Drive side on cartridge BB loosening
Bikes: 1992 Trek 800 Antelope, 1971 Triumph
I bought a UN-55 BB a few days ago and installed it on my bike that afternoon. I torqued it down, and reinstalled the crankset with plenty of grease. I went for a 20 mile ride yesterday and the drive side cup was loose by about 0.5 mm. I pulled the cranks and disassembled the bb. Nothing was wrong; the threads were fine: greased and clean. I have had cartridge BBs loosen on this bike before, but torquing it down hard solved that. I guess I didn't torque it hard enough this time. Anyway, I reassembled it all with grease and this time I used Teflon tape on the drive side. I have a feeling that it's solved now, but just in case it doesn't hold, what would you suggest I do to keep it from loosening again?
Note: I used grease on ALL threads, tightened to spec, and have installed the same model BB on other bikes I own and never had any problems with.
not tight enough I'd say.. got the spline tool that you can put a socket wrench -breaker bar on
or the 1/2" drive torque wrench?
Quoted: 792 Post(s)
Liked 1,783 Times
This is typically the result of not having both sides of the BB torqued or tightened enough. If it persists after tighting Shimano specs that you use a small amount of blue loctite on each side.
I probably torqued it past spec yesterday actually. Rode around a little bit and it's hasn't loosened butninwont know if it's tight enough until after a few days/weeks of use.
I will try loctite if it doesn't hold. Is there any specific kind I should use?
Quoted: 1438 Post(s)
Liked 1,092 Times
"I probably torqued it past spec yesterday actually."
How do you know this; did you use a torque wrench or just guess? Shimano specifies 36 to 51 foot-lbs which is a surprisingly large amount of torque. Most people undertorque large fasteners and overtorque smaller ones, so you may have guessed wrong.
Quoted: 1529 Post(s)
Liked 718 Times
Facing the BB might help; I can see a BB with an out-of-square edge needing extra torque.
If the BB stiffens up a bit when you crank it up hard this is almost a cert.
Jockey Full Of Bourbon
Bikes: Merckx Mourenx '69 with full Dura Ace, 1996 Merckx MX-Leader Campy Record 10 speed, Merckx EMX-5 ex-Etixx team bike with Campag Record 11 speed. Pinarello F4:13 with Campag Record 10 speed, New Merckx Liege 75 unbuilt, '86 Merckx Corsa Extra unbuilt.
Tubular glue.
Well, that's what we used to use. Ha!
Quoted: 443 Post(s)
Liked 27 Times
I learned recently that cross threading them in means they'll never come loose. In fact, they're nearly impossible to remove.
