Choosing a seatpost.
I see plain non-suspension seatposts ranging from $20 to $275. What could possibly explain this gap? What are the factors to consider when shopping seatposts?
A Zipp or Enve logo on the seatpost will command a premium price.
Likes For Reflector Guy:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Form, Function and Price. You can expand the list beneath the first two. The third speaks for itself. Start with a realistic budget for that part.
Am I willing to go above $30? $50? More? So, now I can determine which other attributes I'm willing to buy as an extra.
Function: Correct diameter, degree of adjustability, material, weight, aerodynamics
Form: Style complement to bike (lines, coloring, cutouts, etc.) branding
Quoted: 6974 Post(s)
Liked 10,975 Times
You should be able to get a perfectly good (light, strong reliable) seatpost for well under $100.
Likes For Koyote:
Liked 10,975 Times
They are just different ways of adjusting the tilt...And I suppose the two-bolt will probably hold the tilt a bit more securely, which could matter if you are heavier and/or ride on rougher terrain. But in practice, they probably work equally well...And I actually find the one-bolt posts to be easier to adjust.
Likes For Koyote:
Quoted: 942 Post(s)
Liked 527 Times
One bolt systems are indexed so if your ideal "tilt" is between index points you are forced to settle on the index either above or below your ideal point. Two bolt systems are not indexed and are infinitely more adjustable with regard to "tilt" position.
Likes For jadocs:
Likes For topflightpro:
Quoted: 550 Post(s)
Liked 325 Times
Campagnolo Record SP10-RE round post. Infinitely adjustable, holds its adjustment with low torque, correct diameter, shiny silver, worth the $100 used ones sell for. Also available with a discrete Record logo consistent with 9 speed ergo era aesthetics.
Classic Campagnolo C-record aero post. Works like the later round version. Period correct for 1980s bikes. Available as a Record part with engraved shields plus collectable price tag and Chorus without.
Nitto S65. Mine needed 16 NM of torque to maintain its adjustment so I replaced it with a Campagnolo SP-10RE.
Quoted: 550 Post(s)
Liked 325 Times
Quoted: 1461 Post(s)
Liked 1,486 Times
Carbon commands a premium price.
It was a generalization. But in the interest of accuracy, I am referring only to the $265 Zipp seatpost.
I generally prefer two bolt designs as offered by Deda or Thompson over one bolt designs like Ritchey or FSA because I find two bolt designs slightly easier to setup and slightly stronger. It's splitting hairs, though. The Pro Vibe captive expanding wedge design is also great.
Also, long, flexy D-shaped carbon posts are awesome.
Here ends seatpost talk with Hiro11.
Thread Killer
Quoted: 3152 Post(s)
Liked 1,717 Times
There are many different types of clamping systems, even within the general 1-bolt and 2-bolt categories, and the good thing is that, generally, they all work just fine. The 2-bolt concept grew out of the demands of MTBing and do offer superior clamp security. so if you’r going to be riding in a way that stresses the clamp, you want to thinking about that.
For typical road riding though, it’s nothing to worry about, and the biggest issue with the postis that you get the adjustment range you want, particularly since many saddles have shorter rails nowadays. You’ll notice some posts have the clamp area centered directly on the centerline of the post— this is zero setback— while others have the clamp offset from the centerline of the post, known as setback. Depending on where you want your saddle relative to the pedals and how much seat rail you have to work with, setback may be preferred.
Another consideration in posts is length, so be aware of that.
Material construction can be a big deal depending on what you’re looking for. Carbon fiber are the lightest generally, while titanium can be quite flexible, helping to smooth out bumps. Because of variability in size diameter and extension length, that’s master level stuff, though, and probably not something to bother with for someone who has never thought about posts before.
Personally, weight, style, and price are the big three factors for me, and I try to buy as light and cool as I can afford. FSA SL-K Setback carbon fiber posts fit the bill often for me apparently, as I have two, but I also like Deda’s single bolt road styling and USE’s unique Alien single bolt styles as well. I think titanium is the best post material by feel, and would run it more often if producers offered black anodize or some styling elements beyond natural ti color brushing, bead blasted, satin or whatever.
Randomhead
Liked 3,701 Times
I have a cheap Kalloy post where the internal bore was way off of being concentric. Pretty sure it was unintentional. Like anything else in cycling, the high end gets you very marginal gains for a lot of extra cost. But the difference in quality between the cheapest and the mid-price option can be quite large.
I have and have had many seat posts over the years. Infinitely adjustable posts are my preference as I can get saddle tilt exactly perfect. Currently have two of the Nitto single bolt posts and they do require a lot of torque to secure the clamp. The Campy C Record is excellent as well with the bonus of not requiring as much torque to secure the clamp as the Nitto. Once had a cheap Asian carbon post that served well for about 8 years until the clamp fractured. The clamp was aluminum and it simply cracked from the load I put on it.
My personal favorites are an equal toss up between the Nitto, C Record, Velo Orange Gran Cru, and the good ol' Nuovo Record two bolt post. All three seem exceptionally durable, have at least 25mm of setback with the Gran Cru at 30mm, and they all look great. Weight? Light, strong, inexpensive. Which two do you want?
Quoted: 2604 Post(s)
Liked 1,933 Times
I prefer the controlled adjustability of two bolt seatposts -- I don't think anyone has mentioned that so far. With a two bolt system, you can loosen one bolt, slide the saddle fore or aft, and tighten that one bolt: tilt stays the same. Or you can loosen one bolt and tighten the other to adjust the tilt -- fore/aft position doesn't change. Adjustments are precise.
Contrast that to my experience with one bolt systems. Loosen the bolt until things can move. When you get the bolt loose enough, everything is in play. I've gotten the tilt right only to mess up fore/aft, and vice versa. Adjustment is more of an accuracy thing; it's like learning to shoot a bow and arrow. Miss right? Go back and shoot again, it may be left, up, or down from the bulls-eye. Keep shooting (or adjusting) until you get lucky and hit the bulls-eye, or get tired and call it quits.
Drew's picture surprised me. I haven't had a failure like that on any of my two post seatposts. I guess that was a latent manufacturing defect -- nasty surprise when it failed, I'm sure!
Likes For pdlamb:
Yeah, being able to independently deal with rail clamping force and saddle tilt makes everything a bit easier. Also, I've found two bolt seat posts are less likely to creak.
True. Actually, my favorite clamp design of all time is this cheap $20 "Forte Team" seat post from the old Performance Bike:
https://www.ebay.com/itm/28394607200...EaAjmjEALw_wcB
The bolt on the side independently adjusts rail clamping force. Once you've clamped the rails, the bolt on the back of the post then independently secures the saddle tilt. This makes it a snap to set up and it doesn't creak. I've never seen another post use that design.
Thread Killer
Liked 1,717 Times
Thread Killer
Liked 1,717 Times
Your back-and-forth with Hiro11 underscores my point that there are lots of different seatpost designs in both 1- and 2-bolt designs, so just saying a post is one or the other doesn’t really say much.
As another example,should 2-bolt refer to two bolts used to clamp the rails, or should it include systems like the above Forte post where only one bolt clamps the rails and he other controls angle? The original American Classic post from the mid ‘80s had a similar division of labor with two bolts controlling saddle position, but the angle adjustment bolt is not really bolted to anything, and is really more just a set screw, yet performs the same basic function as the second bolt in the Forte system. You can see that in the pic below. Personally, I use 2-bolt to refer to rail clamping, but it’s admittedly an arbitrary distinction.
