Knee discomfort?
Scrubby duff
Knee discomfort?
I sorta got my riding position dialed in, can do some hard efforts, keep up with Diesel on zwift, and did a ramp test in the last few days...
But...my old jumper's knee is back? It kinda just crept back...no pain yet, and not swollen, but i can feel they are there...
What did I do wrong? Or overdo? *i am noticing the Vastus
Medialis is used more...
Its all indoor at the moment...
Quoted: 6193 Post(s)
Liked 4,809 Times
Overdoing it. Pushing too high a gear for your age. Saddle height. Too much indoor riding. Get some real world experience.
Likes For Iride01:
Scrubby duff
Liked 4,809 Times
I just have no reference for fit on the trainer indoors. What little I do, I don't do like I would on the bike in the great outdoors. Usually indoors I'm sitting up without hands on the bars for 45 min to an hour and pedal about 80 rpm at a low resistance. I have no interest at doing anything more.
So when several ask about fit, and I miss the part about them being on a trainer or forget that later, then it bothers me because I don't know if bike fit outdoors really is the same as bike fit indoors.
Likes For Iride01:
Quoted: 529 Post(s)
Liked 255 Times
I found the having the correct saddle height is beneficial. I have been getting fitter, and riding longer distances, which has resulted in my knees getting a little sore after several long rides. I raised the saddle slightly, which resulted in an improvement in my knees.
I saw somewhere on the internet that your leg should be straight when your heel is on the pedal, and the pedal is at the bottom. Then you ride with your foot further back on the pedal. I set up my bike for to be most comfortable, and it just happened to turn out the same as this.
Scrubby duff
*and i have been trying m520 since late Feb
**20mm pedal extender came in, i will see how that goes.
Likes For alo:
B-b-b-b-b-b-bicicle Rider
Bikes: 1997, stumpjumper S-works hardtail, Medici, Giant Perigee(track dropouts and fixed gear), Columbia twosome, schwinn twinn, '67 raleigh 5 speed internal hub, Old triumph 3 speed, old BSA 3-speed, schwinn Racer 2spd kickback, Broken raysport criteriu
Liked 5 Times
also consider crank arm length. I feel this is measurement is overlooked as so many bikes are stocked with a single crank arm length for most if not all the frame sizes, based more on activity than bike size.
IMO too long for your inseam is worse that too short. Too short just loses power. too long can over bend (hyperflex?) your knee at the top of the stroke while also needing to twist your hips to reach the bottom, or maybe just one or the other.
if your knees hurt going up stairs two at a time.....get shorter cranks.
Likes For orange leader:
Scrubby duff
I did, to make it short, over exertion is the cause. Got excited because i have lost weight, and over did it...
**also my diet could improve some, seems i am lurking around inflammatory food...
Ex gamer, overdoing is the tendency lol.... Oh boy, six to eight weeks minimum to heal...
Its Osgood Schlatter syndrome...
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Nothing wrong with indoor training
Don't push hard on the cranks and your knee will be fine. No hard bursts of energy.
Quoted: 1858 Post(s)
Liked 664 Times
I get knee pain sometimes, too. After all the refitting and checking such things, my yoga teacher suggested that insufficient knee support by the surrounding musculature could be part of the problem. The yoga book "Light on Yoga" by B.K.S. Iyengar has a section suggesting therapeutic poses for certain pains and problems. These have the effect of increasing the strength of the muscles around my knee. Look up "utkatasana." If you can look at a copy of "Light on Yoga," those will be the best instructions. For yoga sometimes good instructions are more useful than videos.
Likes For Road Fan:
Liked 1,290 Times
That is almost 2 inches higher than the "magic formula" says. I think for one, your seat is very likely too high. I don't care for the "magic formula" BTW. Take a look at this: https://www.stevehoggbikefitting.com...ard-can-it-be/
I know I beat this into the ground here, but I constantly see people with issues directly related to seats set too high, and rarely the other way around. There seemed to be a trend in the past few years that resulted in seats set too high, which causes a multitude of problems. When you said, "my old jumper's knee," you didn't say both knees, so I suspect it is only on one side, which can easily be caused by dropping to one side to compensate for a seat height that is too high.
Scrubby duff
And sry, bad grammar on my part... Both knees....
Liked 1,290 Times
Okay, once again, take a look at the link I posted, and still, overuse, and too much too soon. Hope you sort it out. 50 cm over the magic formula is still a lot, and as a result, I am almost positive your seat is too high, based on that alone.
Likes For phughes:
Scrubby duff
Ref saddle height is 86cm from spindal, currently at 87.
I am off bike for a little while so... Wont have a chance to do the hill test. But good tip. Thx
** 10mm is definitely a tad high, it aggravate the injury slightly. 5mm doesnt seem to trigger it with low effort.
Likes For jma1st3r:
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
The exact issue is important. You said "jumper's knee," which involves only the patellar tendon, with pain noticed particularly below the patella. If the pain is not below, but is to the inside or outside of the patella, that's a completely different thing. However it you are indeed experiencing patellar tendinopathy, this is the best article on rehab I've seen:
https://www.strongerbyscience.com/sq...-tendinopathy/
I recommend staying off the bike and just doing these exercises. This is something which has to be rehabbed now.
Pain to either side of the patella is not tendinopathy, bur rather muscular imbalance.
Results matter
Results matter
Likes For Carbonfiberboy:
Scrubby duff
Years ago when I used to be more active with bball, the pain can be felt at the tip at the knee cap along with this. *i never drink enough water.....
Its not as bad as that...and Lol i wouldnt dare, that took a looong time to heal.
Yes off the bike... Really bummed out... Thx for the link
edit: update!!! got all these problem fixed. I have put my trainer on balance pods on each leg(kickr snap), and have 3 layers of your regular exercise mat for the rear. Now I my knees are very very happy.
