Leaky Valve: Replace?
I found the source of the slow leak in my front Tre. The tube itself is fine but the valve leaks air unless it's screwed in very tightly. Tightened up the valve and everything seems to be in working order. Should I replace it anyway? This is the first time I've encountered this type of problem so I guess I've been lucky.
Anyone else dealt with this problem?
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
Is this a replaceable core? If so, try a different valve core.
Yea, replace it
peace of mind & time saver not
having to pump up a slow leak.
Good practice in case it ever needs
done when out & about
You didn't say if it is a Schrader valve (like on a car) or Presta (the skinnier ones). Schrader valves are removable (with a cheap tool) and cost about $.50 each - good deal cheaper than a new tube.
Some Presta valves are replaceable, not all, and they cost about $1.50 each - starting to get closer to the price of a new tube.
Personally, if I have a valve leaking I just replace the entire tube. It always seems like the new valve stops the leak but not long after I get a leak around the base of the rubber where the valve stem goes into the tube.
Quoted: 18397 Post(s)
Liked 15,493 Times
I was born with a leaky valve. Had to have it replaced when I was 25. Cost a lot more than a new tube.
Quoted: 941 Post(s)
Liked 319 Times
If you are not now, start using valve caps. I know this amounts to heresy on this forum, but..
I always use valve caps. I think they're a good idea.
Quoted: 18350 Post(s)
Liked 4,502 Times
Some presta valve cores are replaceable... some are not.
Look for two flats on the threads just below the top. I'm pretty sure that if you have a replaceable core, then they are pretty universal.
With more, better sealants, hopefully we'll see replaceable cores becoming more common.\
There are special tools to remove them, but I just use a standard adjustable wrench.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
I use the valve caps that have the little (Schrader) valve remover tool built into them. I think I've only used those once in my whole life, but it's nice to have right there if you need it. Get them at any auto parts store.
Quoted: 176 Post(s)
Liked 25 Times
Quoted: 641 Post(s)
Liked 1,517 Times
Old fart
Liked 3,395 Times
If you use sealant in your tubes, a removable core makes it easier to inject the sealant, and if/when the sealant clogs the valve, you simply remove it and soak in ammonia to dissolve the sealant. I find it handy to have a few core available, so I can swap a clean one in while letting the clogged one soak. You can buy cores separately or in bulk, or even salvage them for free from discarded tubes.
Liked 4,502 Times
Attach to the two flats. Turn counter clockwise. Be careful of the spokes.
A turn or two, and you can usually get it the rest of the way out/in with the fingers.
Note, this is for PRESTA as above.
For Schrader, you'll need the tool, or a valve cap with the tool.
