Want new rear wheel on Schwinn Discover Mens bike
Tire reads "(40-622) 700 X 38C" Rim is a SWIFT ARRIV and reads "700c/622"
I'm a big (300lbs) and, unfortunately, financially constrained biker. I broke spokes on the rear wheel and want something more durable. Maybe something with more spokes? What size rim/wheel should I look for and where should I go to get it? It is rim brake without quick release with 21 total gears (7 on the rear).
Thanks for you help
Thanks for you help
Really Old Senior Member
Being it's a 7 speed, we need to confirm the width between drop outs.
Remove the rear wheel and measure the inside spacing between the drops.
It should be 126, 130 or 135mm
Or about 4-15/16, 5-1/8 or 5-5/16".
It appears that's a 28 pair spoke wheel? You want 36 minimum at your weight. Maybe more if you ride rough roads or carry extra weight on the back.
Likely, it has a 7 speed Free Wheel rather than a cassette, but check. Cassette hubs are less prone to bend/break axles, so that's what I'd recommend, but you would also have to buy a cassette and have it installed.
See here for how to tell the diff-
Freewheel or Cassette?
Are there any brand/model#'s on the HUB?
Likes For Bill Kapaun:
Quoted: 4204 Post(s)
Liked 3,862 Times
I'll add to Bill's good reply in saying that the parts alone don't control the final product. The assembly (or the wheel build up) has a great inpart too. So most prebuilt, low cost, wheels see minimal attention to anything beyond being straight enough to look good at the point of sale. Some shops will spend a few minutes to further true an "over the counter wheel". A few might also check/correct/add lube to the hub bearings and see if more then minimal spoke tension is achievable.
Even with a well built/tensioned wheel with many spokes and a solid rim will fatigue as it goes through the many thousands of cycles of stress riding produces. A large/heavy rider/load will only quicken this. A rider who learns to pedal smoothly and "ride light" will find their bike to last a lot longer and work better the entire time then a rider who sits heavily in the saddle all the time and over uses their upper body to power the bike. Andy.
Bikes: '93 Trek 520, '98 Trek 1220, '01 C-dale T800
I weigh in at about 240lbs., and ride with loaded panniers: I wouldn't consider less than 36 spoke wheels.
Here's wheels I'm considering for my 1997-98 C-dale hybrid. It still has it's original 7 gears in the back, but I think it's time to upgrade to 8 or 9 with a new r. derailleur. It seems that decent 26" rim brake wheels are getting tougher to find.
from Tree Fort Bikes
rear = Freehub (cassette) Body Shimano/SRAM 8/9/10
https://www.treefortbikes.com/Qualit...n-Rim-26-135mm
front
https://www.treefortbikes.com/Qualit...in-Rim-Alex-26
From BIKEMAN
rear ( Cassette Body Type: Shimano/SRAM 8, 9, 10 Speed )
Bikeman Quality Wheels Alex DH19 Black / Shimano Deore Rear Wheel - 26", QR x 135mm, Black, 36h
front
Bikeman Quality Wheels Front Wheel Mountain Rim Alex 26" 100mm 36h DH19 Black / Shimano Deore Black / DT Stainless Steel Silver
From Universal Cycles =
Shimano LX/Velocity Dyad Rear Wheel - 26"
https://www.universalcycles.com/shop...s.php?id=84309
front
https://www.universalcycles.com/shop...s.php?id=84308
universal cycles wheel builders
https://www.universalcycles.com/wheelkit.php
SideLineSwap
https://sidelineswap.com/gear/bikes/...ack-heavy-duty
front
From BIKEMAN
front
front
SideLineSwap
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Is this your bike?
If so, it is using 24 spoke wheels that are paired - about the worst/weakest setup for a big person. You'll want a 36 spoke wheel with even spoke spacing.
As an aside, 700c is a number used in an old French wheelsizing system. It is still commonly used, although the international standard organisation (ISO) designation is 622, which is the diameter in mm of the "Bead Seat Diameter" of the rim. 700c means the same thing as ISO 622. All you need to know is that your bike uses 700c /ISO 622 rims. You want to duplicate that in your new wheels so that your brakes work without readjustment.
The 38 in the tire size is the approximate width of the tire. A 38mm tire will be happy in a rim that has an internal rim width somewhere around 19mm. You're probably ok with a rim width of 17 to 23mm. Bigger (22mm) would be very good. Check with the seller.
There are two designs for the rear cogs. There is a setup that allows these to spin backwards, but when you pedal, a ratchet with pawls engages to push you forward. The two designs are freewheel, the old system, in which the ratchet mechanism and all the cogs are assembled in a unit (the freewheel) and the freewheel is screwed on. The other system is more modern. It's called a freehub. In this system the ratchet is built into the wheel and you assemble the cogs (collectively called the "cassette") onto the wheel directly. This is called a freehub. For a 7 speed, I think that you're talking a freewheel, not a freehub. But you should make sure. You want to reuse the freewheel or the cassette to save money and you can't put a cassette onto a freewheel hub, nor a freewheel on a freehub wheel. Perhaps check with a bike shop? If you do, they may have a good alternative. Freehubs themselves vary between brands, so the bike shop or coop may be able to tell you the type of freehub you need. I think that its a Shimano.
So you need a 700c/622 rear wheel with an internal rim width of about 17-23mm, and either a freehub built in or that is threaded for a freewheel.
Some desirable things which may or may not be available in a budget wheel:
Stainless spokes are better than chromed steel (called UCP by some)
Butted spokes (with thinner cross-section in the center than at the ends) are better. Yes, even for big guys. Maybe especially for big guys.
If you have a freewheel wheel, a cheap alternative is:
https://www.amazon.com/Wheel-WEI-AS23X-Alloy-Silver-spokes/dp/B000AO3GES?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B000AO3GES
Chromed steel spokes, not stainless. But its 50 bucks, free delivery.
Bikes: Trek, Nishiki, Avalon, Diamondback, 6 Schwinns
I called schwinn customer service and they are sending me replacement wheels (complete minus freewheel) for under $40 ! The rear will be 36 spoke and the front 32 spoke. I don’t know why they are different but they are both more than 24s so I’m happy.
Likes For DanClay:
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Thread closed
Likes For Homebrew01:
