Need to find headlight
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
The BT40S I was looking at is a stand alone light head and would also need charger, battery box and cable. All standard stuff but not included... however that light appears to have been re-stocked in yellow not white light.
Genesis 49:16-17
Genesis 49:16-17
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
I have a couple magicshine clones, and I don't like those beams, even with the diffuser lens. I find them way too narrow. Like 2ft circular spot at 8 foot distance, or with the diffuser a 2x5ft bar at 8ft distance (again just spitballing).
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Ah yes, this is the time of year that people with battery-powered lights start thinking about re-attaching them to their bikes.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
I have nothing but good words for the Fenix BC30. I prefer removable batteries, and this one used 18650 batteries. I always have an extra pair along, a charger at home, a charger at work and I'm set.
https://www.fenixlighting.com/produc...gaAtKtEALw_wcB
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
1. How much light output do you need?
2. How long do you need it?
The first depends mostly on your commute route. If it's on reasonably well-lit city streets, the I'd suggest 300 lumen is a good minimal brightness. Unlit country roads and you might want to step up to 600 lumens or so. Adjust based on various conditions (e.g. if your route has lots of potholes and you haven't memorized their location yet, go up in brightness.)
The second is really just how long is your ride. Consider, also, the worst-case scenario of having to change a tire on the way. Make sure the battery life (at the brightness you'll use; see above) is at least that long.
Once you've answered those, just stick with reputable brands (really, any reputable brand) and find one that fits your price range, esthetics, etc.) REI is a good place to look as all the brands that they carry are fine.
Edited to add:
FWIW, after trying lots of lights over the decades, I've settled for now on the Fabric Lumabeam. Relatively modest light output and battery life, but for me the big selling points are (1) very small and light weight, (2) easy to use controls to change modes (rotate the dial, no messing with multiple button presses etc.)
Bikes: Death machines all
Quoted: 297 Post(s)
Liked 86 Times
I've had very good experience with Light and Motion Vis 360 USB charged helmet-mounted lights. Pricey, but my original set has lasted over 3 years riding year around, (still working but the switch is a little wonky) and I just purchased the latest model for $65. When it's on, the switch glows to report the charging status, very helpful.
Work is the curse of the drinking classes - Oscar Wilde
OP never came back. Nevertheless, I'll answer. I like my CatEye Volt 800. Lots of brightness when needed and replaceable rechargeable batteries for those long rides at full brightness. HyperConstant light mode (constant 200 lumen with a 800 lumen strobe) is a day time attention grabber without being unobtrusive to others.
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
Quoted: 1034 Post(s)
Liked 1,290 Times
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 84 Post(s)
Liked 57 Times
Mine never comes off either, I live above 45th parallel and I am out of the house about 4:15 AM everyday, Maybe 2 months around summer solstice time is when there would be some daylight by the time I arrive at my destination by 5AM. So I use my headlights year round.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,424 Times
no wonder your avatar looks so sleepy/grumpy
Quoted: 84 Post(s)
Liked 57 Times
I like it, I think my avatar is cool ugly face looking, .... :-)
Likes For no motor?:
Quoted: 7348 Post(s)
Liked 2,460 Times
I've been letting my dynamo-powered lights (on the bike so-equipped) stay on but not turning on my battery-powered lights unless it was night. I've recently changed. I run my lights no matter what now. Maybe they won't help, but they certainly won't hurt.
Resident smartass.
I have a couple of cheap Everyday brand headlights and tail lights that I use and I love them. From the saddle, the headlights are really bright and do a great job of lighting up the road in front of you. For oncoming traffic, Unless you know where to look, you cant even see them.
Quoted: 297 Post(s)
Liked 86 Times
I'm not surprised that you managed 10 years out of the L&M 360. The lights and battery on my 3 year old set are still chugging along in great shape, but the switch sometimes needs to be tinkered with more than I have patience for; I'll still use this set as a backup for the replacement.
Bikes: Kilo WT, Bob Jackson
Anyone use the Brighteyes branded units from Amazon? Have a ton of reviews on there but looking for some firsthand feedback from someone who has used one pretty extensively.
Likes For HankHeel:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I'm into year 5 with my MagicShine 1600 triple head unit. I have a spare battery pack, and I only charge once per week during seasonal use. The battery rides inside a modified water bottle in my downtube cage. The head mounts on a DIY horizontal tube above my front fender. Plenty of light, sort of like the Close Encounters footage above. I like that the MagicShine allows me to choose from main beam, side beams, or all at once. Plus it has a dimmer feature that saves on battery life when you don't need to stun others with the brightness. It's been great.
I remove the battery pack during summer to save weight. I keep the head and switch units mounted year round.
On my helmet, I use a NiteRider 650 or 350. On handlebars with my race bikes, I just use the 650, with the 350 on the helmet. I'll re-introduce the helmet light in a couple of months.
Unlisted member
Liked 432 Times
I stayed later at work on Thursday and notice my lights illuminating the road by the time I got home, definitely past time to start shopping if you haven't done so yet. Especially with the trade wars and economy getting worse.
I myself use a Cygolites. I have a 650 now for 5 years, and last year got 800 which will go on as a second head light in the next couple months for night riding.
Likes For crazyravr:
Bikes: 2018 Specialized AWOL, 2013 Surly Pacer, 2011 Raleigh One-Way, 1973 Raleigh Super Course, 2020 Surly Big Dummy
Quoted: 30 Post(s)
Liked 30 Times
I have a couple of them, they work great. They do not charge via USB, but typically come with their own charger. In any case, they are bright, and I was pulled over by a police officer and asked to turn off the flashing for the headlight.
Unlisted member
Liked 432 Times
Isn't this you getting to work in the morning, @cyccommute?
