Update advise sought
Quoted: 16 Post(s)
I’m looking for opinions on the possibly of upgrading my bike. Recently I rode in a couple events that involved a lot of climbing and on more than a few occasions, wishing I had another gear to shift to. I hadn’t done much in the way of extended climbing before, but really enjoyed the challenge of these rides and riding in the mountains.
Part of me thinks that I should just use what I have, a 10 speed 50/34 crank and 11/28 cassette and just work on my strength and endurance. But I don’t live real close to any sustained climbs and at 62 years old I'm not sure I can gain the strength and endurance.
I have been riding for 5 years now and averaging 18-25 miles, 3-5 days a week ( less in the winter, more like 2 days week).
My bike is a Trek Madrone 3.1. Most of my riding is what I would consider mostly flat terrain, with no sustained steep climbs and I average about 17 MPH on my rides.
What do you think about changing to a 11/32 or 11/34 cassette.
I could buy a new 10 speed cassette, rear derailleur and chain for $140
or I could buy a whole new 11 speed groupset for 500$-700$
Would it be wise to put $500 into the Trek Madrone 3.1?
Quoted: 2952 Post(s)
Liked 3,106 Times
I'd just do the 11/34 and chain. You may need a new long cage RD. Or you may not. Are you sure your existing RD won't handle a 34?
Quoted: 16 Post(s)
The front crank is Sram and going on line a couple days ago, I saw this available from SRAM - Climber's Kit - Rival Rear Derailleur / 11-32 10-Speed Cassette / 1051 Chain for $140. Just now going to the REI website says it is no longer avalible. Are 10 speed component become harder to come by?
Quoted: 8279 Post(s)
Liked 9,034 Times
10 speed stuff is harder to come by than it was a couple years ago. You might be able to use a Miche cassette, I use one for my Campagnolo group.
Do you think a 30 tooth cog would be enough? I use a 29 with a 34 up front and I'm older than you and probably heavier, too.
I'd do the 11-34...I plan to change to that if I ever wear out my 11-32. 63yo, 210lb...and you are sustaining higher averages than me...hilly here, the 11-34 should really help you on the hills over your current cassette.
I pedal in my sleep...
The Rival 22 medium cage rear derailleur will work just fine for your 10spd setup. Same cable pull ratio. I did the same thing actually, upgraded a Rival 10spd group with a Rival 22 rear derailleur, an 11-32 cassette, and new chain. Couldn't find the climbers kit anywhere available and pieced together the parts for much cheaper from Backcountry and eBay.
Just to add an opinion, it was a good decision and well worth it for the extra range.
Quoted: 877 Post(s)
Liked 726 Times
Tiagra 11-32 or 11-34
Quoted: 16 Post(s)
Thanks for all the replies! It sounds like everyone agrees on a change to my rear cassette. I'll look into a 11/32 or 11/34.
What does everyone think about replacing the whole groupset to 11 speed, would it be a good idea or more of a waste of money?
My Madrone came with a mix of 10 speed components including a Sram crank, Shimano shifters & derailleurs and no name brakes. The brakes could be better and are something that I have thought about replacing in the past. For some reason the idea of having a single groupset or at least a single manufacturer seems like a good idea.
I'm not opposed to spending a bit on my bike. I have had this bike 5 years, gotten a lot of use out of it and really haven't spent anything on it other than replacing worn parts.
Quoted: 451 Post(s)
Liked 364 Times
Quoted: 7652 Post(s)
Liked 3,473 Times
Either go to EBay and buy all the 10-speed stuff you can find, or swap up if the frame is decent (I'd say a 5-year-old Madone would meet the criteria.) As fro training, hill repeats, riding hills in way too high a gear (Listen to Your Knees) and intervals might help. On hill repeats ride down fast to limit recovery time.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I have the power to climb on a 28, but I don't need to prove anything, so I built the new bike with 50/34 and 11-34 out back, it's fantastic. Can climb anything around here without any issues and still have enough top end for the A group rides. Have already done multiple rides with over 10k ft of climbing and I'm glad I had the extra gear.
You can get the 105 r7000 groupset from Merlin for $450, with the 11-34 cassette and GS rear mech.
Likes For Rides4Beer:
Quoted: 16 Post(s)
I'm now going out of my way to ride in the hills and that should really help. The hills close to me, might not be miles of steep climbing, but it is better that nothing.
Liked 3,473 Times
I'd jump on it.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
KMC X10SL is a fine chain and easily available, and I like the quick connect.
