Help me not hate tubulars!
_______
Bikes: Merckx Corsa Extra, Ciocc Mockba, Zeus Victoria, Serotta CDA, Willier Cento 1SR, Pinarello FP Quattro, Teledyne Titan, Chesini Arena Precision 83, Denti Master, De Rosa 35th Anniversario, 3Rensho Super Record, Koga Miyata Full Pro, Klein Rascal
Quoted: 21 Post(s)
Liked 127 Times
I am hoping to gain some wisdom from this esteemed group to help me reduce my disdain for tubulars. My last three rebuilds have required tubular replacement and the long and painful glue removal, new glue application, sore hands and mess. Does it ever get better? Are there some secrets of the trade to make things easier? I would love to hear your best secrets for tubular replacement!
Quoted: 3464 Post(s)
Liked 2,827 Times
Removing the existing residual glue from the rim is not always necessary.
there is a totally tubular thread that has a lot of information.
aged tires get far fewer flats, the rubber becomes less tacky. 6 mo to a year- even more.
I will admit that the modern crop of adhesives are not as easy to use as the old standard Clement "red".
It's the way of things now.
Quoted: 1946 Post(s)
Liked 2,004 Times
Quit being so selfish. Is it always about you? Tubulars are for your bike and if you really cared about your bikes...
https://www.bikeforums.net/classic-v...y-tubular.html
Quoted: 2323 Post(s)
Liked 4,936 Times
Steel is real...and comfy.
Likes For jamesdak:
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
One hint - leave a small section between two spokes without tape, opposite the valve stem. This gives you a starting point to remove the tub at the side of the road. With this small unglued/untaped space, you can often remove the tub without levers, put your spare on, air it up, and be rolling again in less than 5 minutes.
Dale, NL4T
Dale, NL4T
If this is about flipping old bikes, and you don't like cleaning of the decades old dry glue; yeah, it sucks.
If you're riding tubulars yourself, problem solved by not cleaning off the glue. It isn't necessary. I rode tubulars exclusively for many years. Cleaned off the old glue exactly once.
Quoted: 1627 Post(s)
Liked 630 Times
Heat gun for the glue removal. Sure, it still takes 10 minutes per rim, but the melting glue smell seems a lot less noxious to me than a solvent smell would be. As mentioned above, you don't necessarily have to do it every time you change a tire; just a use a new layer over the old if the accumulation isn't too bad.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I'm not a tubular expert, but I'm hearing that there are some new tubular tires that are also "tubeless". That is, the casing has a thin layer of rubber bonded to the inside so no inner tube is needed. That lets you put in some sealant and in a lot of cases, just ride the tire until it completely wears out. That's what I'd look into if I ever got a tubular-shod bike.
Quoted: 378 Post(s)
Liked 1,409 Times
Tubulars: tape plus some sealant. Easy enough to change on the side of the road., no levers.
Tubular clinchers: some sealant. Supremely easy to change anywhere, anytime, no levers.
Tubeless: an air compressor plus some sealant. On the side of the road? Hope your sealant works.
Likes For RobbieTunes:
Quoted: 378 Post(s)
Liked 1,409 Times
They will never ride like a Veloflex, but the tradeoff is worth it if you ride solo a lot.
Liked 2,563 Times
Source: https://www.bikeforums.net/20814612-post54.html
RUSA #7498
Liked 2,827 Times
I recall Tufo also does this. I have not used them, the color of the sidewalls - kind of a red brick color just did not agree with my visual target.
Likes For repechage:
Now I find pleasure in every aspect of them. Gluing them is predictable. It's a nice process. It doesn't hurt my thumbs at all; there's much less force involved than clinchers or tubeless.
Buy good ones. Stretch them. Read up where others have pointed you and watch a few videos.
I just used Carogna tape on a CX bike. I think it's amazing for CX; I'd never use anything else -- Carogna tape and a tubular tire without a tube. Beautiful combo.
For road, I still glue, because it's straightforward, lighter and less expensive.
I think @T-Mar mentioned a while ago that this type of tire goes way way back, like to the turn of the century or something, IIRC.
Panaracer sealant. Used in tubulars remains wet a very long time. There are and have been butyl tubed tubulars in which sealant remains active for years. Leave the tube dry until first puncture. Expect sealant to repair large majority of punctures.
Modern tubulars do not puncture all that much. Not noticeably more than light modern clinchers. In many instances tubulars can even flat less, because the tubes are better protected and you will never have tubes failing by split seams. If your standard is Marathons, no, tubulars aren't supposed to compete with that. Cheap tubulars still puncture almost as much as in old days. Repeat for emphasis, cheap tubulars puncture easily and often.
The Tufo approximates old singletube tires. They don't have the tubular ride at all. They flat pretty easy. When I began there were still lots of riders using singletubes, which were then still fresh enough to use, but which were in fact dead inventory from 1940s. Old singletubes didn't ride great either, but clinchers in '60s rode bad too. The old singletubes got some comfort by being very wide, 32mm and up, and by usually being mounted on wooden rims. And they were basically free. Patch with a rubber band, some sulfur, a match. Paying money for a bad imitation of a singletube will not make life easier.
Very strange to first read about those who for unknown reasons wish to apply many layers of glue. Then read about removing glue. Just leave the old glue alone and be happy.
If you can shop at all top quality MSRP $100 tubulars can be had under $50 and often much less. Not that different from quality clinchers. And you don't need tubes. Has it been mentioned yet the good tire stretch onto rims very very easily. Not much need for pre-stretch or overnight inflation if you start with the good stuff.
Liked 2,563 Times
Quoted: 1361 Post(s)
Liked 423 Times
There seems to be LOADs of confusion on the interwebs regarding Tufo.
They make tubulars for tubular rims. They also make tubulars for CLINCHER rims. Nomenclature is closely related and probably adds to the mix up (S33 and CS3 etc).
Both serve specific duties and may or may not appeal BUT do have advantages.
The tubulars are known for higher rolling resistance and harsher ride but are very robust. They had a run for the multi-sport tri crowd as that's one event a puncture will largely cost a competitor. Plus you're on your own with no support. Though today, its well acknowledged other brands are better riding, faster with equally robust tread.
Now for the Tufo tubular for clincher. These are exceptionally tough for its tread and long wearing. The assembly elevates out of the rim cavity. Because of the design, pinch flats are non-existent. In case of puncture, one cannot take apart or patch but rather the removable stem core allows sealant.
Other advantages of the tubular for clincher: if one does puncture, the tire will not roll of the clincher rim. Its SAFE. You can even ride deflated-- slowly and one will feel a slight bump by the stem.
Knock them or not, they're one of the few makes that have good quality from low to high end product. I've never had a lumpy vs. other well known brands.
Years ago Pirelli made a comparable design to the Tufo tubular for clincher called Gentleman.
Another, the Wolber Evolution tubular for clincher was not of comparable design to the above mentioned. The design filled up the rims cavity or well.
“Senior” Member
Agree on the lousy color.
Quoted: 603 Post(s)
Liked 1,062 Times
Tubulars are awesome, till you get a flat, then they kinda suck. Still, great ride when inflated.
Tim
Tim
I would personally support hating tubulars...haven't used them in 20 years and don't miss them at all. I have been running GatorSkins (generally 23 or 25) on my main road bike since they came out...with thinwall tubes and I'm happy with the weight and the ride. I have NO fond memories of living with tubulars and prefer carrying a spare tube rather than a spare tire.
Quoted: 378 Post(s)
Liked 1,409 Times
Psimet2001 says that some (all?) of Donnelly and all of Maxxis's tubulars are now tubeless construction as well, so it's not just one particular tire.
Quoted: 378 Post(s)
Liked 1,409 Times
Not in my experience at all, and not in that of the other people I know who use them.
I'd be interested in knowing how many you've been through.
