A word about VO headsets
Recently I went to the LBS to have them install a VO headset on my NOS Motobecane Fork , they called me about a week ago saying the race fractured , and that I needed to get a replacement, so I ordered a replacement from VO to get a second call today from the LBS stating that the second race fractured as well .
This LBS has a very knowledgeable staff with a lot of experience working on bikes of all vintages , more specifically I trust the mechanic (who is also the owner) performing the install . He stated that the race was for this race for the headset was really cheaply made , he also located a suitable replacement race for me and did not charge me for it .
I have mostly had good experiences with VO products I can't say the same of their headsets, or their brake pads . I would highly recommend using your original headset if possible or locating a good quality used French headset before purchasing one of these .
Quoted: 796 Post(s)
Liked 522 Times
Interesting I have installed a couple VO headsets and not experienced this issue, VO seems pretty stand up I hope they replaced the races at no cost or just for shipping. Hope your Moto is back on the road soon OP
Actually I was charged for the replacement crown race at full retail plus shipping. It was not a princely sum but honestly it still leaves a bad taste , on other hand they replaced a nut on the VO sprung saddle I had when it came off during a ride. So I am not going to be overly upset I just am not going to buy any more of their crown races.
Quoted: 4805 Post(s)
Liked 3,927 Times
Which part is breaking? The crown race? It is machined a touch undersize? If it is the crown race, have you (or the shop) checked the fork? Now that you have a headset that works, this is a moot point but if the fork is oversized, this may come up again.
Now, if the part that broke isn't the crown race, forget everything I said.
Edit: Just noticed this is a Motobecane. French. I don't like to bad-mouth bikes based on country origin, but those of us who have worked on French bikes have learned to expect everything when it comes to adherence to standards. I owned two Peugeots and spent a summer assembling Motobecanes and Peugeots.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
An unusual part to break methinks. I've slammed, er tapped a few of them into place. Or course they've been the correct size.
Quoted: 767 Post(s)
Liked 1,898 Times
Here is Sheldon's crib sheet:
Sheldon Brown Headset Crib Sheet
Quoted: 5888 Post(s)
Liked 3,471 Times
That's odd. I don't know if I've ever seen a crown race break. Perhaps this is a bad batch of crown races? So far so good with my VO headset and I recently bought another. One thing I do like about VO headsets is that they let me mix and match so I was able to buy a JIS headset with a 26.4 crown race.
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
Agreed. Just checked an original fork from a GJ and its 27.
the LBS let me do it myself. He had never used the tool after 10+ years in business. the mill still had the shipping wax on it. a $25 tool rental fro a $593.95 tool. sounded fair to me!
possibly maybe that was what caused the fracture during install. sure sounds like it. probably not a VO problem (unless they are not calling out ISO vs JIS.... not sure) .
and it's some really esoteric info for the bike shop owner to keep in his mind - what with 53million different bottom bracket sizes out now.
Again this isn't a size issue. I know that is always the default idea someone likes to arrive at. I did not have the tools to cut the shoulder myself but my LBS did and the mechanic is a very experienced.
Something was weak, the original race fractured after he cut the shoulder on the fork and attempted to install it, he told me when he calipered it before install it, the race was right at 26.4 , same thing with the second one. His opinion of the VO races are that they are cheap and honestly I agree at this point. I do most of my own work but I can't cut a crown race shoulder myself I just do not have the tools. He actually had the correct Campagnolo tool and used it. versus using the more modern Park tool version.
Had I used the original fork it may not have been a problem , but the chrome was pitted and wasn't cleaning up as I would have liked . I got lucky and was able to source a NOS Grand Jubile fork for my Grand Jubile, however the crown race shoulder had never been cut. The reason I did not use the original headset was some pitting on the metal . It was function just not as pretty as I wanted it to be . The VO headset looks really nice , I am just not impressed with the races at this point. My mechanic found me a suitable replacement that installed without incident.
Jedi Master
Why bother commenting IF you can’t be nice .
Jedi Master
Jedi Master
The fact that the VO headsets come with a split crown race is not an opinion, and I'm not posting for your benefit since you already have a different crown race. I'm posting for anyone else who might read your post and think there's something wrong with VO headsets.
Quoted: 3464 Post(s)
Liked 2,829 Times
Used to that from decades past.
These are not super expensive headsets, and even fewer now have French threading.
they also could have said hey this is a split crown race when I called to order a replacement ..
Jedi Master
As I said, my intent was correct the mis-information in your original post not to be helpful to you. I guess it's not surprising that you were offended by that. Thank you for your feedback on my communication style. I will try to be more delicate with you in the future.
I didn’t think the caged bearings had a split race, only the sealed.
