disc hub on a v brake bike
Old 03-25-09, 11:14 AM
ebeard
The rim on my rear wheel (v-brake) has just split, and the wheel the bike shop is recommending I replace it with has a hub which takes disc brakes. It works in the bike, fits and all that stuff. Is there any reason why this isn't a good idea, or is it fine to have a disc brake hub in a v-brake bike?
Many thanks
ebeard is offline
Old 03-25-09, 11:21 AM
demoncyclist
demoncyclist's Avatar
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
Well, unless you are switching to disc brakes, why buy a disc hub? Does your frame and fork have disc mounting tabs for the calipers? I would have them order a proper hub for your application.
demoncyclist is offline
Old 03-25-09, 11:53 AM
bikinfool
I have senior moments...
bikinfool's Avatar
Bikes: Many
While it's nice to have a wheel that can go both ways, just having a disc rear wheel isn't all that useful on the other hand. I take it the original hub isn't all that special and the cost of a new rim vs new wheel is attractive otherwise? If you do get the disc hub and don't mount a rotor, and it's the 6-bolt type, you might want to cover the bolt holes so as to keep the threads nice and clean.
bikinfool is offline
Old 03-25-09, 11:54 AM
Unknown Cyclist
The hub flanges are likely to be closer together, which would result in a weaker wheel.
Why did your rim split ?
Is this a warranty issue ?
Doesthe disc brake wheel they are offering you have a decent rim for rim brakes ?
If it's warranty I'd hold out for something more suitable.
If you are paying for the repair, get the right wheel or expect a discount as you are accepting what they want to shift.
If it is going to cost you the same, get the correct wheel.
Unknown Cyclist is offline
Old 03-25-09, 11:57 AM
jhota
blithering idiot
jhota's Avatar
Bikes: 1991 Trek 930, 2005 Bianchi Eros, 2006 Nashbar "X," IRO Rob Roy
i wouldn't worry about the hub. just make sure the rim isn't a disc-specific rim.
jhota is offline
Old 03-25-09, 02:55 PM
tatfiend
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
Agreed. Disc specific rims are not designed for rim brakes. The surface the rim brake would work on is frequently not flat and not designed to take the wear that a rim brake causes.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
tatfiend is offline
Old 03-25-09, 07:20 PM
CCrew
Older than dirt
CCrew's Avatar
Bikes: Too darn many.. latest count is 11
A lot out there that are both though.
CCrew is offline
Old 03-25-09, 07:28 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
My RANS V-Rex came with disc hubs and V-brakes. No way to mount disc brakes. The rims aren't disc-specific. Are there very many disc-specific rims?
JanMM is offline
Old 03-25-09, 07:48 PM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
If you have a wheel built with a disk hub and rim brake rim, you will have a wheel that is more likely to work on your next bike. I don't see any downside, just more options later on.
c_m_shooter is offline
Old 03-25-09, 09:38 PM
frankenmike
mechanically sound
frankenmike's Avatar
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, Dahon mu uno, Outcast 29 commuter
Quoted: 100 Post(s)
Liked 84 Times in 53 Posts
Tons. They are preferable because they require less material and are therefore lighter. I've noticed that many mid-level replacement wheels have disc hubs and rims for brakes, I just assumed it was manufacturer economics- it would work for either type of bike.
frankenmike is offline
Old 03-25-09, 10:35 PM
tatfiend
Gear Hub fan
The DT rims on my Civia definitely are and I suspect the Alex rims on the Swobo may be. Both are disc brake bikes from the factory. Both are fully anodized rims without a machined braking surface while most rim brake rims these days have a shiny silver, frequently machined, braking surface. Many also have a wear indicator groove in the braking surface.
tatfiend is offline
