Spoke Poke Flats
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Spoke Poke Flats
I've been getting punctures on my commuter bike tubes that look like spoke pokes.
-I've got good rim tape on there - not Velox but similar.
-The rim tape looks intact and not deformed or shifted out of position
-There is no spoke poking through the rim tape
-The tube where the poke is, has a bulge deformation that looks like it did poke down into the spoke hole - one of them has two deformations for the same spoke area - like it shifted at some point; only one puncture though.
-The deformations and punctures are near the valve hole.
-The rims are really narrow and I've got 28mm tires on them.
-As my commuter, I do ride it over curbs and such, so an impact could be involved.
-It's happened to the front wheel twice and the rear once in the last few weeks.
-It's never interrupted a ride, it's always been that I notice the flats before starting a new ride.
So I guess the question is, can rim tape actually move and cause this kind of puncture and then move back so it looks like it's OK?
Or is there some other explanation?
Quoted: 7348 Post(s)
Liked 2,471 Times
This has happened to me, and I can't explain it.
It's MY mountain
Liked 2,981 Times
Once it was both wheels at the same time - fine one evening on the ride home and flat the next morning. I thought my wife was pranking me and just let the air out because 1) she MIGHT have been mad about something and 2) two garage flats at the same time just never happens.
Single wall Rear of my Brompton did this, It had a fused loop plastic rim strip,
so I cut a section of narrow rubber rim strip , joined around the valve hole with duct tape,
put the plastic rim strip back on over it and it was fine after that..
90 psi 349-35 tires..
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 4806 Post(s)
Liked 3,929 Times
Do the spokes protrude above the nipples? I'd eliminate that first (bolt cutters then a file, PIA I know) then consider going to Velox tape.
It's been decades since I used non-box rims but they were always with Velox and flush spokes and I don't recall ever seeing your issues.
Ben
Ben
It's MY mountain
Liked 2,981 Times
Very much like the photos in that thread; what the heck is that? Seems like the most likely fix is to put on a second layer of rim tape.
Quoted: 18377 Post(s)
Liked 4,512 Times
It actually makes some sense that you'd get hit by two hitting at once. You probably recently re-inflated both tires to a fairly high pressure.
I've heard that the rubber rim tape is bad for double walled rims as it tends to sink into the holes. I have some non-reinforced plastic tape that did that too, but it was permanently deformed.
I've moved away from the velox cloth tape, too thick. One bike, I put in veloplugs, then covered them with plain electrical tape (covered edges with off-center rims). So far, so good.
I've always assumed a wheel flexes when you hit a bump or jump a curb. If this is true, then that would partially explain why your spoke heads are pushing into your tubes. Why this isn't a more common problem is a big question, though.
Liked 4,512 Times
With single walled rims, one can file off the ends of long spokes.
With double walled rims, the spokes should be recessed a bit.
Any bump strong enough to bend a rim, say 1/4" likely is enough to do permanent damage to the rim. Keep in mind, the tire should take up most of the transient flex of the rim beyond simply the rider's static weight.
Tape should be strong enough to take some nipple/spoke bumps from below.
I've seen pocks like @DiabloScott posted. One of the issues is that the rim wall holds part of the tube, and a very small area of the tube expands to the point where it is at risk of splitting without actually having anything puncture it.
Michelin is now intentionally making bumpy tubes with the idea that the bumps actually add compression to the tube rubber, and tend to hold holes closed.
I can't say if they'd help in @DiabloScott's situation, unless a bump happens to be close to the spoke pocket.
It's MY mountain
Liked 2,981 Times
Except there definitely IS a puncture, right in the middle of one of the pimples.
BTW, those weren't my photos, but the look is identical.
Liked 4,512 Times
No, well, in part.
One has dimples in the rim tape.
I presume that as the tube inflates, it inflates up to flat against the rim tape, which then will hold the tube more or less in a fixed position.
Then the tube continues to expand into the dimples, and thus, only a small portion of the tube is expanding at that point, and eventually gets thin enough to split.
However, the rim tape either has to have dimples in it, or perhaps is flexible enough to allow that to happen.
Somewhere I have some rim tape with about 3/16" dimples/pockets at each spoke hole, and a tube that has popped because of that. It was kind of nice. The dimples held the rim tape in place quite well, but the popped tube wasn't good, and it is very hard to patch.
I have some errands to do this afternoon, then I'll browse around this evening and see what I can find.
Quoted: 2026 Post(s)
Liked 1,096 Times
Liked 3,929 Times
Hmmm, those bulges are 1) outward and 2) in pairs an inch apart. This says to me that there is a set of holes somewhere on your wheel or tires that match. I'd blow up one of those tubes slightly, put in in the tire and see if there is anything suspicious at the bulges in either the tire or rim. (Or the same distance from the valve in the other direction.) Front and rear doing the same thing? Weird.
Quoted: 4408 Post(s)
Liked 1,562 Times
Looking at the other thread, I wonder if the grooves the run in the bottom center of the Weineman rims act in concert with the holes to make small punctures in the cloth rim tape. After those spots of weakened sufficiently the tube is going to force them open until they allow the tubes down into those spots where they burst. This would explain why the tube bulges are oriented in the same direction as those grooves.
Once it starts happening, you'd have to replace your rim tape or at least off set it by half a spoke hole. You should be able to find these weak spots in the tape with a dull pencil.
Mechanic/Tourist
That is a stumper as far as spacing of the dimples. The distortions are greater than the width of the hole in the rim above the spoke ends, but much smaller than the distance between holes. They are not right next to the valve stem, and presumably not at the seam. Although I can't explain the spacing I do know that it is a common problem to get such dimple failures when one combines a very narrow rim with a wide tire, and that the use of thicker/double rim tape, in order to minimize stretching of the tube into the narrow inner section of the rim, can help. However it can also make mounting more difficult. It's simply poor practice to combine a narrow rim with wide tires, especially as there is no advantage to doing so.
Liked 1,562 Times
As far as the spacing goes, the tubes in the picture are over an inch wide - those punctures are less than half the width of the tire. Spoke rim holes are around 3/8" - why are you saying the holes are spaced wider than the diameter of the spoke holes?
Quoted: 1438 Post(s)
Liked 1,092 Times
Continental has an HP series of rim strips which are rated to 220psi that you could try: https://blobs.continental-tires.com/...ip-en-data.pdf
