Mounting Rack on Disc Brake Eyelet?
Old 06-16-16, 10:28 PM
youthcom
Seems kinda iffy to me, but do any of you think this would cause any issue if one were to use a disc brake mounting point to also support one side of a rack?
youthcom is offline
Old 06-17-16, 10:37 AM
Tim_Iowa
Tim_Iowa's Avatar
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times in 5 Posts
I can think of two gotchas:
1) Is there an eyelet in the same place on the drive side? If not, your rack will mount all crooked.
2) You'd have to mount the rack support on the outside of your disc caliper (bolt head > rack support > disc caliper > frame) so that you don't mess with the spacing of your caliper.
Most rack makers offer models that are specifically made to be disc-compatible, often with L-shaped rack supports that can clear the caliper.
Tim_Iowa is offline
Old 06-17-16, 12:45 PM
youthcom
Not exactly, but there is an eyelet close enough to the same location on the drive side. The brake is mounted on the inside so it looks like it should clear it without having to use a disc compatible rack.
My concern was with the extra weight/force that could be applied to the disc brake eyelet.
youthcom is offline
Tanstaafl
Hybrid Bicycles
4
01-05-19 12:45 PM
cyber.snow
Touring
12
08-01-15 02:00 AM
unclejemima
General Cycling Discussion
5
03-26-14 05:47 PM
newkie
Commuting
11
01-24-11 04:01 AM
NormanF
Commuting
9
05-07-10 02:42 PM
