Brakeless and adjusting chain length, every worried?
Old 03-07-09, 02:21 PM
jhaber
Hip-star
jhaber's Avatar
I was thinking today if I should ever be worried about chaining chain length if I ride brakeless. On occasion (actually almost never) I have to take out or add a link to adjust for a gear ratio. There is something that bothers me a bit about popping pins in and out of a chain. I feel like they have to be deforming when ever this happens. Am I crazy? Does it make sense if I know I will be running two different ratios to have two separate chains to?
edit: I just saw my typo in the thread title, oops.
jhaber is offline
Old 03-07-09, 04:42 PM
Thetank
Thetank's Avatar
how often are you removing links and popping pins out? Can't be that many times but chances are you'll wear the chain out before something like this will cause a problem.
Thetank is offline
Old 03-07-09, 04:57 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
It depends on WHAT chains, you can safely do this to most non-peened 1/8 chains, anything 3/32 you are asking for it. Especially 8 speed+.
operator is offline
Old 03-07-09, 05:39 PM
Hirohsima
Buy more than one chain. I have two chains, one for my 45/16 and one for my 50/16. This way I just use the quick disconnect and only break the chain once, EVER.
operator has it right though, older 8sp chains and 1/8 chains that have striaght pins usually can take being broken a few times but only if you have a decent chain tool. Cheap chain tools twist the chain up and often screw up the side plates. I use Park's newest shop quality chain break @ ~ $75 and it works like butter. Cheaper tools produce less than desireale results.
My advice, instead of worrying about it, get a few chains, and KNOW that you are fine.
Hirohsima is offline
Old 03-07-09, 07:41 PM
ADSR
Gentlemen.
ADSR's Avatar
Bikes: S-Works e5 Aerotech with 2009 Veloce and a Fulcrum 5s
I have a cheap chain tool and chain, and it's produced some stiff links that I've had to mess with for a while. I'll probably get better equipment soon.
ADSR is offline
Old 03-08-09, 07:22 AM
sonicj
sonicj's Avatar
you should be constantly worried! you don't have any brakes!
thats a mighty bold statement! how do you "KNOW" your chain isn't going to fail? because you bought the best tools and you have multiple chains? paleeese...
machines fail. they don't care if you used the best tools, ate your wheaties, color coordinated your chain, etc... do you want someone to have to scrape your brains off the pavement because you were too worried about looking cool or your zen experience? i don't like the idea personally... i almost never use my front brake, yet there is comfort in knowing that its there if i need it.
sonicj is offline
Old 03-08-09, 07:37 AM
time bandit
¡Senor Member!
time bandit's Avatar
last i looked this wasnt a thread debating brakes v. no brakes.
take it somewhere else.
dont pop your chain too much. as someone said, it's best to use different chains for different ratios.
time bandit is offline
Old 03-08-09, 09:12 PM
Lou627
Registered User
I feel im damaging my chain popping links as well and was surprised to see on sheldon browns site that he recommends completely disassembling a chain for cleaning
Lou627 is offline
Old 03-08-09, 09:53 PM
owenboen
are you taking about this? https://www.sheldonbrown.com/chainclean.html
cause that's definitely a joke, seeing that the link to it is under his "bike humor" section.
owenboen is offline
Old 03-09-09, 06:12 AM
HandsomeRyan
Pants are for suckaz
HandsomeRyan's Avatar
Bikes: Hardtail MTB, Fixed gear, and Commuter bike
Originally Posted by sonicj
you should be constantly worried! You don't have any brakes!
Thats a mighty bold statement! How do you "know" your chain isn't going to fail? Because you bought the best tools and you have multiple chains? Paleeese...
winner!
HandsomeRyan is offline
Old 03-09-09, 07:00 AM
kyselad
extra bitter
kyselad's Avatar
Bikes: Miyata 210, Fuji Royale II, Bridgestone Kabuki, Miyata Ninety
Quoted: 23 Post(s)
Liked 5 Times in 5 Posts
The chain is far less likely to fail if you're not popping pins in and out frequently. No, there's no guarantee, but really, if you get a new chain, remove a pin, and replace it with a master link, it's very likely to hold up fine. If you keep breaking and reassembling the chain, depending on the type of chain, it's very likely to snap at what can only be an inopportune moment when you're exerting plenty of force on the drivetrain. And that's from experience.
And yes, the OP should use a brake. But I don't want to read that thread for the umpteenth time, so I still think the advice to get multiple chains is the best response.
kyselad is offline
Old 03-09-09, 08:43 AM
2wheelsgood
2wheelsgood's Avatar
Bikes: '08 Marinoni Pista, '05 specialized langster(RIP), '06 norco kokanee(RIP), '05 norco charger(RIP),'08 surly steamroller, surly big dummy coming soon!
If I remember correctly that article was posted on April fools day.
2wheelsgood is offline
Old 03-09-09, 11:07 AM
jhota
blithering idiot
jhota's Avatar
Bikes: 1991 Trek 930, 2005 Bianchi Eros, 2006 Nashbar "X," IRO Rob Roy
this may be kind of a dumb question, but:
why would you be changing your gear ratio that much?
i change my chains about once a year (except for the mountain bike, which is around every three). more often for the bikes i ride more.
and i just can't see changing gear ratios often enough to fubar the chain before i'd be replacing it anyway.
maybe it's living in flat-as-a-pancake coastal SC.
jhota is offline
Old 03-09-09, 11:17 AM
monsterkidz
monster
Quoted: 12 Post(s)
I run 46x17 most of the time, but am able to ride 46x15 with the the wheel flipped and the same chain. As long as you aren't damaging the chain while installing/breaking/installing you should be OK. I've always felt that most chain failure is due to improper installation.
monsterkidz is offline
Old 03-09-09, 11:49 AM
Hirohsima
As a paid shop mechanic for 6 years I can tell you in plain honesty that every broken chain I have ever seen has either been due to a crappy install or extreme wear. My chains are the the expanded pin type which are mushroomed at the outer plate and I seriously doubt I could break one of those chains unless someone fat-fingered the install.
Since I only break a chain once to remove excess links, all of the links are factory closed and peened. Having the best tool helps ensure you don't do damage to your parts. And yes, machines fail. But the biggest variable in most bike repairs is NOT the part, but the monkey turning the wrench.
I have never had a chain fail, but I also run SS and run F&R brakes, so I pretty much KNOW I am fine. I also maintain my dad's bike who does cross country rides multipule times a year. He has over 50,000 miles on a few different bikes and many parts. He has never had a chain fail. That is pretty good evidence to me.
Old 03-09-09, 03:04 PM
jhaber
Hip-star
jhaber's Avatar
I guess I should respond cause this thread got more responses that I thought. I don't have many thousands of miles on my chain. My chain is strong chain in good condition (KMC 710SL), I have a nice (but not shop quality) 1/8 chain breaker, and the chain has only been broken three times so far in its life. I guess I just worry
jhaber is offline
Old 03-09-09, 11:27 PM
Lou627
Registered User
jesus christ. I wish I could remember why I saw that. If it was posted here or something. I really thought he was crazy recommending to do this every time you clean your drive train. Crazy in that he loved bikes too much. Well jokes on me, good one sheldon.
Lou627 is offline
Old 03-09-09, 11:31 PM
Lou627
Registered User
would you not think this man is crazy?
sorry I hijacked the thread
Lou627 is offline
