Need help with stuck crank arm bolt
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400 // Santa Cruz Stigmata CC // Bridgestone MB-3 BoxTwo 1x Conversion // Bridgestone MB-6 // Santa Cruz Highball C // Ibis Spanky
Quoted: 67 Post(s)
Liked 19 Times
Hey everyone -
So I found a vintage Trek 820 Mountain Track by a dumpster today that I would like to refurbish. Surprisingly, the bike is in pretty decent shape, but I wanted to make sure that I could actually get it apart before committing to buying new parts and stuff.
So I tried to get the crank bolts out and while the non-drive side one came out without any issue, the drive side one is completely stuck in there. I'm doing it by myself so maybe having a friend come over would help, but so far I'm stuck. I've tried putting all my strength into it with a piece of pipe over the opposite crank arm, but the bolt started to strip a bit (more so because I was having a hard time keeping all of my strength on both sides while keeping the socket flush against the bolt), the bolt is still ok, but I don't want to strip it further.
I've sprayed some Liquid Wrench on it, although I haven't really given it more than 15 minutes to work in there. I've tried tapping the bolt with a hammer a few times, and I tried heating it up with my MAAP torch, but I'm getting the crank arm hotter than the bolt which I'm pretty sure would make it harder to get off instead of easier. I do have a big Milwaukee M18 electric impact wrench in my storage unit I could grab tomorrow, but would that be a terrible idea? I fear I would have a hard time holding the opposite crank arm while using the impact, or would the hammering motion prevent me from having to do so? Any other ideas?
Thanks everyone!
Photo of the culprit:
Thanks everyone!
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 273 Post(s)
Liked 416 Times
Two person job I reckon
Seeing as you've soaked, it really is just a matter of force.
Once person holds the tool avoids it camming out. The other strikes it with a hammer or uses a long pipe.
You will get it.
You will get it.
Quoted: 273 Post(s)
Liked 416 Times
Some heavy blows with a hammer might crack it too
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
Those need to be fairly tight to begin with and they've been there for 25-ish years. Make sure you have a tight-fitting socket on the bolt. It's a little odd that you say the bolt's beginning to strip- I wonder if you're using a cheap wrench.
Jeff Wills
Jeff Wills
Really Old Senior Member
Do you have a 6 point socket? Highly recommended if your 12 point is starting to slip. Or general fasteners that are tight.
I flip the bike over, hold the pedal with one hand pushing down and my cheater bar on the other, pushing down. Crank arms with about 150-160 degree angle between them. Kind of what "feels" best.
Likes For Bill Kapaun:
Quoted: 67 Post(s)
Liked 19 Times
How would I best how the opposite crank in that situation? I just tried right now with my girlfriend standing on the opposite pedal while I go at it with a socket on a breaker bar and I just end up lifting her off the ground.
Quoted: 67 Post(s)
Liked 19 Times
Somewhat ironically my 12-pt sockets are way nicer (USA made Craftsman) than my 6-pt new DeWalt ones which is the one that started round off the bolt. The socket still grabs the bolt well but I'm afraid of rounding it further.
Quoted: 67 Post(s)
Liked 19 Times
I use a 1/2" drive breaker bar, not a ratchet. Less to flop around then another tool with a piece of pipe slid over it for leverage.
Sq. Dr. & 6 point sockets gives 12 different positions if you need to pick one for best leverage.
Quoted: 4195 Post(s)
Liked 3,837 Times
And watch out for those ring teeth! I strongly suggest you place the chain on that large ring, better to punch the chain then the teeth. One trick I sometimes use is to use a toe clip strap to wrap around one crank arm end and the chain stay. Double wrap it. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1079 Post(s)
Liked 1,019 Times
With a cheaper bike with thick tubes that I don't worry about I strap the crank arm to the frame so I don't have to hold it and also use a 1/2" breaker bar. Flip the bike upside down and set the bar so I can put my weight behind just pushing down.
What's the model number of the crank? It'll be on the back, looks like one of the ones that was recalled, if it is the recall is still valid and last time I did one 2 years ago it included a crank, BB, chain and front der. They're slow to replace right now but if it is the recall crank its cause they would snap.
Quoted: 67 Post(s)
Liked 19 Times
Not surprising, actual US made craftsman sockets were usually a decent brand and made to fairly decent standards, Newer stuff, not so much, the dewalt sockets are also, not to be insulting, a fairly cheap item and not really any better then harbor freight. I'd expect the craftsman to work better regardless of the 12 vs 6pt.
Would should I use to strap the crank to the frame? Would a ratchet strap from my truck work?
Oh wow I had no idea about that crank - I was considering replacing it anyway so that might be a good idea. What replacement did they send you? How would I go about getting the replacement done? Do I just call Shimano?
EDIT: The crank is FC-CT91
Quoted: 67 Post(s)
Liked 19 Times
Quoted: 800 Post(s)
Liked 2,962 Times
Tools?
Impact air/electric tools are made for these situations.a quick burst of 500-1k ft.lbs. of torque should spin the bolt out ez.install a plastic pedal in the opposite side of the drivearm so it jams the crank from turning.
Likes For '02 nrs:
Quoted: 645 Post(s)
Liked 797 Times
You (or a helper) will have no problem holding the crank steady if you use the impact driver. The torque is delivered in very short impulses. I easily hold a wrench to a fastener while I “impact” the other end. The helper will also enable you to concentrate on not having the socket slip off the bolt and mess it up. Strangely, in another recent thread, I stated that there were few, if any, bicycle applications that required this much force. I clearly didn’t consider this instance, which has “impact driver” written all over it. That being said, however, give the penetrating oil a bit more than 15 mins to do its thing before you go medieval on the bolt - the less hammering necessary, the better
I think that a longer “soak time” for the penetrant will go a long way RE: making removal of the crank bolt easier and less likely to damage tools and/or components! I’d lay the bike on its side and fill the little well surrounding the bolt head with Liquid Wrench, PB Blaster, Kroil etc. and let it sit overnight. Don’t be impatient . Clean up something else on the bike. From the look of the crank, I’m quite sure there are other components that need attention .
Likes For sovende:
Half way there
Quoted: 985 Post(s)
Liked 879 Times
I have had a pneumatic impact wrench in my toolbox for many decades but I can't recall using it for the last 20 years. I think I would grab it, though, if I encountered what you are dealing with.
Good luck.
Edit: Also, I'd probably mount the NDS crank in a vise with soft jaws instead of lashing it to a stay. Probably wouldn't happen; however I'd be concerned about bending the stay.
Good luck.
Likes For Moe Zhoost:
Liked 3,837 Times
Were I to have my own retail service shop again (currently enjoy not bring home stress by working for someone else) I would want an impact driver. The auto service shop next door to Full Moon Vista has loosened a few BBs and other frozen threaded fittings for us with their coedless driver. We would hammer, long leverage, damage a tool or two then they would get the thing loose in about 30 seconds... Andy
AndrewRStewart
AndrewRStewart
Liked 1,019 Times
Yeah definitely on the socket set - the DeWalt set was a gift bought at Costco. It's nice cause it has a bunch of stuff, but it is definitely way, way lower quality than my USA made Craftsman and vintage Snap-On stuff that I usually buy for myself.
When I tie down I use the long end of the ratchet strap, wrap it multiple times tightly and knot it. That does the trick usually.
Likes For Russ Roth:
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
Heat it up, it's possible that someone used lock tight on it.
You are turning the bolt in the correct direction and not assuming the threading is opposite like a pedal or BB cup?
Quoted: 1135 Post(s)
Liked 1,726 Times
I would remove the pedals and use a cheater bar extension on both the wrench and the crank. That may provide enough tork, have the crank at 11 o'clock and the wrench at 1 o'clock positions and push together. Usually I just do this without extensions and just use hand grip with gloves on.
Quoted: 67 Post(s)
Liked 19 Times
So two things:
1. I got it off - the electric impact did the trick. It was definitely really stuck in there cause it took quite a bit of pulsing to get it off. I had to risk it with a chrome socket since my impact sockets would not fit. I wore eye protection and long sleeves to be safe. It was very, very satisfying when it came out - here is a 20 second video of the moment of success since I figured you guys deserve to share my joy with me -
2. I love this forum - I post this question last night and I have 21 replies in less than 12 hours. You guys are all so helpful and kind, and I truly appreciate that. Thank you all.
Likes For speedyspaghetti:
Liked 3,837 Times
You're welcome but most of up just want to show up the other guys here
And a thank you for your prompt follow up. Andy
AndrewRStewart
AndrewRStewart
Friendship is Magic
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,361 Times
...for your consideration as you proceed, now that the bolt is off. I have grown weary over the many years I've been doing this stuff, with freeing up old stuck crank fixing bolts. The worst ones are the ones lie Zeus, where the 16 mm bolt head gives you precious little room even for a thin wall socket. So I very often replace them with a couple of these socket head crank bolts. They show up a lot over at the co-op as miscellaneous leftover parts, but you can also buy them new, online, if you are a big spender. Anyway, it's harder to screw up the bolt heads using an Allen head wrench socket on your ratchet. As a bonus, you no longer need those caps that sometimes get frozen in the crank sockets.
