Is this tire ok? Rubber peeling from wire bead :(
Quoted: 1221 Post(s)
Liked 629 Times
I had bought these Vittoria Randonneur tires probably back in 2014? 700c x 37mm, mounted once on my mtb for maybe 30 miles then put away till now. I kept them inside, and decided to experiment with using them on a cheap gravel build.
So I'm trying to mount them and the rubber is peeling from the wire bead! Ugh, from the included photo even the fabric casing is getting rubbed away. I'm afraid these tires are done for. I'm trying to mount them using Pedro tire levers unto DT Swiss R460 rims, haven't had this happen to my other road tires (ugh these rims are tough to mount tires on!)
So should I throw away these tires? Thanks for sharing any info!!
Quoted: 5888 Post(s)
Liked 3,471 Times
I don't see a pic but I'd throw them out. I had something similar happen to a vittoria randonneur 26 x 1.75 tire. There is no reason to risk a tire failure on a bike ride.
I am not impressed with the tire.
Quoted: 1438 Post(s)
Liked 1,092 Times
Toss them. The strength of a tire is in the fabric/wire cords and yours are seriously compromised. They are unsafe and not usable. They might even blow out in your face while you are inflating them.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
If you use them prepare for trouble, I'd toss them
Liked 629 Times
Thanks all, yup I figured they're bad so out they went. Thanks for the info @bikemig, what a bummer!
Good riddance I suppose, I've got a set of Gravel King SK's enroute now
Quoted: 5224 Post(s)
Liked 3,581 Times
hmmm, 2 wires? that's cool. this tire only had 1
Liked 3,581 Times
yup. I drove 2 hrs to get to that place. was in the woods alone. changed 1 tube not figuring out what tore it. got down the trail a cpl miles more & it blew again. that 2nd time I saw what was going on. used my last tube & used some electrical tape & a band-aid to cover the wire end. had nothing on me to snip it with. got it to seat & inflate & hold my weight but played it safe & hitched a ride back to my car. yeah that day stunk
Quoted: 18375 Post(s)
Liked 4,510 Times
