Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Has anyone combined a crank shortener and pedal extender?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 08-04-23, 04:10 AM
esther-L
Bikes: tandem, road bike, hybrid
Quoted: 19 Post(s)
Liked 6 Times in 6 Posts
I use pedal extender on left side to avoid heel strike.
I am considering adding a crank shortener also on the left side, and wondering if there are known issues with combining those together?
esther-L is offline
Old 08-07-23, 09:23 PM
oldbobcat
oldbobcat's Avatar
Quoted: 514 Post(s)
Liked 451 Times in 339 Posts
There shouldn't be.
oldbobcat is offline
Old 08-07-23, 10:49 PM
Russ Roth
Quoted: 1088 Post(s)
Liked 1,028 Times in 724 Posts
Would there be a need to? Maybe you found a nicer, high end system but the basic crank shorteners are thick enough the pedal spindle won't stick out the other side and gouge the crankarm, probably about as thick as your current extender. Rather than cludge together something like this would it not be better to buy a shorter crank with a wider Q-factor if something new or just buy a wider BB with a shorter crank if older square taper?
Russ Roth is offline
Old 08-08-23, 12:20 PM
esther-L
Quoted: 19 Post(s)
It's not an older square taper. The issue is that prosthetists point the toe out a few degrees on the foot on artificial legs and this is required to make the amputee walk efficiently. Also, I have a very non-textbook dynamic alignment to make me walk well. The ankle does not rotate, so that toe is always pointed out.
I have tried having a biking leg just for cycling, and that was a fun experiment for about 5 years, but not sustainable. Now I'm going to modify the bike to me. I'll take a look at shorter crank on 1 side with wider Q-factor. The crank shortener and pedal extender are only needed on the prosthetic side.
Thanks!
esther-L is offline
Old 09-25-23, 12:33 AM
Tessitori1
I am riding 145 cranks with a 20mm pedal extender on the right pedal and none on the left!
Tessitori1 is offline
