Campagnolo 9 Speed chain install
I was going to switch a Campagnolo Record 9 Speed groupo from one frame to another. So I was wondering when I remove the 9 Speed chain will I need to buy a new pin to re-install it onto the new frame or did that start with the Campagnolo 10 speed? Thanks.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
Use a connex quick disconnect link ! They are great. You can pop the chain off in 15 sec. Much less trouble than re-peening the pin.
just type "wipperman connex 9 speed link" into ebay and find your best deal. Highly recommended.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
As long as the chain has a protruding pin, it can be reassembled with the same pin. 10, 11 and 12 speed chaina are flush-pin chains that all require a new pin or a quick link to assemble.
Quoted: 18377 Post(s)
Liked 4,512 Times
The first thing to ask is how worn is your chain.
The easiest check is to measure 12", if it is exactly 12", then you're OK. If you're up to 12 1/32 to 12 1/16, then I'd probably just replace the chain. Anything more than 12 1/16, and the chain is trash, and possibly your cassette.
I have a Campy 9s chain on one bike. I think it came with a pin to push in, but not snap off. If the pins push out easily, then I'd try pushing it out (90% of the way), then pushing it back in.
I do like to carry a chain tool, or chain multi-tool, just in case.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Yup. Don't mess around with pins.
Other brands are good too.
Quoted: 550 Post(s)
Liked 325 Times
Campagnolo didn't move to peened flush riveted chains until the 10 speed era although the other companies transitioned long before that.
Measuring your chain is prudent. Use 11" instead of 12" so you can use the fractional marks on a standard ruler.
Expect to replace your chain due to degraded front shifting performance from increased flexibility before that happens. Campagnolo chains are harder than other brands and don't elongate as fast.
