Replace Cassette?
Replace Cassette?
I'm about to order a new chain, roughly covered about 3k on current chain and cassette, do I need to replace my cassette too?
Quoted: 6202 Post(s)
Liked 4,816 Times
3K being 3000 miles? That ain't a lot of mileage.
What determines for me whether to change cassettes is how the new chain runs on the old. If I have problems that might be related to the cassette wear, then I'll change it.
If you don't mind the expense, then you are welcome to change your cassette every time you change the chain. I won't mind at all.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
You're fine.
You can sort of get an idea of how it's going to go when you wrap a chain around the cog & it doesn't nest very well. At 3000 miles, I wouldn't have even thought about the cassette.
Car dependency is a tax.
Quoted: 839 Post(s)
Liked 1,064 Times
That cassette looks almost new. Most riders go through about 3 chains for every cassette and the best way to know if it needs replacing is if a new chain skips on the cogs. Install new chain and if no issues you're good to go. Also measure your old chain first to see if it is actually worn out. If your saying your chain had 3k kilometers and not miles it almost certainly would not be worn. No sense replacing good parts.
In general, no. 3000k is not a lot of miles. With proper occasional maintenance, a cassette, and a chain for that matter, can easily last 3 times that. And if you're hard of hearing or ignore the clacking, a lot longer than that.
Seriously, I have put close to 9,000 miles on an already used cassette (so I don't know how many miles are actually on it). When I put a new chain on recently I was worried I had let it go too long and would have to change the cassette, as well. It was no problem...silky smooth.
However, if your drive train has been abused for all those miles, yes, you might have to change your cassette. Just put on a new chain. You'll know within the first ride if anything else has got to go.
Likes For joeruge:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
put the new chain on and give the bike a test-ride. if any of the cogs skip under the new chain, replace the cassette. that's all there is to it.
Thanks for the replies, sorry 3k is 3000 miles not kilometers, was only asking as I noticed when cleaning some of the teeth on the smaller cogs looked pointed rather than having a flat top like the rest! Just thought I might as well order the chain and cassette at the same time to save waiting another week for delivery should the new chain skip! I'll order the chain for now and see how I get on.
Liked 4,816 Times
If you want to reassure yourself, just find out what exact model cassette that is and then go to the mfr's website and compare the teeth to their picture of that same cassette. It's really amazing when you first look at one closely the first time and notice how much shaping and sculpting of almost every tooth is on our modern cassettes with 10 or more cogs.
Quoted: 1438 Post(s)
Liked 1,092 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
That cassette looks practically brand new. Unless you get skipping with your new chain, I wouldn't change it.
Quoted: 839 Post(s)
Liked 1,064 Times
I'll say it again, measure your chain first. It may only be half worn. If a new one is needed yes, just order the chain. Highly unlikely any of the cassette cogs are worn and even if they are you can just ride around with the old chain until a new cassette arrives.
Likes For Crankycrank:
I'm blown away by how clean most people here keep their bike components. That 3k cassette looks like it's right out of the box. After four days on the bike, mine looks like it has been stored in the fat collection tray of a barbecue.
Quoted: 6976 Post(s)
Liked 10,975 Times
All the folks stating that a cassette is barely worn at 3k miles should consider the use conditions. 3k miles on a bike that is used exclusively for sunny day pavement rides is nothing. 3k miles on a cassette that is used heavily off-road in mud and dust is a very different matter. In such conditions, I've had problems with cassettes in as little as 3500 miles.
Quoted: 981 Post(s)
Liked 584 Times
Likes For sweeks:
Quoted: 550 Post(s)
Liked 325 Times
Likes For Papa Tom:
Strange shapes are normal and look like that from new. Helps shifting. There is however slight signs of wear. Some of the middle cogs have the typical burr or fin near the top of the teeth. Im betting you are fine still.
Blamester
You could order one and have it ready if needed or just the cog you use the most
I have a cassette with with thousands and thousands of miles and I changed the 17 and 19 a few times. And no problems. I keep an eye on it.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 418 Times
If you make any effort at all to clean and lube your drive train, a cassette should last a couple of seasons, maybe longer.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
