strange freewheel mounted on Cranks
D.G.W Hedges
Bikes: '87ish Trek 400 road bike, 93 trek 1100, 90ish trek 930 mtb
Does anyone know about this?
About a year ago I was tinkering with an old chicago made Schwinn caliente, I had a coaster wheel laying around so I decided to make it a sorta crusier. Much to my disappointment and confusion You couldn't stop on the damn thing cuz the freewheel was mounted on the cranks. I tried to switch out the cranks for a regular set but then I got pretty frustrated by the entire endeavor (50 pound schwinns are not that exciting) and gave the bike to a friend who just mounted a front brake on it.
Anyway I just moved to New Orleans and strangely enough my new roomate has a Panasonic tourist with the same feature and my girlfriend has a Panasonic roadbike with the same feature.
I suppose its so you can shift gears while coasting, but why? I mean I've never while riding a bike been, "I just wish i could shift gears without pedaling"
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 20 Post(s)
Liked 7 Times
Its one of those things where they come up with a solution to a problem that doesn't exist and then try to convince you that you need that solution.
The Front Freewheel Systems are just as pointless as you think they are, and they weigh a ton....and they make it difficult to install a new, regular crankset.
Quoted: 5 Post(s)
Liked 5 Times
But besides that, they are great, right....
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
I guess they are pretty good........to put on 50+ pound Schwinns and similar bikes.....
I still don't know what could happen when you are coasting down a hill with one of these and something causes the chain to fall off the chainwheels and jam against the gears and the frame...
Chombi
Chombi
It's the Shimano Front Freewheel System. Gloss here from Sheldon Brown https://www.sheldonbrown.com/gloss_e-f.html
Allows shifting while coasting. If you've ever played with a bike having this system, you'll find that it uses a special "freewheel" in which the rear cogs (as well as the chainrings) do freewheel, but independently of one another, and rather stiffly.
Maybe Chombi is thinking that the cogs are fixed, but they actually aren't.
I've always thought it would be cheeky to set up a bike with a fixed wheel and front freewheel. You'd need brakes, of course.
Quoted: 150 Post(s)
Liked 34 Times
Maybe I'm just worrying too much.....
Like Grand Boise might say, I might be talking mostly B.S....
Quoted: 3464 Post(s)
Liked 2,831 Times
I thought the rear cogs are fixed and the front chainrings are the ones that freewheel, opposite of "normal" systems. At least that's what I remember with my brother's entry level Motobecane in the 80's with this Shimano FFS system. If the rear cogs are indeed fixed, what will prevent crazy chainwrap from happening if the chain falls off the front chainrings? I'm thinking that the rear cogs will keep pulling at the chain at the bottom and will try to feeding it back to the front of the bike??
When the Shimano reps came by the shop to promote the system in was it '74 or '75? they indicated in Japan they had prototyped a Dura Ace level FFS, providing the ability to shift in a corner while coasting, so a racer could select the gear he wanted upon exit.... I guess the prototypes stayed just that, as we never saw THAT.
D.G.W Hedges
someone should put together a book of the all the hairbrained bad ideas in the history of the bike world, I seem to come accross quite a few of them just looking at this forum.
Actually, until your comment, Chombi, I never understood why FFS had both front and rear freewheels. But that must exactly the reason (again, as repechage says).
Dura Ace FFS! Knock me over with a feather! Boy, somewhere at Shimano Labs there is a closet with some interesting stuff in it.
dayco
General Cycling Discussion
41
08-13-19 06:33 PM
E_is_Chill
Bicycle Mechanics
6
01-08-13 09:16 PM
