Does unloaded wheel spin matter?
Quoted: 99 Post(s)
I have a DT swiss R32 spline wheelset, and its the nicest wheelset I have.
Though when you flip my bike upside down, and spin the wheels by hand, they don't spin anywhere near as long as two of my other bikes that have generic formula and novatech hubs.
I'm trying to figure out if that wheelspin time reflects loaded bike performance, or if possibly its just time to replace my cartridge bearings in the dt swiss wheels.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Unloaded, it's pretty much meaningless. Unless you can tell that the bearing are worn out (roughness or binding when turning the axle), replacing the cartridges is unlikely to improve unloaded spin and may actually worsen it, as seal drag is a major reason why cartridge bearings don't spin unloaded as long as loose balls. Seal drag lessens over time as the seals wear in.
Quoted: 1438 Post(s)
Liked 1,092 Times
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Quoted: 99 Post(s)
I've even removed the outer seals from the bearings, and that didn't show much of an improvement.
1) Take the bike to the top of a moderate hill, get on, and coast down to the stopping point - then mark the road.
2) Install second set of wheels and repeat using the same body position.
3) Tell us what happened.
I've always wondered why my friend coasts faster/further on his bike as I do mine. It could be his extra 30# on me, the hubs, the tires, a combination of all, etc.
'Science' is fun!
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Just as a point of personal curiosity and experimentation, I like trying to maximize the "free spin time" when I set bearings up. I try to set the preload as loose as possible...basically, right at the point where physical play is gone. I know this doesn't result in any real world gains on the road, but it's fascinating to me how a few degrees of a turn on a cone nut can change bearing operation so dramatically. It is, of course, very logical, but it's no less interesting to me.
So I feel you -- that "free spin time" is something that makes me smile, too.
I recently bought a set of wheels with Novatec hubs, and one of the bearings went bad pretty quickly. I replaced it and, obviously, couldn't adjust anything. It either worked or it didn't (it took me a few tries to get it seated perfectly). I thought to myself, "huh...this is no fun...I can't adjust anything!"
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Hello
It matters to me, I had these superbe pro wheels with bearings as smooth as butter and no play, they would just spin and spin and spin.....I loved it. Ahem, back to reality, In response to your question I have no idea, and it would be hard to argue with the science stated above, but the perception of nice spinning high quality wheels makes me feel better.
Likes For zebede:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Stuart Black
Stuart Black
Liked 406 Times
You might have a point if the DT Swiss hubs were a “cheapo cartridge bearing hub”. None of the hubs that DT Swiss sell can be classified as “cheap”. In my experience, cartridge bearings of just about any kind last far longer with less maintenance than any other hub I’ve used. They even spin far better.
