Cog position in dropout
Does my cog look too far back in the dropout? This one is a 17t, the 16t I run sits even closer to the end of the dropout. Should I replace a full link in the chain with a half link?
Dave
Dave
Quoted: 4846 Post(s)
Liked 3,976 Times
I don't see anything wrong with what you've got. You could go another 1/4" back with no issues if you wanted. (Sounds like you already have with the 16 tooth cog.) Possible considerations - you may prefer a more compact rear end to the bike that will skid less when climbing out of the saddle on slippery surfaces. Or like the quicker feel when cornering with the wheel forward. On the other hand, you may like the generous clearance between tire and seat tube and the ease of getting the chain off to pull the wheel out.
The bike absolutely doesn't care where that wheel sits as long as you have enough track end to clamp properly with the nut.
I'd probably remove a "link" (inner and outer pair) and slide the wheel forward 1/2" - unless I had thoughts of also using a bigger cog to go up a hill. There are 1/2 links (male at one end, female at the other) that shorten the chain just 1/2" and move the hub 1/4". As far as I know, these are all for 1/8" chain, not 3/32". I cannot tell which chain you are running.
It was interesting about what you said with having the wheel further in on the track end. I hadn't really thought about how it was effectively changing the wheelbase.
Dave
Liked 3,976 Times
Thanks, wanted to make sure my setup was still safe. Been running that 17t for a while, don't really have the power to push the 16t up hills at the moment. I think I want a quicker feel on cornering, will probably swap out a full link with a half link. Does it matter where the half link is on the chain? (Does it need to be connected to the quick link, or is that just my OCD?). Lol. Think I can still swap between the 16 and 17 with the half link? I don't swap very often, but options are always welcome.
Dave
Dave
Pulling the wheel forward won't have any issues when you swap to the 16. You've just taken further from the end. It's on the 17 that a too short chain makes getting enough slack to derail the chain and get the wheel out harder. (If you shorten the chain, try removing the wheel before you go for that ride. Otherwise you might find you cannot remove the wheel to repair a flat without the chain riveter you left at home.)
Likes For 79pmooney:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 170 Post(s)
Liked 281 Times
bironi
Quoted: 101 Post(s)
Liked 298 Times
I don't see an answer to what chain width you're running.
If you use 1/8" chain, Izumi makes a half link with a screw nut attachment.
You could dispense with the quick link.
Liked 3,976 Times
And if you want a half link for 1/8" chain anywhere in the country, go to a hardware store. 1/2" x 1/8" chain is an industrial standard. The pin might be clevis and cotter like you would see on a sailboat but it will both work and be even more secure.
Old fart
Quoted: 3607 Post(s)
Liked 3,433 Times
The axle position in the dropout is determined by the chain and your gearing. As long as the axle is fully within the slot (and yours is), it'll be fine. If you change your gearing to a smaller sprocket and/or chainring, you'll need to shorten the chain.
