Need seatpost advice.
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times
I have an older RockShox suspension seatpost on my Fuji Traverse and want to go to a non suspension seatpost. I can't find the original stock Oval seatpost and am looking for a new option. Diameter is 31.6. What are some good options to target? I'm only looking to spend $50 tops.
Thanks for any input.
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Big fan of the Thomson Elite--the weight(much lighter than any stock posts that came on my bikes), the look, how well the clamp works. I now have 3 bikes all with these on 'em. New they're out of your price range but I got the last one used on Pinkbike for around $50 or so.
Likes For pbass:
Quoted: 124 Post(s)
Liked 51 Times
Edit: Would I be good with either a 410mm or 367? I'm 5'9", 30" inseam, bike is 53cm.
Originally Posted by MrWasabi;[url=tel:21949440
21949440[/url]]Edit: Would I be good with either a 410mm or 367? I'm 5'9", 30" inseam, bike is 53cm.
But also, there are lots of decent rigid seatposts. You don't mention if you want setback or not; it'd be convenient to figure that out before you choose a seatpost, unless you just want to get two, with and without, and experiment.
If you are fussy about whether your seat is exactly level, I suggest looking at seatposts that use two bolts to hold the seat, because the ones that use one bolt typically use little ridges in the clamp mechanism, and then the seat angle isn't continuously adjustable.
Likes For scubaman:
Likes For zen_:
Quoted: 1088 Post(s)
Liked 1,024 Times
Randombikeparts has I think oval brand carbon posts in your range with shipping included.
Likes For Russ Roth:
Quoted: 124 Post(s)
Liked 51 Times
Thanks for the replies everyone,
There are some good deals on that Randombikeparts site. How are FSA seatposts? I have FSA Afterburner bars. Basically flip a coin between FSA and Oval in that price range?
Quoted: 124 Post(s)
Liked 51 Times
Just scored a new Thomson Elite seatpost for a little over my budget. It's 410mm and no setback like I want. On the length, how much can I trim off? I don't want to take it to the absolute safe limit but am looking for a conservative amount if I don't need it. I think my stock Oval 300 seatpost was 300mm?
https://archive.fujibikes.com/2014/Fuji/traverse-132
Thanks again for the replies and advice.
Likes For MrWasabi:
Quoted: 1461 Post(s)
Liked 1,481 Times
Just throwing it out there that the FSA SL-K carbon seat post is roughly the same price as that Thompson Elite, if you wanted to consider a carbon option.
Quoted: 124 Post(s)
Liked 51 Times
Outside of weight savings (not much here), what will the carbon offer me? Also, can a carbon seatpost be cut shorter if needed?
Liked 1,481 Times
Carbon seat posts (generally speaking) have more compliance and mute vibrations better than aluminum, making for a smoother ride. In most cases they're lighter, though that Thompson post is already pretty lightweight.
Likes For msu2001la:
Quoted: 284 Post(s)
Liked 313 Times
Likes For pbass:
Liked 1,024 Times
Cutting the thompson isn't an issue, from cutting a number of them over the years for other people they seem to be the same design as far as I can see, biggest thing is marking the same length they recommend should you transfer it elsewhere. Cutting carbon is a slightly different game, you want to tape where you'll cut to prevent fraying and use a new, fine tooth hacksaw blade, I use my bandsaw and it cuts very nicely without a hint of fraying. Like the Thomson I suspect the carbon will be the same profile till you get close to the seat clamp.
As others mentioned, the main benefit is vibration dampening. I knew of the Oval as I have 2 on the way for my wife and my bikes. Although they'll be fairly comfy with the 2.1 tires the carbon can take out just enough of the road buzz to make a difference over 5-6 hours and 80mph. I bought them for the ride comfort but the weight savings is a bonus as even an 1/8 lb matters when fording a stream.
