New cassette really loud
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,179 Times
Some brands hubs just make noise when coasting. As long as the cassette was properly lubed when it was installed, it's no big deal. I just got Zipp wheels and they are really loud.
Bikes: Borealis Echo, Ground Up Designs Ti Cross bike, Xtracycle, GT mod trials bike, pixie race machine
Quoted: 8 Post(s)
are you complaining about the noise when coasting or the noise when pedaling, it seems like you are mixing terms a bit. Generally if there is a lot of chain noise when pedaling it is because the derailleur is not adjusted right.
Quoted: 453 Post(s)
Liked 104 Times
As chriskmurray, the OP needs to confirm this, is the OP talking about the freehub clicking, or the chain noise when pedalling?
For the cassette, the OP needs to confirm what they are using as well, a quick bit of research indicates that the Sachs LY 99 is a 7 speed freewheel; not a cassette, would be useful if we knew what the OP ha' as freewheels are different from cassettes.
Quoted: 5787 Post(s)
Liked 2,580 Times
If you had a cassette replaced the ratchet sound when coasting wouldn't be changed, since that part is still original.
There are variations in freewheel noise level between brands and models, but none are silent. As a rule they tend to get quieter as dire and dried oil or grease build up along the ratchet mechanism dampening the clicking noise. You can quiet a freewheel by running some thick oil into it between the turning and non-turning parts (if there's no seal there). Some also have an oil hole, but it's on the inside and can only be used when the freewheel is off. I suggest you go back to the shop and ask them to remove and oil the freewheel for you, using the thickest oil they have, like Phil Tenacious, or Chain-L.
FB
Chain-L site
FB
Chain-L site
Quoted: 8 Post(s)
FBinNY is giving you some good advise, if they replaced a freewheel chances are this brand is just louder and some heavy oil will quite it down. You also mentioned
There is a big difference between a freewheel and a cassette by the way. A freewheel has both the gears and the ratcheting mech in one unit, a cassette is only gears and would not change the noise when coasting.
https://sheldonbrown.com/free-k7.html
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
The bike sounds perfectly normal to me. I find these kind of threads to border on OCD.
For what its worth, I looked up what the OP said was replaced, a Sachs LY 99 which is indeed a freewheel so the OP is inadvertently misusing terms here. OP, you do NOT have any form of a cassette whatsoever. There is no cassette at all on a normal freewheel. What you had replaced is known as the freewheel, not a cassette and the terms are not interchangeable, they refer to completely different parts that do perform the same function. So when you (the OP) keep using the term cassette, it is confusing since you do not have any type of cassette on your bike.
If the bike shifts fine and rides fine, just enjoy it. Some freewheels are noisier than others and that is just life.
Quoted: 966 Post(s)
Liked 1,629 Times
How manny remember that smooth click of the old Regina Oro freewheels tearing down some mountain slope with the same sound as an open faced Penn Reel on light drag at sea.... Ahhh... Heaven....
Liked 2,580 Times
Aaaaah Yes, Regina freewheels, or Shimano fishing reels, those were the days.
FB
Chain-L site
FB
Chain-L site
Liked 2,580 Times
Yes, thick oil helps reduce the noise level, but only so much. There's an inherent difference in noise level among the various freewheel brands. Some sound like Swiss watches and others like buzzsaws.
FB
Chain-L site
FB
Chain-L site
Quoted: 966 Post(s)
Liked 1,629 Times
Im in a hilly area so I go for the Shimano 6 or 7 with the 34T bailout - May need a long derailuer cage...
Screw in the B screw a bit , perhaps the guide pulley sits on top of the chain
which is also in contact with the cog teeth, this of course presses against,
the big rear cog..
the big rear cog..
