Recommended shock pump
Old 10-09-19, 08:55 AM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
Anyone have a shock pump that they like and would recommend? Thank you.
NoWhammies is offline
Old 10-09-19, 03:52 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
I’ve had 4 different shock pumps over the years (Fox, Progressive, Rock Shox, and one I can’t remember), and honestly, they are all pretty much the same in quality and function.
What pressure range are you looking for?
Kapusta is offline
Old 10-09-19, 05:38 PM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times in 601 Posts
I bought a no-name brand on EBay because it got good reviews. Very similar to the name brands. Have been using it for 2 years now and still going strong. If I remember tomorrow I can go check the brand if needed.
2cam16 is offline
Old 10-09-19, 06:40 PM
ab_antiquo
Quoted: 44 Post(s)
Liked 25 Times in 17 Posts
I've had a bunch of them from Rockshox, Fox, XFusion, etc. They all break eventually.
The ergonomics of the Lezyne are pretty good.
ab_antiquo is offline
Old 10-09-19, 06:53 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Wow. I have never had one break or fail.
What breaks?
Kapusta is offline
Old 10-09-19, 07:10 PM
ab_antiquo
Quoted: 44 Post(s)
What breaks?
Face (and subsequently the needle on the gauge), handle, shaft, etc.
Old 10-09-19, 08:40 PM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 533 Post(s)
Liked 312 Times in 236 Posts
I've mostly used the Fox digital pump, which to the best of my ability seems identical to the Rockshox one. They work well. I also have a Lezyne Shock Drive, which is tiny and light works fine but the gauge is hard to read--nice for dorking around with shock settings on trail.
For personal use honestly most are fine--the gauge needs to be fine enough to dial in settings, but really it doesn't matter if they're accurate in an absolute sense so long as you use the same settings on the same pump, and they all pump up well enough for the relatively occasional use seen outside of a shop setting.
cpach is offline
Old 10-09-19, 09:51 PM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
After Googling around I ended up purchasing the Topeak 360 PSI Bar Pocket Shock DXG. Once I start using the pump I'll let you know how it works out.
