What can I do to improve Universal 68 Sidepulls?
Francophile
Liked 674 Times
I have a bike (1970s Mercian) with Universal 68 sidepulls, and another ( 1960s Bianchi) with 61 centerpulls. The 61s work well; the 68s are terrible. Both sets use the same levers and have Kool Stop Salmon pads. As far as I can tell, thé issue is the lever pull. I need to get in the drops to get enough leverage to pull the brake levers hard enough to get the brakes to do anything. Braking from the hoods is ok for gently slowing down, but is inadequate otherwise.
i would love to keep the 68s because I suspect they were original equipment in this bike, but if I must I can swap them for something else. I have Nuovo Record, Mafac, and Weinmann Vainqueur brakes at hand to use as needed. But first, I'd love to hear if anyone has any suggestions for setting up the 68s to work more efficiently. Thanks.
pic shows bike as I received it. I've posted a pic of the bike as rebuilt down a few posts, so you can see the cables and housing are new and in good condition.
The center mount version of the Paul Racer would probably work.
Likes For Rick:
I have fully Mavic equipped Limongi. The Mavic branded brake callipers were made by Modolo. When I acquired the bike, it had been converted to flat bar with linear pull brake levers, a stupid combination. Wanting to convert it back to drop bars, I bought a pair of Tektro brake levers, forget the model name. I was very pleasantly surprized by how good the braking was the first time I rode the bike. The braking compares pretty well with much more recent dual pivot brake callipers. I believe that they are the RL340 levers which are very inexpensive. Worth a try
Liked 5,404 Times
Single pivot calipers were always poor for quick stopping unless the pads were freshly new and everything else perfect. Looks like you might have a steel rim. Those were always worse for stopping distance than a alloy rim. The dual pivot calipers stop much better than single pivots ever did IMO.
I never was one to experiment much with different pads. So you might try some KoolStop pads or others. Many other members recommend them.
Regardless of the poor stopping ability of the single pivots, they always stopped me in time. Even when wet. Though I came close to soiling my underwear many times! <grin>
Likes For Iride01:
Likes For alcjphil:
Francophile
Liked 674 Times
Clean the rims with acetone and wire wool. Check the cable is moving freely, the pivots are not slack and not binding, the arms aren't rubbing, the spring legs are sliding on the arms, the blocks are slightly toed in ... just all the usual stuff really, and a few drops of Tri-Flow.
Francophile
Liked 674 Times
Likes For Aubergine:
Francophile
Liked 674 Times
Francophile
Liked 674 Times
Bike as refurbished with new cables and housing.
I get it. That photo shows that you have tons of tire clearance which was pretty common in the early 1970's. I still suggest that you spend $25 and buy a set of Tektro RL340 brake levers. An inexpensive experiment. As a bonus, the levers have an additional release on the lever allowing wider tires to pass through if the release on the calliper doesn't give you enough width for wider tires
Likes For alcjphil:
Francophile
Liked 674 Times
Trying different levers does sound like the best solution. Those Universal levers are pretty ratty!
Tektro levers work so far above their price point that is worth the experiment I also have them on my touring bike. Makes it easy to open the cantilever brakes when I have to change a tire
Liked 3,482 Times
If you shop around, there are levers with greater leverage, which comes at the cost of reduced cable pull. That may solve the problem, though they'll call for more aligned wheels and less forgiving brake adjustment.
You may not want to replace the levers, hoping to keep the bike more original, but the 50 year old para hoods are probably rotting anyway (mine are).
In any case 2 thoughts.
1 these brakes originally had cloth reinforced rubber shoes, with a higher coefficient of friction than most modern shoes. Higher CoF means greater friction with lower brake pressure, so I'd try to source this type of shoe before giving up.
2- this was designed as a brake for racing bikes, not utility bikes. In the racing world, brakes are barely used under conditions while riding the hoods, and if so, only for small corrections. Real brake use tends to happen when riding the drops, so both the maker's and the riders (,including me) were fine with what you find to be a problem.
So, you can't eat your cake and gave it too. Decide whether to prioritize keeping it original, with small tweaks and marginal improvement, or go with another brake better suited to your needs.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Francophile
Liked 674 Times
Thanks!
Liked 3,482 Times
So, measure the distance from the pivot to the cable swivel. Shorter means more leverage, and may solve your problem.
FB
Chain-L site
FB
Chain-L site
Francophile
Liked 674 Times
That was exactly what I intended to do.
I came to the point with the ‘68 where I gave up on them. Either the calipers’ bend for the pad slot had crack, the pivot bolts broken, or the lever bodies (famous for cracking on installing) were broken.
Liked 3,482 Times
Another example of a product that served well for years, but who's time passed with the advent of either new technology and/or ham fisted mechanics.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Recycled Cycles in the south end of the U district has great prices on used parts, big selection. I found some fairly obscure brake levers there (L-handles, so can grab on bar-ends too), like new, cheap. Replacement shifter, $5. Check days/hours, I think still closed on Sunday and Monday, close at 6:00 p.m.
All modern brakes, short and long pull, have a partial return spring in the handle, to reduce cable friction. Make sure the brakes and levers are matched.
Francophile
Liked 674 Times
Liked 509 Times
I used Universal 68s for 7-8 years, until I finally sprung for a full Super Record kit. Following the move away from centerpulls in the early '60s, nearly everyone used these until Campaganolo made a Nuevo Record brake set in 1968. Give them a thorough cleaning and lube around the pivots, and adjust the free play at the pivots by adjusting the locknuts. Then replace the cables and housings, and clean up the levers. This maintenance is long overdue. If that still isn't cutting it, look for new pads. Anything that fits like old-style Campagnolo Record will be an improvement.
Francophile
Liked 674 Times
Liked 3,482 Times
FWIW, I was happy with mine for years, and replaced them with Campy Record (1st gen) only after a crash bent my front brake. If not for the crash they'd still be there.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
