Tire size question
Tire size vs rim
I have a Novara Corsa Hybrid which has been one of my project bikes (I'll post some pics later). It came stock with 700 x 40c tires
which ride OK, but wont allow fenders with the rigid fork I put on the bike.
The long and short is that I bought some 700 x 28c Vitoria Rand. tires. There was ever so much swearing involved as I tried to get
them on. The thought of changing one of the on the go is...I don't like to think about it. So they went back to REI.
It hadn't occurred too me that my rim might be too wide for some 700 tires, but that seems to be the case. Right now there are some
cheepy Fortes that are 35s and allow only about 1-2mm clearance between the tire and mud guard in the front of the tire, it seems
OK in the back of the back end of the front tire from a clearance place. The rear tire/mudguard are fine.
Is it reasonable that a 28c tire would be too small for a rim that came stock with a 40c? The bigger tires fit/go on & off with no problem,
the smaller ones have to be torqued on and off with a great deal of stretching. I had assumed that since the diameter is the same
then any 700's would work...
Thanks,
Brian
Thanks,
Brian
Bikes: jamis 2002 komodo, univega aplina uno, miele toscana 300, 1972 puch brigadier, Marin Sausalito
Quoted: 18 Post(s)
Liked 17 Times
check here for your rim width. you my be to wide for a 28mm.
https://www.sheldonbrown.com/tire_sizing.html
i just put a set of kenda kwest 35mm on, they seem to be an excellent tire for $12.59 from bikesomewhere.com.
How wide are your rims? Mine are 24mm on the inside, my bike came with 38mm tyres. Currently running 28mm Continental UltraGatorskins without problems. They slip off and on easily too.
aka Phil Jungels
They will be easier to change after they have been pressurized, and stretched, for awhile.
Bikes: Surly Cross Check, Surly Karate Monkey, Soma Smoothie
I have the same tires. The are really tough to put on. Good tire tho.
Bikes: 2009 SE Draft (I know, I know)
That tire is probably slightly small for that rim. Chances are that your stock rim is 21mm wide based on your stock tire size. I could be wrong though. If I were you I would ride around a 32mm to be sure. Next time you have a tire off, measure the inside width and use the tire chart above to determine the "safe" tire sizes available to you.
