A different kind of pump
Quoted: 626 Post(s)
Liked 401 Times
This is Stompump a high volume foot actuated bicycle pump. It is made in California by the people who brought us robot wars. I looked at a couple of YouTube videos and would like some input from someone that owns one of these or knows if it is reliable.
Quoted: 366 Post(s)
Liked 274 Times
When I first saw the picture, I thought it was some kind of PTO drive that you pedaled to power.
Perhaps there is a possibility for a frame mounted pump that drops a gear into your chain. You pedal (in reverse perhaps) with your hand or foot, and it pumps like crazy.
Quoted: 3462 Post(s)
Liked 1,468 Times
I have a foot operated pump like this. But mine is at least two decades old, maybe three. Until a few years ago I was still using it on the bike that is permanently on my trainer that took a shrader valve pump. Mine, the gauge reads about 20 psi too high.
https://www.target.com/p/schwinn-air-...p/-/A-54145331
That bike now uses a presta valve pump (a Silca), so that foot pump is in my vehicle, just in case I come back to it one day and find a flat. My spare is so hard to get to that I have not aired up my spare for years on that vehicle.
Quoted: 626 Post(s)
Liked 401 Times
Tourist in MSN:
Stompump came out in 2018 after a successful kickstarter funding. The pump is 2 3/4" X 4 1/2". It compresses to 3" in the mount. They say it is for large volume tires and will reach 60 psi. It currently retails for as low as $49.00. They suggest mounting it on the underside of the downtube. I don't want it collecting spray from the road. I like the back of the seatpost better.
Quoted: 4560 Post(s)
Liked 2,802 Times
I had a pedal type air pump for our rural place years ago -- lever type stomp pedal, not rotating, sorta like the footswitches on dictation machines and other devices. I got it for occasions when the power was out and the big compressor tank was empty.
We mostly used it for the riding mowers, small tractor, low pressure on the pickup, that sort of thing, although we used it a time or two for air mattresses for guests.
It worked okay and would still be usable with an injured arm, which might be a factor in an emergency on the road. Although a CO2 inflator kit with spare cartridges would be better for bikes in most situations.
There are also small battery powered portable pumps which could be practical for bikes and trikes that are already fairly heavy. I'd consider one for my steel frame recumbent trike, which already weighs nearly 40 lbs. A little extra weight won't matter on that trike.
Quoted: 626 Post(s)
Liked 401 Times
Tourist in MSN Posted: I have a foot operated pump like this. But mine is at least two decades old, maybe three. Until a few years ago I was still using it on the bike that is permanently on my trainer that took a shrader valve pump. Mine, the gauge reads about 20 psi too high.
Quoted: 6198 Post(s)
Liked 4,814 Times
How many stomps did it take to fill up those tires on your bike to 60 psi from completely empty? And do you feel stomping with your leg preferable to pumping with your arms? I never liked those foot pumps for air mattresses and such. But I can see where it's a personal preference item that some or many might want.
Likes For Iride01:
Liked 1,468 Times
Would you strap that thing to a bicycle. It has to weigh over a couple of pounds. Stompump is actually portable and weighs with mounting bracket 220 grams. Here is an informative review incase someone is interested.
Quoted: 626 Post(s)
Liked 401 Times
Iride01 Posted: How many stomps did it take to fill up those tires on your bike to 60 psi from completely empty? And do you feel stomping with your leg preferable to pumping with your arms? I never liked those foot pumps for air mattresses and such. But I can see where it's a personal preference item that some or many might want.
Thread Killer
Quoted: 3151 Post(s)
Liked 1,716 Times
160 stomps to get a 26x2.125 to 35psi does not sound like impressive performance.
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
chaadster Legs are easier than arms. At an 80 cadence that's 2 min, (?4)
still beating my Ryobi electric handheld (NEVER go into HDepot unless totally sober)
But lags the smaller pocketable pumps, even for those of use compelled to buy stuff on impulse (sic)
Quoted: 626 Post(s)
Liked 401 Times
chaadster Posted: 160 stomps to get a 26x2.125 to 35psi does not sound like impressive performance.
Thread Killer
Liked 1,716 Times
The Stompump is a foot operated high volume mini pump as with all mini pumps they emphasize easy to carry over convenience. I have a Topeak Road Morph G and a Silca Tattico mini pump also. Both of them require a lot more pump strokes than the Stompump to fill whatever tire I have on my bicycle. The Stompump complete with mounting bracket weighs 220 grams or about 7.7 ounces. It is a little less convenient to deploy than conventional mini pumps and I would say it is odd or even quite ugly in appearance. I showed it to a couple of friends and they asked what is that. I am happy with my purchase because this pump doesn't aggravate the worn parts on my body. I believe your statement was full of assumptions.
I went and took a look for some comps, but it has been awhile since anyone tested on the 26x2.1 tire size you reference, but Velo recently tested a bunch of High-volume mountain and gravel pumps with a 650x47mm (27.5×1.9in) Panaracer GravelKing tyre (and tube) on a Hunt Adventure Carbon rim (24mm inner width) – inflated to 35psi as an average pressure for gravel tyres. The same wheel setup was also measured at 30psi for the mountain bike-specific test.
https://velo.outsideonline.com/road/...ike-45-tested/
There’s about 4L volume difference between yours and the tire size Velo tested, but adjusting for that (by figuring out the Stomp’s displacement based on number of stomps for tire size and pressure and backing down 4L worth from strokes), it doesn’t appear to outperform the best minis, which is kind of surprising to me.
It’s a nice option to have, particularly for folks with difficulty operating hand pumps. Mini electrics, like Fumpa, would appear to pump faster, too, but are obviously not suited for all use cases; having to remember to recharge my pump is pretty unappealing to me!
In any case, I certainly prefer the mini hand pump myself, but did want to understand the benefits of the Stomp pump, the greatest of which is that it’s foot actuated.
Liked 1,468 Times
I’m not sure what all these assumptions are that you’re suggesting I made, but my use of the word “seems” was meant convey uncertainty about my view. If I did make a presumption, it was that the comparatively large Stomp might deliver best-in-class volume and pumping speed.
But I do not bring that foot pump on tours, too heavy and big. For that I bring a Lezyne Micro Floor Drive or the Road Morph G.
My heavy touring bike is a S&S coupled bike, I have to disassemble the bike to fit it into a case for airline transport. The tires are 57mm wide. I have to deflate the tires to pack the bike into the case, the tires inflated are way too big to pack the bike in that size case. And I can assure you that the Lezyne Micro Floor Drive (high volume) pump takes a LONG time to pump up both 57mm tires after I assemble the bike at my destination, touring with a heavy load I run 45 psi in rear, 35 psi in front.
On a tour, I do not use a pump very often, so I continue to use the pumps I have been using, when stored they have a better size and shape for my purposes. But when I make that choice, I am fully aware that it will cost me some time to pump up my tires when I start my tour. Just two days ago I posted a photo of my heavy touring bike, it is at this link if you are curious, you can see the Lezyne pump attached to the seat tube on the frame. Fortunately on that tour I never had a flat, so was only occasionally topping up the tire pressures for a few minutes after the initial fill.
https://www.bikeforums.net/23208352-post9.html
Thread Killer
Liked 1,716 Times
Liked 1,468 Times
I explained that I agree with Rick, the foot pump is faster and easier to use.
But I explained that in my case, I am not going to carry around a foot pump due to size.
Apparently I was not sufficiently clear on that.
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
"A different kind of pump". Someone 'invents' these ↓ pumps about every ten years, so we're about due again.
Quoted: 7352 Post(s)
Liked 2,479 Times
Pump hub. That is so weird.
Thread Killer
Liked 1,716 Times
https://youtu.be/rDmknRJVk_A?si=maFSU6STZeK6n0HE
Thread Killer
Liked 1,716 Times
You sounded quite opposed to the concept of a foot operated pump and it sounded like you felt that hand pumps were better than foot pumps.
No, my point was only that the Stomp didn’t deliver impressive performance compared to common mini-pumps, and I provided mini-pump test results to support that conclusion.
I was not, as you were, talking about any possible foot pump in the world, rather I was specifically addressing the StompPump and its performance stats as reported in this thread.
Quoted: 626 Post(s)
Liked 401 Times
So I mounted my mini foot pump and Decided it's a keeper for me. With mounting bracket it weighs 220 grams. This is the same weight as my Topeak Road Morph G without its bracket. There are a couple of mini pumps that put out
more air per stroke but most of them don't. I bought it for its usefulness to me.
