What cleats does everyone use?
Quoted: 192 Post(s)
Liked 11 Times
I have been using traditional SPD cleats. This is primarily because I started with indoor riding and this is the setup my gym had, then when I transitioned to road riding I wanted to have compatible shoes for both and this is what I was used to. I also valued the ability to actually be able to walk in the shoes given the cleats are recessed and shoes have tread. I've been reading that there are power advantages to SPD-SL or Look cleats on the road. Anyone have experience with both these more traditional road types and SPD? Thoughts welcome as I am considering getting new shoes and would consider a new setup at this point. Thanks.
Likes For billyymc:
I used SPD pedals for many years - both in spin classes in the gym and outdoors on my touring bike.
One year, some SPD-SL shoes were on a big sale at Nashbar, as were Shimano SPD-SL pedals, so I decided to try them out - I really liked the more solid connection to the pedals, so I stuck with them.
There have been some tests that say the actual increase in power from flat pedals to cleated is minimal for most riders, don't really think I got any faster going from the SDP to SL but I just like the feel better.
The big down side is the clunkiness of walking. I bought a newer road bike, now have that setup with SPD-SL but for touring and biking with my wife I tend to do more walking around and actually put dual sided pedals on that bike: flat on one side/SPD on the other. I still like the feel of the SL lockin better, but for tours and rides where we'll be locking up the bikes and walking around, can't beat sneakers or my old SPD shoes where the cleats are recessed.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I started with SPD, lasted about 3 months in those, then moved to Look, then Campagnolo, then Speedplay for the ensuing 6-7 years. These last 8 years have been solely SPD-SL for retention, feel (float, platform), weight, and price. Nothing beats them. Briefly tried some Xpedo with the Look Keo cleats but those cleats were so garbage I had to switch back, which is a massive shame because I'd be all over the Favero Assioma's other wise.
So SPD-SL all the way. But I don't walk in them.
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
The cleat/pedal system depends on what shoes you want and what pedals you have.
Snobby roadies will scoff at the SPDs you use but for most applications they are FINE.
FWIW I use Look Keo and am fine with it, but the walkability of SPD is a consideration.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
SPDs for me. I have yet to find any actual data that supports the claims that SPD-SL are better for power transfer. I've had no issues sprinting or climbing on SPDs. I like that the shoes are walkable, my road shoes are actually "gravel" shoes and my gravel shoes are MTB. lol
Next bike will be full aero, thinking about using Speedplay Zero Aeros, go for all the marginal gains.
Quoted: 1743 Post(s)
Liked 1,281 Times
Speedplay Zero for the road and Speedplay Frogs for the cross bike.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Look Keo on my road bike and SPD on my CX bike.
Quoted: 4806 Post(s)
Liked 3,933 Times
I use different systems for different bikes because the uses are so different. (Important aside - float is a mortal enemy to my knees. To use SPDs, I have to crank in max toe-in, even cheat to a little more on the right to get an approximation of my no-float pedals.)
Road bike - Forte brand LOOK Delta compatibles (black, no-float cleats) KoolKovers hang from an aluminum carabiner off my toolbag. KoolKovers extend both cleat and tailbone life.
Fix gears - traditional slotted aluminum cleats (toestraps and clips - if I pull a cleat out, my foot is still on the pedal - very, very important at 40 MPH and 200 RPM) I have one pair of shoes a cobbler built up around the cleat so they are fully walkable.
Gravel, city, winter bike - SPD
All this is further complicated by the fact that I have one leg a 1/2" shorter so I use a 1/4" aluminum plate shim under my cleats. I have cobblers 1/4" sole material I've glues with 3Ms 5200 for those right shoes. So, yes, I take shoes and cleats seriously.
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times
SPDs on my road and also when i had a mtn bike. i cannot see any way for SPDs to allow a rider to generate less power barring an accidental un-clipping event. that has never happened to me except for the few crashes i've had.
Quoted: 769 Post(s)
Liked 1,748 Times
Quoted: 823 Post(s)
Liked 1,962 Times
SPD on my Schwinn Peloton for rides without a possible rescue.
SPD-SL Ultegra for my Kestrel endurance road bike.
Quoted: 2952 Post(s)
Liked 3,106 Times
SPD-SL on my road and TT bike. SPD on my CX bike.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
On my road bikes I use Look Delta cleats.
On my fixed gear bikes, I use slotted cleats.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
For those using Time ATAC, do you find they slide around sideways or do anything disconcerting when you stand up to hammer up a hill?
Also, how long do those brass cleats last? The look a bit soft.
