Drag brake question
Drag brake question
Old 03-20-21, 08:15 PM
Shinkers
Bikes: '88 Trek 1200, '91 Trek 1400
Quoted: 125 Post(s)
Liked 12 Times in 9 Posts
Drag brake question
Hello,
I'm looking at an application where I will be using a thumb shifter to operate a caliper as a drag brake. This is not for a tandem, but it seems like this has been done on some tandems in the past so I'm hoping someone here will have some insight.
I'm wanting to know what the best way to deal with the shift cable/brake cable mismatch. I'm assuming most people are just running a shift cable and housing to the brake. Is there a slick way to deal with the difference in housing/ferrule size at the caliper? I know that as a drag it doesn't necessarily matter much but thought maybe someone had a neat trick for this.
Thanks!
Shinkers is offline
Old 03-21-21, 02:40 AM
Ross200
Quoted: 57 Post(s)
Liked 44 Times in 34 Posts
Brake housing from the thumb shifter to the drag brake for us. Index shifter housing will blow up in brake applications.
There are step-up/step down ferrules that might help if you have a mismatch.
Ross200 is offline
Old 03-21-21, 08:20 AM
Shinkers
Quoted: 125 Post(s)
Okay, so how are you fitting the brake cable to the shifter?
Thanks!
Shinkers is offline
Old 03-21-21, 07:01 PM
Ross200
Quoted: 57 Post(s)
1.2 mm shifter inner wire with 5 mm OD compassionless brake housing with metal ferrules. The rig is currently in storage "off site" so pix not immediately available-sorry.
Ross200 is offline
Old 03-21-21, 08:35 PM
Monoborracho
Monoborracho's Avatar
Bikes: More than I really should own.
Quoted: 205 Post(s)
Liked 20 Times in 18 Posts
I’ve used brake cable with a barcon for an Aria drag brake and also for a disk where it was our third brake. Just file the lead head down till it fits the barcon inset. DO NOT use a shift cable for a brake cable.
Monoborracho is offline
Old 03-22-21, 05:54 PM
Shinkers
Quoted: 125 Post(s)
So in that case are you not using a ferrule at the barcon?
Shinkers is offline
