width of 19, I run 75F and 85R but I also sit more upright. I am still high so I was trying 75/80 which is smoother. Since I run tubeless front-only now, I have gone to 70/78. I'll be going tubeless in June when Zipp 303 comes in and will likely run 70/75 on true-to-size 28s. That 70-80 range seems to be just as fast and much smoother. Since my frame is limited to 28 max tire size, I may not go much lower. If I could run 30-32, I'd get into the 60s. That will be the next bike.
I have experimented with tire pressure quite a bit. The pressures I quoted were the results of my experimentation. Low 90’s results in a decidedly more sluggish ride. I go as low as possible before sluggish sets in. This is what interests me in the tubeless route.
Quoted: 464 Post(s)
Liked 182 Times
After a certain point and depending on road surfaces, thy will be more sluggish. However, I'm faster at 80 than I was at 90-95 on most of my paths/roads. I have a power meter and combine that with HR, I can determine my speed/effort on segments. With my tire size, rim, and road surfaces, I bet I'd be slower at 60-65 but not sure by how much. I have to try diff experiments on non-windy days.
pan y agua
Quoted: 1456 Post(s)
Liked 733 Times
If you find tubulars to be too stiff, you’re definitely running to high of pressure. One advantage of tubulars is that you can run lower pressures without pinch flatting.
. Having ridden tubulars for years, and road tubeless for the last two years I can say with confidence that tubulars are still the most comfortable riding tires available.
Tubeless tires are arguably easier to deal with and less prone to flat, and can be more comfortable at the right pressure than clinchers, but they are not going to ride better than tubulars
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 733 Times
For years people road tires that by today’s standards were way overinflated. A rock hard tire feels fast and responsive as it bounces over tiny imperfections. But that bouncing adds to rolling resistance and is actually slower.
Likes For merlinextraligh:
What you describe as sluggish, may not actually be slower.
Likes For ratell:
Quoted: 464 Post(s)
Liked 182 Times
I think we (or some of us) were used to that bouncy fast feel. That did feel fast.
Liked 9,456 Times
If you're just talking about perception, a) mistake b) what makes you think that you'll find it any more satisfying to run tubeless at lower pressures?
Likes For WhyFi:
Bikes: SL8 Pro, TCR beater
Quoted: 994 Post(s)
Liked 588 Times
Quoted: 3959 Post(s)
Liked 7,347 Times
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4401 Post(s)
Liked 3,024 Times
Debatable. Guy on my ride this morning running tubeless road tires double flatted going over something this morning. Waiting for him to fiddle with his bacon bits or whatnot took freaking forever. I kept thinking "put some tubes in and let's be on our way."
Liked 9,456 Times
What about the times that he didn't flat, and you didn't notice, because it worked seamlessly? That's the problem with second-hand tubeless failure observation - by nature, you only note the failures and it very neatly feeds in to observation bias.
Likes For WhyFi:
Liked 3,024 Times
I do not keep statistics on the number of people on my rides running tubeless and the relative frequency of flats, but the frequency of tubeless flats is not negligible.. And once the tubelss guy gets a flat, it's an ever loving pain to deal with it.
No thanks.
Liked 9,456 Times
Oh, I know; I never proposed that. You can only look at relative frequency, which is why it's a trade-off that doesn't lend itself to casual, secondhand observation. Mine is way, way down from my tube days.
Quoted: 18883 Post(s)
Liked 10,646 Times
I went from one flat per month on average to one per year. Same kind and amount of riding. I don't miss flats.
Likes For Seattle Forrest:
For that argument to work, you need to ride tyres with the exact same puncture protection or it might be just that limiting the amounts of flats, not the sealant. I moved form cheap training tyres with normal tubes to better protected tyres and light tubes and haven't had a single flat since. By your logic I might as well attribute not flatting to light tubes ;-) Not claiming sealant doesn't work at all, but lots of direct evidence it doesn't work very well and is (can be) a real faff to deal with when it doesn't. - Having to wait for roadies that insist on riding paper thin race day tyres every single training and flatting as a result, is just infuriating. Imo, worse than not bringing a spare tube, lazily relying on others. TL or Tubes, flats will happen if you do that.
Liked 9,456 Times
Super Modest
Quoted: 10972 Post(s)
Liked 4,628 Times
Yep. I got a rear tire cut that wouldn’t seal above 20-25#. It was 12 miles to home and I rode it fine. I’m >200#.
Keep the chain tight!
Advocatus Diaboli
Quoted: 4750 Post(s)
Liked 1,536 Times
Is this a positive story? Or are you saying if you ran tubes, you would have put one in and run at your normal pressure til you got home? What did you do with the tire after you got home (plug or bacon strip)?
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
My Domane came set up tubeless from the Trek store. 0 flats . My other bikes I would get 2-3 flats a year on the MUP and the tow path. Not world ending but still a flat to fix every few months. If and when I flat on my tubeless set up I will slap a tube in there to get it home and do whatever else after that. I carry a tube not bacon strips or plugs etc. Just seems like it would be faster and easier.
Love the tubeless set up BTW for the better ride. The flat protection is just a (big) perk.
