Find the flaw: Expert version
Likes For altenwrencher:
Liked 3,302 Times
if you're hungry, go make a sandwich... don't be chomping on hub parts!
-YMMV
-YMMV
Likes For ign1te:
Bits of extraneous metal jammed in the freewheel? Guessing, I've never had much to do with these, I used to be good with Sturmey Archer.
SE Wis
Liked 3,653 Times
Never had one of these open but What's going on here.
At midpoint there appears to be a dog-clutch, thin metal cylindrical part with axial tabs, that appears to perhaps be missing a section between tabs. Hard to see with all the grease.
Just to the right of that, looks like a ring of some sort with a good chunk of it missing.
Also the cylindrical section to the left of the right caged bearing, someone had mentioned a chunk lower in the picture, but the same part high in the picture also looks chewed. Inside of that, the planet gears look not fully engaged, partly slid out axially.
Likes For Duragrouch:
Not having a clue how that hub is constructed, I'm gonna take a first stab at it and say that the (pic) left end wheel bearing disintegrated or the cone loosened, and that's what holds the whole assembly together axially, or simply a locknut on the axle that does the same and rotates with the whole assembly.
Wow, I'm seeing more and more damage, huge chunks taken out of carriers or plates.
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Liked 480 Times
It didn’t work as a rock crusher.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Retaining ring that keeps the rods in their place has failed. Rods are protruding past their normal position (picture). This caused gear mis-alignment which led to further damage.
Is the retaining ring a big wire ring, or a flat plate like a giant c-clip? Is it fixed or free to rotate with respect to the pins? I'm just wondering about why it failed, if under any stress, or just fixed with respect to the pins and there was fretting wear at each contact point?
Clark W. Griswold
Liked 4,552 Times
Exactly what is the flaw in using an internally geared hub? Is it because you don't understand their utility or because they did something to you or what? Yes there are drawbacks to an IGH system just like there are drawbacks to using a derailleur and drawbacks to a fixed gear or single speed application. However in many cases the IGH can be quite superior if done right for a wide variety of riders. It won't be ideal for someone racing or who needs really quick gear changes but that is a small number of the cycling population. Also consider that Sturmey-Archer is still producing their hubs with not a ton of change for way longer than any derailleur has been around is pretty decent testament to their staying power. Granted yes S-A did get bought out by SunRace but I can still get a shifter that can work with an old 3 speed hub from the 50s is pretty neat. Now I am not saying I am a S-A fan just pointing out the longevity of their product compared to say a Dura-Ace derailleur which will change every 3-6 years or so and not always be backwards compatible.
Likes For veganbikes:
https://www.sjscycles.co.uk/hub-spar...-1110/?geoc=SE
Came out of its groove. Could be error during assembly or material failure. These rings are not under load.
Looks like this.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Liked 757 Times
So, the ancient Sumerian Wankel rotary engine, brought to earth by ancient aliens? That's all over the internet...
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
