Help with brazing cable housing stops
Quoted: 30 Post(s)
Liked 12 Times
Specifically what type of flux and filler do I need for brazing aluminum cable housing stops to a Reynold 520 Cromoly frame?
Also I am modifying a rear derailleur hanger. I am adding a small bar to the hanger to keep it properly aligned. The hanger is aluminum. Should I also use aluminum for the bar or a different metal? Then what flux and filler for the hanger?
Thanks
Thanks
Quoted: 321 Post(s)
Liked 263 Times
Thanks
Thanks
Likes For guy153:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Randomhead
Liked 3,694 Times
There is a supplier sticky at the top of this forum.
I would consider bike fab supply or framebuildersupply
https://framebuildersupply.com/collections/braze-ons
Quoted: 4199 Post(s)
Liked 3,851 Times
I have a good stash of various braze on bits including cable stops in a few configurations. Feel free to PM me if I can help you out. Andy
AndrewRStewart
AndrewRStewart
Quoted: 321 Post(s)
Liked 263 Times
You can even weld aluminium to steel but only by using high explosives. Probably not a good idea to attempt this in your garage.
https://www.sciencedirect.com/scienc...24013618302899
Randomhead
Liked 3,694 Times
It makes no sense to do this with aluminum when steel parts are easily available. Joining dissimilar metals is always going to be an experiment best left to people that really need to do it.
Likes For unterhausen:
Liked 3,851 Times
Quoted: 714 Post(s)
Liked 800 Times
Just buy some steel braze ons and some 50 - 56% silver solder and the appropriate flux. I would stick with ordering the stops from Bikefabsupply or Framebuilders Supply, because NOVA will kill you on shipping for small parts.
Randomhead
Liked 3,694 Times
Is that still true about Nova? In the past they would send a different way if you called, I did that once.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
With Nova under new ownership you may want to call them and see if that is still the case.
Quoted: 714 Post(s)
Liked 800 Times
As a test, I put 10 cable stops in my cart and the shipping calculator shows $16.12 to ship to NJ. I don't know if they would put them in a padded mailer and send them USPS if you call, but I have an irrational aversion to calling places to ask about stuff like that. I know Andrew at Bikefabsupply will only charge me the actual cost of shipping and refund any difference from the online shipping calculator.
Likes For dsaul:
Randomhead
Liked 3,694 Times
I don't like it either, but I think I did it before BFS and FS showed up. Henry James was the same way. Bad postage estimators.
Of course, now companies are a bit worried about using priority mail, but my experience with Paragon and priority mail has been good.
Liked 3,851 Times
And what was the refund amount? Asking because I feel that some small amounts of doing business are not worth the efforts to save more on sometimes. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,694 Times
You gotta pay someone to put the small order in a box and ship it, so I can understand why there is a floor at some companies. Don't really see it as dishonesty or honesty really
[QUOTE=guy153;21951987]I think you can braze aluminium to steel using something something like an aluminium bronze rod.
You can, but not for the home welder. You will need to use a bimetallic transition insert or coat the steel prior to welding / brazing.
