wheel building
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,006 Times
wheel building
So do the outer spokes go forward or rearward
I have both
outside toward front
totally screwed, 3 spokes from the inside next to each other with 2 crossing
outside toward rear
outside front
Some I built, some purchased so questions
I have both
outside toward rear
outside front
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Likes For bwilli88:
feros ferio
Quoted: 1393 Post(s)
Liked 1,334 Times
If I rebuild on an existing hub, I keep the same clockwise/anticlockwise inner/outer spoke pattern that is evident in the indentations on the hub flange.
In practice, I have yet to find that the exact pattern (symmetrical left and right flanges vs. parallel left and right flanges, torque spokes on the inside vs. outside on the drive side, likewise on the left side -- I have experienced almost every combination, as you reportedly have, as well) makes any real world difference in feel or reliability of a wheel.
Likes For John E:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 537 Post(s)
Liked 1,017 Times
There are a lot of little things you can do that show attention to detail, but as long as the spokes are laced correctly and tensioned equally, it doesn't really matter to us mere mortals.
Likes For Pompiere:
Quoted: 793 Post(s)
Liked 1,794 Times
Likes For zukahn1:
Quoted: 793 Post(s)
Liked 1,794 Times
The outside lacing on hub shift or coaster wheels is basically correct to help offset the back force of shifting or braking.
Quoted: 1954 Post(s)
Liked 2,018 Times
Definitely fix that SA!
Quoted: 975 Post(s)
Liked 1,638 Times
Kinda like that little scratch in the paint no one can see but you...
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4684 Post(s)
Liked 5,818 Times
I was taught pulling spokes inside (head on the outside), as they get the most stress, and if your chain drops behind the largest cog, the outer ones get chewed up. I believe that's the gospel according to Jobst as well. But then, some wheel experts differ...
What's really important is to build a wheel so that looking down through the valve hole you should see the Campagnolo logo centered up.
All of this is approved by the ASFE.
Likes For gugie:
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 513 Times
Much like what #Gugie said above. The spokes under the most tension are the pulling spokes on the rear hub. Since most spoke failures occur at the bend, a pulling spoke should be on the inside of the flange with the head facing out. This gives the spoke a slightly straighter pull angle at the bend when the wheel is under torque. If it were laced to the outside it would then also have to bend around the outside of the flange at a greater angle which could increase any weakness. Having said that, spokes these days are of such excellent quality that it really does matter that much. Breaking a spoke on a properly built wheel under normal riding conditions is quite rare without some outside influence. Just my opinion though and worth what you paid for it.
https://utahrandonneur.wordpress.com
Likes For Oldairhead:
Quoted: 4813 Post(s)
Liked 3,940 Times
Señor Member
Quoted: 1492 Post(s)
Liked 1,099 Times
I used to think stuff like this might matter, but after several dozen wheels for my own use, I am starting to think that many of the "finer points" of wheelbuilding are inconsequential, and that the reason they have been discussed is because someone's ego decided to rationalize their personal preferences and attempt to showcase their knowledge of trivial things that don't really matter. Yes. There are absolutely some good practices advocated, and I'm not claiming these people are incorrect - but I haven't found the leading/trailing or inside/outside makes a difference.
Granted, I usually build 36 hole wheels, have only built 3-cross, and always start wheels relative to the valve hole and with spokes with heads facing out (because it's an absolute P.I.T.A. to lace 3x if you start with the courses of spokes that have the heads facing inward). I suppose this means I am consistently building wheels with the same pattern, but I can't be bothered to contemplate how my practical approach to lacing compares to what the "experts" advise about such a traditional and proven effective pattern.
Likes For USAZorro:
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,564 Times
An aside more than anything else here, but I recently picked up a '78 Raleigh Comp GS and both front and rear wheel were laced with the 'pulling' spokes on the inside on one side of the wheel and on the outside on the other...! Seems like it would be kind of a PITA to lace up a wheel this way, and.... why?
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
Gotta say, after assembling traditional 2x or 3x wheelsets, I was a bit flummoxed with my first radial spoke build. Took me a minute to figure out there's nothing to figure out. 😜
Likes For BTinNYC:
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
Likes For awac:
Not so New
Likes For John D:
Quoted: 793 Post(s)
Liked 1,794 Times
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,006 Times
feros ferio
Liked 1,334 Times
Once you put the torque spokes on the inner flange of the drive side, putting them on the outside of the left flange makes wheel dishing asymmetry that much more severe. Other than the chain suck argument, one could choose outside the drive side flange and inside the left side flange for torque spokes.
Quoted: 65 Post(s)
Liked 60 Times
Mavic, back in the early/mid 90's, did a test with their neutral support wheels. They tested every combination. Result was outside spoke pulling and blue loctite held up the best.
