Spinergy Wheels - 2mm ring?
Last fall I shipped to the factory, for repair, a set of Spinergy XL wheels (10 spd shimano style freehub). Something was loose inside the rim. The wheels were 5 years old.
Raves to Spinergy - the put a new set of rims in place at no charge. Great service.
I only pulled them from the boxes today. Spinergy sent new rim tape and skewers. So, again, Great Service.
The rear wheel package included spoke tools and also a 1.85mm alloy ring that will fit over the freehub? Any idea what that is for?
I'll call Spinergy tomorrow but was hoping to put the wheels on and take a ride this PM.
Thanks.
Thanks.
Quoted: 4236 Post(s)
Liked 2,949 Times
Is it a spacer to run a 9/10 speed cassette on a hub meant for 11 speed?
My initial thoughts were something like that but a 4.5mm is required for 7 speed on an 8-9-10 freehub. At about 1.85mm, as measured by micrometer, it is almost same as a single 10 speed cog. At those sizes my micrometer will give a slightly different reading every time I check.
I didn't really think about the 9/10 to 11 hub you mentioned but then my busiest wheel is only 10 speed.
Thanks.
Likes For Monoborracho:
From the interwebs:
Shimano Cassette Spacers
- For use on 11-Speed freehub body with 9 or 10-Speed cassette
- Using 10-Speed cassette on 11-Speed freehub body requires both 1.85mm (FW8991) and 1.0mm (FW4671) spacer
- Using 9-Speed cassette on 11-Speed freehub body only requires 1.85mm (FW8991) spacer
